3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
i am new and i have a question. i just bought a 1992 nissan maxima se, and there is a loud knocking, i have read about vtc now my question is if this is vtc probs where would the sound be coming from, also some times the engine cuts out, usually at lower rpms but until it stops doing it i cannot go any where
noise comes from top of engine(under valve covers), on the belt side.
other stuff, I will defer to someone with ve(30de) experience.
mmm, could be, but chains don't have a tendency to wear out(like a belt). I would suspect that if the chains are the noise problem, it would be the tensioner before the chains themselves.
i recently bought 4 DUB 2 way speakers at clearance prices. but the size is off. i have the stock bose system in there now. will 5.25 size speakers fit without modification?
no.
most people grab some plywood or mdf or some such board and make "adapter" plates.
worked so far for my 6.5's up front.
Ok, I'm posting this up here because I want a quick answer. I removed my power antenna, bought some antenna assembly from auto zone (a solid antenna, not another power one) but the antenna I have is too tall. A friend of mine gave me his s2000 antenna from his s2000, but I can't get it to fit on there. The screw is too short. Anyone have any ideas how how I would go about getting it connected? If pictures are needed to explain my set-up better, then I'll make a new thread. Thanks.
__________________
89 Maxima GXE
Mods: Rear Disc Conversion, Front Strut Tower Brace, Brembo's all around (Slotted Front), SE Tails - Hopefully more to come!
no.
hey my 6.5 that installed in the font did not need any mod except a bypass and I just screwed in the speakers to the stock speaker box and it worked perfectly
__________________
1993 SE / VE30DE / 114k / TK3 Sapphire Blue Pearl / MagnaFlow Cat / WarpSpeed Y /
FSTB / KYB GR-2 / Brembo Blanks / EBC Red Stuff / Poly Links / 30% Tints / 5000k HID Heads & Fogs /
Clear Corners / LED Interior
New in the fam- 2007 black on black Maxima SE
3000k Hid Fogs / Slotted RotorPros all around
alright i know there are tons of turbo write ups and discussions on the .org i've searched and read through a few of them and didnt find all the info i was looking for. so i went looking around on other forums and here's what i found http://forums.hybridz.org/showthread.php?t=104858 and here's my very simple and bold in a nutshell look at it. Z31's have the VG30ET, awesome engine, can run 300HP no problem with bolt ons. only major diff other than Z31's being RWD is that the engine is mounted 90* from that of a maixima. So using a modified Z31 manifold and some new tubing to adjust for the 90* placement issue and all the rest of the hard, finnicky custom expensive work. theoretically you can pump out just as much power as any Z31? that being if you have a VG30E in your max.
whats up, my name is kevin, i just got a 92 maxima from my friends dad for free because it has a miss. well he took the timing cover off to check that and it was fine, my question is how do i know what engine i have? there is two timing gears on top, one by each head, but the pics i seen of the dual cam look nothing like mine, i am lost lol.
easiest way to tell is if it has a distributor, its a sohc
you seem to think that a dohc means it has two cams, but it has four cams, two for each head. each cam has a corresponding gear. if you have one gear per head, its a sohc (vg30e). two gears/head, its a dohc(ve30de)
nice, thanks man, i was completely confused, i have the vg30e then, because i have one gear per head and a distrubitor. thanks again. any idea what would cause a miss? all plugs are perfectly clean and properly colored. i took the mass air off and gonna clean that and i guess the idle air im gonna clean too. but is there any real common problems? i am ruling out injectors for now only because no funny spark plug colors or anything
This is a vg30e (sohc) engine.
This is the VE30DE engine (this one is painted up nicely, but you get the picture so to speak lol)
the first pic is exactly what i have, thanks alot man, sweet car in the othe pics, i cant wait to get this thing cleaned up, its replacing my girls integra.
No problem
Btw, your missing issue is most likely a bad injector, to verify this, pull the injector harness plugs off each injector, then put on ohm meter on each terminal. A good injector will read between 11-14 ohms, usually a bad injector will read nothing or infinite(pegged out).
so does that mean my 5.25's would fit without any mod?
it sounds to me like you only got the antenna mast from your friend not the whole thing.
getting the whole thing would make it much easier since there is variation in the mast threading between cars.
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
i took out the old bose speaker and then drilled the new 6.5on the box to the hole as in puttin the speaker in front of the box and sticking the end threw the hole. just un screw everything on the back and remove the speaker and amp and do a rewire, then drill in the new one and your set, but there is a small gap at the dashboard end (the door panel) because of the new speaker sticks out alittle
__________________
Yeeep, all I got was the mast. The thread will fit, the problem is that the screw is too small length wise to fit. Would the whole antenna assembly even fit or work with our cars?
__________________
89 Maxima GXE
96 Green A/T gone
But it won't fit my budget; found a whole S2k antenna assembly for 90 bucks on ebay. I think I'm going to have to jerry rig this one. I know I said I would make a post yesterday, but things got complicated. I'll get pics today and make a new thread.
__________________
89 Maxima GXE
I am planning on buying an ebay Knock Sensor for my car, but I have a question.
The only one I found that specifically stated that it was for a '90 Max looked different than the rest of them. I just want to make sure I get the right part.
Are the KS's from the 90's different than the later year parts? Is this the wrong part?
^^This is the pic for the part listed as a '90
^^This is for 92+
Just want this sorted out before I drop the cash. Thanks in advance.
^^This is for 92+
It's not that they are different from year models, it's that they are different from engine types..The first picture is for the vg30e engine, which is in all 89-91 3rd gen maximas, SE or GXE models. The second picture is the k/s for the 92-94 VE30DE dual overhead cam engine, this engine is only in the 92-94 SE maximas, the gxe maxima continued on with the vg30e engine through to 94. So if you have a 90 model maxima, the first picture is the right k/s sensor. you have a 90 model right?
Yes, it's a 90. It's definitely the SOHC engine. So that first sensor is the correct one then, yes?
hi, i have a 90 nissan maxima timing belt just broke, motor is garbage. picked up a motor from a junkyard and wanted to go through it and get it ready for a turbo. was looking for head bolts, head gasket, fuel injectors. does anyone know of performance stuff?? also, was looking for a cheap clutch that will work good. anyone have anything in mind
If you wanna turbo your vg try and find some Z parts in the 'yard like the manifold and as for clutches+kits there's tons out there just give a search
96 Green A/T gone
So I've been driving my car around with no speedometer for like a month now. I looked at this picture: http://i164.photobucket.com/albums/u...r/IMG_0013.jpg and there are two wires coming from the black thing, one is loose, one is attached to it. I'm not so sure what I'm supposed to do, the loose wire ran to this sensor looking thing, and everything was plugged in, the other part I dont know where because I would have to get under the car.
Can anyone tell me specifically, what I should be looking for??
