Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-26-2009, 07:56 PM   #3881
Quote:
Originally Posted by BenStoked View Post
pics of "stock" mounts? plz? cuz mine aren't welded. they are held on to each mount by two bolts.
k, will take pics tomorrow when theres light
austin from texas is offline   Reply With Quote
Old 07-27-2009, 11:05 AM   #3882
thats my stock bar set up
heres the new one again so you dont have to go back to the last page
i just dont see how they are compatible
HALP plz!
Old 07-27-2009, 11:51 AM   #3883
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
Originally Posted by MaXiMa_RyDaH View Post
hey, im having a problem with my signal lights... i have a 94 maxima and I was wiring up my speaker system and after i was done, i noticed the signal lights no longer worked later on. The tail lights and break lights work fine, but the signal lights in both front and back wont turn on or even blink in the dash display or make any clicking sound at all... ive checked the fuses and they are good so im looking for feedback and possible diagrams of the turn signal wiring...
did you do the head unit too? cuz if you had that part of the dash out, and you forgot to plug the hazard light switch back in, that'll keep your signals from working at all.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 07-27-2009, 11:52 AM   #3884
HALP plz!
there is SUPPOSED to be a hardware kit for this.... leave a message for traxtar944 or maxitech; they have aftermarket rear swaybars iirc
__________________
Old 07-27-2009, 12:05 PM   #3885
just pmed them both, thank you sir
benstoked, you got any input on this??
Old 07-27-2009, 04:54 PM   #3886
:squint:
BenStoked's Avatar
Send a message via AIM to BenStoked
lol. no, sorry, I thought you meant the upper/inside mounts (seen near the top of the first two pictures). haven't seen, or looked, for any aftermarket setups, and how to install them (yet), so I have no more input
BenStoked is offline   Reply With Quote
Old 07-27-2009, 09:08 PM   #3887
Hey guys, I'm looking for the part number or the name of something. On the power steering pump bracket, there is a tensioner pulley of some sort? Looks like the one used for A/C, anyways, it's making a weird noise and I want to replace it. Anyone know where I can find it or a part # to order it?
__________________
89 Maxima GXE
Mods: Rear Disc Conversion, Front Strut Tower Brace, Brembo's all around (Slotted Front), SE Tails - Hopefully more to come!
Dhunterx is offline   Reply With Quote
Old 07-27-2009, 09:39 PM   #3888
Quote:
http://www.courtesyparts.com/11925p-...4-p-50706.html
overpriced OEM part is overpriced.....
after my back heals i can pull the one off my parts car for you.
__________________
Old 07-28-2009, 09:14 AM   #3889
Wow that is pricey. I haven't had any luck trying to find it aftermarket.
__________________
89 Maxima GXE
Old 07-28-2009, 09:39 AM   #3890
03 E55 AMG, 93 G20, and
Send a message via AIM to mikekantor
If I'm looking at the same part, its $30 at rockauto.com
ACDELCO Part # 36115
__________________
mikekantor is offline   Reply With Quote
Old 07-28-2009, 02:30 PM   #3891
Don't think this is worth starting a new thread for, so here's my question.
What is this plug for? It's not plugged in and hasn't since I had the car, I'm pretty sure about that.
It's right beside the ABS box thing on the passenger side.
Also what would a broken vacuum line do to the engine? I just found one, I will replace it but could it affect my gas mileage?
__________________
Phatmatt is offline   Reply With Quote
Old 07-28-2009, 03:27 PM   #3892
i mean obviously you know WHERE that thing plugs in... you have 1 male and 1 female plug right there next to each other. that might be for the cruise control or the abs i dunno... how many pins and what are the wire colors?
as for the vac leak that will cause your engine to not know how much air is actually coming in which can mess up your fuel mileage, air/fuel ratio, power, idle, etc. it will also keep your a/c from working as well as it otherwise would (because your heatercore bypass isn't working with that particular hose disconnected)
__________________
Old 07-28-2009, 03:56 PM   #3893
Green and White and two pins. And yea I obviously know where they connect, but I don't know what it's for.
It connects to the black box to the right of the plug.
__________________
Old 07-28-2009, 04:30 PM   #3894
looks to be part of the "E5" harness plug group (there are a total of 4 plugs in the E5 group) that controls the ABS
__________________
Old 07-30-2009, 10:43 PM   #3895
I have a problem! Just put in a new fuel injector now running really rich?
could anyone help me out?
maxilina90 is offline   Reply With Quote
Old 07-30-2009, 11:05 PM   #3896
2 VE's are better than one!
The Suspension Techniques hardware kit will give you a metal plate that you have to install in between the strut and that lower portion where the stock bar attaches. It's really a big PITA getting those separated (or at least on my car since it was from Penn. originally, but IIRC even my Texas car was hard to separate)
The Addco bar mounts differently but I haven't installed mine yet so I don't know offhand how it mounts
__________________
Desperately looking for a 5 speed axle carrier bracket. Either VG or VE will work. PM me if you have one!
