5-Speed Swap Here I come
Well, I'm finally able to have enough time, patience and money to start my VLSD-5 Swap/ ACT Clutch/ Pacesetter sts. Looks like it's going to be a fun job to say at the least, but my dad has air tools galore and a lot of how-to knowledge. I hope it works out. If anyone has any hints, methods, anything to make the job easier PLEASE share. I have about 8 or so stickies pertaining to the 3rd gen 5-speed swap, and Matt Fugina (previous owner, and 5-speed swapper) offered to come and help if I really get myself in a bind.
Here is where the car is at now!
Anyone wanna come get the engine out of my way? Lets say $100!
for how jacked that engine bay looks, I'd be wary of using the tranny. check all mounts and make sure the axles didn't beat up the differential. I'd also be wary of the knuckles and axles if you're planning on using them.
Also, I'll be sure to take pics... and if I do it right *crosses fingers* try to make a little write-up.
Is this swap for the VE? For some reason i'm thinking you have a couple maximas aside from this sad hunk of junk pictured.. If it is for the VE, you're going to need that plenum, and you're probably going to want to get some new axles
Important little piece of info I learned the other day: The passenger-side CV axle support bracket is a different part number between M/T and autos. They have slightly different offsets from each other, which is why my passenger-side axle seal has always leaked despite replacing the seal several times...Make sure you swap that bracket over, as well...3 bolts hold it to the block.
Everything you need is on the parts car. The plenum is what you're referring to as the manifold, it's got the power valve bolted to the left hand side, the auto doesn't. Both VG and VE have a power valve. Might want to throw some new injectors in the rear rail if you don't plan on pulling the plenum later. Maybe the knock sensor as well.. Course that'll run you another day or so and about $450 extra..
Pic of the car with both axles out:
Yay, no more axles:
One of the control arm bolts I stripped to hell... (still on the car, but we worked around)
The axles look and feel surprisingly good...none of the boots have any cracks:
[QUOTE=94maxshima;6133174]Gots the torque wrench and FSM! Also, I knew the VE-5's had a variable intake manfold, and I had planned on getting one soon. But is it a necessity that it be done with the swap? Also, is there any visible difference from the outside?
The donor car doesnt have the power valve (evidenced from pic#3 above).Even if you installed the Variable Intake Manifold your current harness doesnt have the connector for the variable intake (located around the EGR area).
You would need to replace the harness or install a switching mechanism to do it manually. (I think Aaron92SE has it on his car)
Try to replace BOTH axle seals on the tranny since it's more difficult with the tranny installed.
If I recall correctly, I bel. the driver side axle is supposed to have a small cap/cover on the end that goes into the tranny. It doesnt seem to be visible in the pictures.
Double check the tranny bolts carefully as it's easy to mixx it all up.
Dont forget the holes UNDER the insulation by the brake pedal.
Good luck
Good luck
Good luck
Good luck
If you want your abs to work,yes you need abs axles,or you might be able to tap the abs rings on your current axles onto your non-abs axles..
Today went pretty good, I have the starter, shifter, shifter brackets, support rod, control rod, and all clutch lines/ slave cylinder lines off. I was reading earlier and I believe someone mentioned that I should ditch all of the stock clutch lines and just run a stainless steel one. Is there any benefit to that? Why does the stock setup have all of those twisties and turnies?
If you inspect the pass. side axle that goes into the tranny, you will notice it has a little cover, kinda like a dust cover or something. I THINK that the driver's side (part that goes into the tranny) has a similiar cover which doesnt seem to be on the axle in the picture.
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
HerpDerp1919
09-29-2015 02:02 PM
