3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
I guess it would have to be a GXE then, the car was bought for $2k and has had $4k dumped into it just to keep it running . it's not nice like a lot of the Maximas you guys have. Either way it's the climate control unit and having heat/ac I am concerned about.
heh yea i know the climate control is the bigger issue. i was just tryin' to make sure you were asking the right group of people. what you're describing sounds like an electrical malfunction within the unit itself... like from bad solder joints or something. do you know how to check and repair bad solder joints? usually when things like that fail (like the clock, or the door lock timer) it's bad solders.
__________________ PieceOut.FallToPeacesNew to the forum? CLICK HERE!!!! 1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress! 2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z 1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09 2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
I appreciate the help. I will pull it out again and take it apart to look. If it looks too bad I may just pick up a replacement rather than soldering (sp?) it myself. I really didn't want to buy a replacement to find it was not the issue. I'm going to go pull it and check.
i have been seeing very irregular idle and im wondering if its not a larger problem on its way i recently drained the transmission fluid other than that i haven't worked on the drivetrain recently at all
the car when stopped or with transmission in park will jump rpm's from 6-700 up to 900-1000 instantly u can hear the difference in the engine even see a lil more exhaust come out
the car operates perfectly otherwise no throttle problems while driving or anything irregular like that only other thing that might be related is that i get a lil vibration between 75-90mph then it goes away
__________________
Quote:
Originally Posted by Pearl93VE
That is the single most depressing post ever in the 3rd gen forum.
ibyouhaveavacleak, and maybe unbalanced wheels causing vibration on the highway
awesome finally i can add some color to the engine bay with some bright red vac hoses and your probably right about unbalanced wheels i know im due for alignment
__________________
one more thing anyone know how to replace the window master switch my chiltons manual basically told me to **** off
1: remove door panel
2: replace switch
3: reinstall door panel
there's a couple screws involved in there too. and the black gooey crap on the clear weathersheet. you might need to buy some extra black gooey crap. it was mentioned in greeny's taillight/OOOOOPS thread
2: replace switch
see i knew there was something like that why cant they just say "dont forget about the black gooey crap" in chiltons im sick of it im buyin fsm
__________________
well the black gooey crap shouldn't be a big issue for you.. moreso when replacing the window regulator. but just in case your weathersheet is loose, you may wish to reseal it with new gooey crap.
heres another one for ya the cigarette lighter which ive been using as a phone charger shorted out when i bought an actual cigarette lighter and it was the wrong size now the charger wont work and theres a lil burnt mark on the cigarette lighter but the adapter looks fine and still has its light glowing
what do i do rip out the whole dash and replace it?
the light glowing? like on the adapter? hmm try another adapter (i'm sure a friend/relative has a car charger you can test) and see if it works. but first, shine a light into the cig lighter socket and see if anything in there looks melted. if it looks fine then i guess go ahead and try a different charger. if you want to take out the black panel and replace the socket, i have a spare you can buy. installation is not terribly hard.. just takes a little muscle to push it into place, iirc.
I just upgraded my wheels from stock to 96-98 Cobra rims sitting on 235/45/17 rubber. My steering feels wobbly, like it over compensates and tends to pull to one side either left or right when i brake hard most of the time. I got an alignment after installing the wheels and had the inner tie rod ends replaced. I was wondering what can i do to correct this problem?
well it's possible that something was keeping the car from aliging right and the alignment place just said "you're good to go" when it really wasn't. try taking it somewhere that will do a free alignment check and ask for a full readout of the results. it will either tell you if those items are in-spec, OR you will be able to compare it to the FSM yourself.
how evenly are the tires wearing?
does this only happen when you break hard or does it pull while your driving as well if not it could be a defective brakes that would explain why the alignment didnt fix anything
__________________
well.. my car does that too though. new inner and outer tierods, new balljoints, new control arm bushings, new calipers, new rotors, and lightly used brake pads. and i greased the living hell out of the slidepins and stuff. but it still sometimes pulls one side or the other. mainly it does it over bumps, or on banked surfaces (like pulls to the left in the left lane cuz it's angled that way for drainage). i have a slight feathered edge on the outsides of my tires
really? i never noticed anything like that on mine arent u still runing original cv shafts?
__________________
no i have switched to a VE5 tranny so i'm using Goon's old CV axles (among other things). "anything like that' being when my car pulls toward the left in the left lane (and sometimes in other lanes... but sometimes to the right)? well that's cuz something is not right with my car.