Good working door lock timers $20 shipped. PM me if interested
James92SE is offline   Reply With Quote
Old 07-31-2009, 07:03 AM   #3897
check for vacuum leaks. listen around the manifold to make sure the gasket seated right. check all vacuum lines to make sure you put al of them back on.
did you use rebuilds, aftermarket or new oem injectors?
__________________
1991 GXE Resurrected from the dead
1989 SE gutted for parts and 5 speed.
300zmax is offline   Reply With Quote
Old 07-31-2009, 12:49 PM   #3898
perhaps pinched an o-ring. is there fuel on that particular spark plug?
__________________
Old 08-01-2009, 06:13 PM   #3899
Revs jumping when coasting downhill
Hi Guys,
I've noticed something weird happening on my 1993 J30 VG30E and hoping someone might have had a similar experience. When i'm coasting downhill and doing about 80km/h the revs are right on about 1500rpm but the engine starts jumping up to about 1800 and back down again constantly. It only seems to happen in this situation. My first thought was that the car was changing between 3rd and 4th but it felt different like it was coming from the engine. Another thing i noticed which may or may not be related - when doing idle learn a while ago and trying to hold the revs at 200orpm i found it kept dropping down to about 1500rpm all of a sudden. I eventually managed to get them holding steady at 2000 for a couple of minutes after this happening a few times. Thought it was a bit strange at the time. Otherwise the engine runs really well - smooth and powerful. Any ideas what this be?
Cheers,
Mark
mark77 is offline   Reply With Quote
Old 08-01-2009, 07:54 PM   #3900
it could be lockup engaging and disengaging. that's right around the speed where it engages... so it could be that you are just barely treading the speed where it engages and disengages and that's why it's doing it. just a thought.
__________________
Old 08-03-2009, 04:03 AM   #3901
98 Octane
Howdy all.
I just brough a Maxima 3rd Gen (93 VE) a week back from ebay for £350 (about $500). It's in great condition.
Im looking at modding it all out balancing HP with MPG's.
At the mo im looking at clearing out the engine bay, re-wiring, hosing and re-locating the battery. Also looking at running HHO (water conversion).
Just a quick question though (and yes I have tried the search ) Living in the UK our petrol option are 95 octane (budget) or 98 octane (premium). The car is set at the mo to 15 degrees timing. Im wordering if it is worth advancing it further to maybe 20 if runing on 95.
Can I go further than this if running on 98? and what about the ECU? Should i get it re-programmed.
Cheers.
Keep up the good work
W00dface is offline   Reply With Quote
Old 08-03-2009, 10:46 AM   #3902
just got it installed. thank you for the input, everything helps
im almost overhauling my whole suspension so im gonna document everything in my own thread WITH PICS!
Old 08-03-2009, 10:48 AM   #3903
i agree, my engine was running really rich and i found a vacuum line that was unplugged for god knows how long
havent messed with the injectors yet though
Old 08-03-2009, 11:01 AM   #3904
how many posts do you have to have before you can make your own thread??????
Old 08-03-2009, 11:10 AM   #3905
*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
page one
__________________
Old 08-03-2009, 11:17 AM   #3906
Quote:
Originally Posted by W00dface View Post
Howdy all.
Cheers.
nistune would be good for helping the mpgs, full control over ecu. but is it ok for VEs i think hadman has it, not to sure.
hho? never seen anyone try it here. im looking into it as well. we can swap notes if you want.
NGK spark plus will love you long time for mpgs
i would leave the timing alone for now.
check the vacuum lines and the normal stuff to ensure your engine is running well be for major tuning
good luck!
