Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-08-2008, 01:19 PM   #1801
Spankin new here need help with 92 VE ignition problem..
Well as the title says I am a newbie, I have been having some trouble with my car for a while now. I have just had the engine replaced after the previous on had a freak oil leak and locked up on me. But, now I am having problems with my ignition system. At first when I had just picked my car up it idled a little rough and did not accelerate so well (couldn't floor it, had no effect really). So, I returned it to the dealer and they temporarily fixed it, everything was great for like 2 wks. Then I was out for a little drive on my lunch and it just started acting up again, so I took it back to the dealer. This time they said it was an ignition coil that was bad and they charged me $140 to replace one coil (I was upset about this b/c later I found one online for $40). But as soon as I cranked the car it was exactly the same so I decided to try and do some work myself because after the engine im a little broke. Well the coil they replaced was on my #3 cylinder which I checked and was fine, but 5 was'nt firing so i switched some of the coil packs around to see if it was the coil but that cylinder still wasn't firing. Then eventually #3 and #5 both stopped firing. And it progressively got worse now the car cranks fine but stalls out immediately. My ECU is now showing a code 21 (2 long 1 short if im right), my hanes manul reads:
Cause: The ignition signal in the primary circuit is not entered during engine cranking or running. This repair must be performed by a dealer service department.
FAT CHANCE! I've done some other web searching and found I may have to replace the wiring harness or PTU. Does anyone know anything regarding my situation? I really need this car working asap, I have no idea how to test to see which one is malfunctioning. I am no mechanic anything I know about auto's has been learned in the last few months with this car so PLEASE HELP! Also I am sorry for the long post just tried to include as much info as possible about what has been done, thank you.
dmklime is offline   Reply With Quote
Old 09-08-2008, 05:54 PM   #1802
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
have you checked your spark plugs?
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 09-08-2008, 05:55 PM   #1803
buy a car from him?
Quote:
Originally Posted by Born83 View Post
Hello. I own a 93 GXE max and i'm having electrical problems. My cigarette ligter, radio, electronic entry keypad, and clock are all out. The seatbelt only retracts in ACC and the airbag light is on. I removed the lower steering wheel panel, checked the fuses, but found nothing wrong. Perhaps I'm not checking good enough. Any help is appreciated. thanks.
look at your underhood fusible links
__________________
96 Green A/T gone
Old 09-08-2008, 07:12 PM   #1804
I drive a '94 gxe also...garage kepted ...no rust that i know of. However i commute daily at freeway speeds 75 plus. And once in a while i will hear something like knock (like a rock) hitting the bottom of the chasis.....now ya got me wondering if this could be a worn bushing somewhere???
85k on the speedo...
Starrider is offline   Reply With Quote
Old 09-09-2008, 11:59 AM   #1805
Quote:
I just did that and discovered that the radiator fans aren't working either. Could a blown 45A radiator fuse (indicated on the fusebox cover) be the cause of all my problems?
Born83 is offline   Reply With Quote
Old 09-09-2008, 09:35 PM   #1806
buy a car from him?
my rule of thumb, fix what you see as bad even if it appears to be unrelated.
__________________
96 Green A/T gone
Old 09-10-2008, 06:18 AM   #1807
Yes i have changed the spark plugs already spankin' new...anyoneknow where i can get instructions on how to remove the rear manifold to check those injectors? Or is it really that complicated, total n00b here who doesn't want to kill his car :S ty
Old 09-10-2008, 08:15 AM   #1808
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
i thought that code's description would indicate the CAS??? or is that another different code? like, that the ECU is not reading any RPM or reading what position in the firing cycle the cams are at.... thus not attempting to fire injectors or spark or something like that.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 09-10-2008, 02:30 PM   #1809
put the new timing belt and tensioner in.
tried to start it before putting everything back on.
and it started right up. put cover, belts, etc back on.
now its running sluggish and doesnt respond quickly to the gas pedal.
it will rev when its in P. but when i put it in D it doesnt want to move or respond at all.
changed out the tps and nothing.
checked all the vaccumm lines and everything seems dandy.
any ideas? im broke so a new engine is outta the question.
my 240 was much easier to work on. lol.
oldspice is offline   Reply With Quote
Old 09-10-2008, 06:04 PM   #1810
:squint:
BenStoked's Avatar
Send a message via AIM to BenStoked
you may wanna pull the covers back off, and check to make sure the belt didn't somehow jump a tooth, and the tensioner is properly torqued (adjusted, whatever)
also, go through, and check to see if any wires were disconnected(or damaged) in the process.
