Nissan quality, still strong
Old 12-28-2007, 02:28 PM
eric93SE's Avatar
Damn I still have some love for my 3rd gen
Blower motor stops running, and its cold out side. No spin at any speed. checked fuses, good. checked voltage at motor, good. couldn't get to the connector to easily get an ohm reading, so I pulled the motor, had to pull the glove box to get at a screw, pretty easy. Motor has less than an ohm of resistance, spins not too freely, and acts as a generator while spinning it /generates higher voltage reading/. So next, hook up a 12V battery for a quick second and it spins up to a high speed. Open up the end cap to check the brushes, and they look good plenty of life left and the sping puts enough pressure on the commutator. So I clean it up, blow out the dust with compressed air, put some all purpose grease in the bushing houseing /it was dry before/. Do a test run by plugging it back in without installing it in and bam runs like new again. Gotta love Nissan quality.
Same thing happened with the starter motor last summer, the grease dried out, and the engine wouldn't turn over fast enough to start. Took it apart and cleaned it, greased it, and literally starts like new again.
eric93SE is offline
Old 12-28-2007, 05:40 PM
ColombianMax's Avatar
I didnt read everything rather a skim but I dont get it...
ColombianMax is offline
Old 12-28-2007, 05:53 PM
¯\(°_o)/¯
Greeny's Avatar
His blower motor stopped working,he took it apart/cleaned it/regreased it,now works great.
go nissan woohoo..
Greeny is offline
Old 12-28-2007, 06:10 PM
Jesus was a Zombie.
BenStoked's Avatar
that sounds like youre under-enthusiastic.
it should be more like
unless you mean
BenStoked is offline
Old 12-28-2007, 06:14 PM
1992maximase30's Avatar
yea i have to admit nissans are pretty good even when working at autozone there's more problems with american than imports.
my dad had a 240 sx...NEVER KEPT UP ON IT.
i always did.
never used premium, timing chain sounded like crap till warmed up.
then started burning oil round 190k but still ran like a champ.
good job on the blower motor!
1992maximase30 is offline
Old 12-28-2007, 06:15 PM
Ah, thanks for the clarification
Old 12-28-2007, 08:37 PM
goon9's Avatar
Just wondering... why is shavedmax's car your sig?
goon9 is offline
Old 12-28-2007, 08:47 PM
Yea I was wondering the same thing
Old 12-28-2007, 09:31 PM
eric93SE's Avatar
Because that hood is on my max right now LOL
So technically...........
That max was fricken awesome, RIP. Shaved doors might still be for sale
eric93SE is offline
Old 12-29-2007, 01:47 AM
¯\(°_o)/¯
Greeny's Avatar
Could you make the sig pic a bit smaller please?
thanks
Greeny is offline
Old 12-29-2007, 04:49 PM
mod or sell?
internetautomar's Avatar
i always did.
you work at autozone?
internetautomar is offline
Old 12-29-2007, 05:46 PM
aminus21's Avatar
Nissan Rocks!
Just curious, what kinda grease did you use on the starter? White lithium?
aminus21 is offline
Old 12-29-2007, 07:13 PM
Way out West
Cliff Clavin's Avatar
A job is a job, man. At least he is working around cars.
Your job may be better, but he is working his way up.
Cliff Clavin is offline
Old 12-29-2007, 07:42 PM
i used to work at autozone...part time while working at just tires fulltime. yall may laugh but i met some fine *** chicks there.
Old 12-29-2007, 07:47 PM
Jesus was a Zombie.
BenStoked's Avatar
mau! ive got a part time job at a sonic drive in. you guys seen the hotties car hoppin?
:wink:wink:
Old 12-30-2007, 08:30 AM
eric93SE's Avatar
Originally Posted by aminus21
Nissan Rocks!
I used a multipurpose grease, white lithium should be fine. Bearing grease would be too thick. Thinking back, the bushing was completely dry, I have a feeling there were a ring of magnets around the bushing end cap. So it might have been some MAG-LEV action going on there, GO Nissan HOOT. So the motor either got stuck from some age/friction, or possibly the motor got stuck in a dead field spot.
eric93SE is offline
RinconI30
11-10-2015 10:55 PM
carid
09-09-2015 05:06 AM
ef9
09-05-2015 11:18 PM
coasterswim
09-02-2015 07:43 AM
Quick Reply: Nissan quality, still strong