__________________
Old 08-03-2009, 11:53 AM   #3907
hello everyone! new to the maxima but i like it. i got the most beat *** 93 maxima se with a vg30de a 5spd and 208,xxx miles it ran good whaen i got it but now the vtc noise is almost constant at low rpms and it will run way harder when cold. i am going to rebuild the front vtc so the question is what do i need to buy besides the new return spring and is the special tool necesary? and does anyone have any ideas on it running better when cold, i have added a k&n airfilter advanced the timimng alitle removed the muffler and replaced it with a 3" tail pipe still has the stock cat and resonator i have a snap-on scanner and it is not pulling any codes, fixed all the broken vaccum lines i could find. oh and anyone ever have a problem with there clutch sticking to the flywheel on startup? lol i know this is alot of crap at once but thanks for any imput
the roach is offline   Reply With Quote
Old 08-03-2009, 01:20 PM   #3908
we were talking in class today about a car that started fine when cold but once it got hot it would be ****. the solution was a new starter.
what was happening is the starter had enough voltage built up to start the car, but once it got going it had no voltage left and the car died.
not sure if its the same, but every little bit helps
Old 08-03-2009, 02:57 PM   #3909
no the car still runs fine its more of a performance issue. you can even tell a differance reving it in nuteral it sounds differant and picks up rpms alitle slower. my idea was that the clatter from the vtc is throwing off the knock sensor? another thing i noticed was that the temp guage doesn't work, would the ecu use this sensor to adjust air fuel ratio for engine temp?
Old 08-03-2009, 09:32 PM   #3910
Quote:
Originally Posted by the roach View Post
no the car still runs fine its more of a performance issue. you can even tell a difference reeving it in neutral it sounds different and picks up Roms Little slower. my idea was that the clatter from the Tc is throwing off the knock sensor? another thing i noticed was that the temp Gage doesn't work, would the EC use this sensor to adjust air fuel ratio for engine temp?
Knock sensor only check for premature detonation. when they sense this the ECU will richen up the fuel mix and open the erg further to prevent damage.
__________________
Old 08-04-2009, 04:45 AM   #3911
Sure. Im along way off doing it seriously, just at the experimentation stage at the mo. I figured before doing it, I should get the car as light, tuned and running as smooth as poss. I have taken out the air con (never need that in the UK) and today will be relocating battery to the boot to make space in the front for HHO. Also want to clear up all the cabling etc.
good luck!
As it happens I do have a loose hose coming out of the plenum. It doesn't look like it was cut broke but it is pulling a vacuum. I can't for the life of me find out where it goes
Old 08-04-2009, 05:09 AM   #3912
Found where it goes
Old 08-04-2009, 07:01 AM   #3913
Something I have just noticed though is that one of the HT's are pretty knackered. Any recomendations for replacements?
Old 08-04-2009, 08:05 AM   #3914
i love my car i want to sleep in it !!!!!!!!!!!!!!!!!!!!!
Old 08-04-2009, 08:47 AM   #3915
:squint:
BenStoked's Avatar
please, phrase that in a form of a question...
and what do you mean, "one of the HT's are pretty knackered"?
(I get the 'knackered' part, I think, but HT?)
Old 08-04-2009, 09:03 AM   #3916
3rd gens are actually one of the comfiest maximas to nap in though
__________________
1992 GXE l 414,000km on original tranny and original VG30E l Pioneer Premier 12" 3500w subwoofer l 600w amp l JVC H/U l aftermarket fog lights l 2.5" Magnaflow catback exhaust l Momo summer rims l Stock winter rims l Sparco Sprint driver/passenger seat w/drivers 6 point harness l Sparco Volanti steering wheel l Castrol Syntec oil/premium Vpower gas
Future mods- 5spd swap, Z31 turbo w/intercooler
This winters mods- Z31 hood scoop, digital cluster swap, lowering springs
chrome91 is offline   Reply With Quote
Old 08-04-2009, 09:24 AM   #3917
i thought that the knock sensor retarded the timing advance when it sensed predetonation?
Old 08-04-2009, 09:29 AM   #3918
does anyone make a manual fuel pressure regulater that is a direct bolt on?
Old 08-04-2009, 11:10 AM   #3919
ok so i pulled the vaccum line to my fuel pressure regulator off and pugged it off and started the car right away i could tell that the car was running better so i took it for a spin it was alitle doggy on the bottom but i regained the 3500 rpm plus pull i was missing. so the qestion is, what would make my car lean out at normal operating temp? and remember the temp guage dosent work right, so could the sensor for the temp guage also tell the ecu what the engine temp is? to change from cold start enrichment? i am just rambling off random stuff here but let me know if any of you have ran into somthing like this.
Old 08-04-2009, 11:22 AM   #3920
:squint:
BenStoked's Avatar
there are two seperate temp sensors; one for the gauge, one for the ecu. you should check both for corrosion.
you may also have a bad injector. try pulling spark plug wires, one at a time. if the idle changes, then everything is fine. if it drops, check for spark. if spark is good, check injector, using a multimeter.
when was the last time a tune up was done (plugs, wires, cap, rotor, t-belt, air filter, oil change, etc.)?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