I'm thinking that SOMETHING in my alignment wouldn't align right no matter what they did... and they just didn't bother to tell me. Originally i assumed it was the caster from me forgetting a washer behind the control arm bushings.... but that didn't fix it so now i'm thinking they either messed up the toe, or that my camber is wrong. that's why i was sugesting him to get a readout (as i have been to lazy to do ) and compare it to the acceptable range in the FSM. my what i said about my car was to show that there is nothing wrong with my brakes because everything is new except the master cylinder and brake lines.
It only happens when i break hard, the rear calipers are new.
rear brakes don't do much. you definitely DO need rear brakes but they only do like 20-30% of the work when you're hard on the brakes. the front ones would be much more likely to pull the car to one side, if the brakes are the problem.
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
96 Green A/T gone
Very quick question here. I have a 1990 Maxima SE that's rarely let me down before. I've had it for two years now and it's got 161,000 miles, runs great. However, it's now sitting in the Wal-Mart parking lot refusing to start. When I turn the key, my interior and exterior lights will come on and I hear a clicking noise, but the engine refuses to turn over. A friend tells me I need to test the battery, and if it's good, then it's a starter issue. If the battery is bad, then it could be an alternator or battery issue. Now, I trust him, but just need to get the battery tested...I will take it into Wal-Mart and test it there, but first,
-how do I remove the battery?
I found this website ( http://www.ehow.com/how_2191602_remove-car-battery.html ) that looks fairly trustworthy but I can't figure out the Maxy's 'grounding system type.' I checked through the whole manual but can't seem to find any indicators.
Help a sister out?
Help a sister out?
Very quick question here. I have a 1990 Maxima SE that's rarely let me down before. I've had it for two years now and it's got 161,000 miles, runs great. However, it's now sitting in the Wal-Mart parking lot refusing to start. When I turn the key, my interior and exterior lights will come on and I hear a clicking noise, but the engine refuses to turn over. A friend tells me I need to test the battery, and if it's good, then it's a starter issue. If the battery is bad, then it could be an alternator or battery issue. Now, I trust him, but just need to get the battery tested...I will take it into Wal-Mart and test it there, but first, [b]
Ground is not an issue just follow the directions that site tells you, the driver side terminal is the ground (Negative) side and the passenger side of the battery is the possitive.. But before you go pulling stuff outlook it over very well. Check the terminals realy well. does the positive side look like it has snow on it and if so the problem is the connection to the battery (clean it jiggle the wire and try and start the car). if its ok, get someone to help you jump the car before you pull the battery out. get a cheap'o volt meter and place it on the terminals (red for positive : black for negative ::ground: while the car is running. if you get a reading of over 14 volts the alternator is good anything under 12volts and the alternator is bad. turn off your car and reconnect the jump wires on the battery for 5 or 10 minutes while their car is running. use the meter again and if you get over 12v on the battery it might still be saved.
good luck!
__________________
1991 GXE Resurrected from the dead
1989 SE gutted for parts and 5 speed.
Help a sister out?
theres no such thing as a "positive" grounding system anymore thats just there for antique cars every car manufacturer has used a negative ground system since the 1940's
__________________
Word, good to know. Thanks everyone for your help. I got the battery out & tested it, and of course it was dead. Purchased a new one and got it installed successfully...Car wouldn't start until I put it in neutral and tried, but it is running now. I appreciate it.
i got a 92 maxima sohc with auto i was driving to salem it worked fine then on the way home it would not down shift nor did the overdrive or the performance or comfert switch work so i am thinking tranny controller any insight i am going to check the fluid levels now by the way it is snowing
SOHC? sounds like the tranny is starting to go into safe mode. my understanding (only this, because I have a manual transmission, and I don't pay too much attention to tranny problem threads) is this is because the auto is starting to die, or there is some sensor going bad. this is a frequent thing with the SOHC autos. a search should yield better answers than mine.
fluid levels are fine smells fine it just seems like the electronics are not working hwere is the controller located ? i could swap it out i have searched
ok i looked over the self diognostics but something that makes me think its the tcm is all forwaord gears can be selected and it will go forward reverse works it just wont downshift and the over drive or the power comfert switch will not work ..thi is the exact reasons i did not want a auto lol
don't just "look it over" you need to actually do the diagnostic procedures..