BenStoked is offline   Reply With Quote
Old 09-10-2008, 06:25 PM   #1811
Also on the VE engine i found a wire that was completely severed that connects to the block near the EGC valve is that for the vacuum or what? Either way i spliced that and no it will crank and idle but only around 300-400 rpm's and Cyl 3&5 still no combustion.
Old 09-10-2008, 08:47 PM   #1812
my tranny has been acting a little weird the past 2 days. the other day it didnt want to shift out of gear like there was no 1 and 2nd gear then that very night and the following day it was ok. so i planned on replacing the tranny filter but cant seem to find the pan or plug for it on this nissan. anyone know the location of this pan?
__________________
VG 5speed for sell, only needs a clutch. Email dxcape69@yahoo.com for info and pics
MaxZap is offline   Reply With Quote
Old 09-10-2008, 09:19 PM   #1813
buy a car from him?
Quote:
there isn't a filter or pan.
it's just drain and fill.
__________________
96 Green A/T gone
Old 09-11-2008, 04:10 PM   #1814
Popcorn
Alright, got a new battery, car worked fine for two or three days and now, all the electrical system turned off (deck, headlights, backligthing for gauges) but my battery light did not come on or any other light except the airbag. When i give it some gas the engine makes popping sounds, goes about 30 feet and then the car dies completely. Taking it in to the dealer or a shop today, jsut curious what you guys think it is.
Garf is offline   Reply With Quote
Old 09-11-2008, 04:56 PM   #1815
hello i try to bypass the front speaker bose with only using the 2 small wires which are green and a black one, i can only hear a small amount of sound coming from until i turn then up very loud. i have an aftermarket h/u and i dont want to change out the rear bose cause its has some nice bass and its still working, so the question is why is it so low in sound what am i doing wrong i tried all the combinations too
__________________
1993 SE / VE30DE / 114k / TK3 Sapphire Blue Pearl / MagnaFlow Cat / WarpSpeed Y /
FSTB / KYB GR-2 / Brembo Blanks / EBC Red Stuff / Poly Links / 30% Tints / 5000k HID Heads & Fogs /
Clear Corners / LED Interior
New in the fam- 2007 black on black Maxima SE
3000k Hid Fogs / Slotted RotorPros all around
coolsun is offline   Reply With Quote
Old 09-11-2008, 06:40 PM   #1816
buy a car from him?
Quote:
the bose speakers are 1ohm speakers rather than the standard of 4ohms.
when the amps are used they are amplifying what is basically a line-level signal.
Swap out the front bose speakers for some regular speakers, it's the best thing to do with an aftermarket H/U
__________________
96 Green A/T gone
Old 09-11-2008, 07:13 PM   #1817
i did im trying to put some 4 ohm pioneers in
__________________
Old 09-11-2008, 08:56 PM   #1818
:squint:
BenStoked's Avatar
are these the ones you are having problems with?
if so, just bypass the stock wiring, and run new speaker wire to the speakers.
are you using the line out on the hu for the rears?
Old 09-11-2008, 10:08 PM   #1819
im not too sure of my h/u setup cause i got it done at bestbuy and the previous owner had another h/u in it which broke n i had to get it done, the bestbuy guy said it was a mess and he re organized the wires, i saw its now nice n neat, its my font speakers i have very low sound on it and when i plug it in it make a pop first and then i turn up the volume n i can hear its on. i pluged wires directly to the h/u and same results. i really want all my speakers to work i dont want to feel like i have a deaf right ear lmao thanks alot im a real noob in stero systems
__________________
Old 09-12-2008, 02:25 PM   #1820
so can anyone help me with the wiring colors and maybe why its very low and make a pop when it turns on
__________________
Old 09-12-2008, 04:24 PM   #1821
buy a car from him?
your pop is because their is probably an aftermarket amp wired into your system somewhere and it lacks a soft turn on feature.
the sound is low because the system is mismatched. Replace all the speakers with aftermarket and bypass all the amps and you will get good sound.
__________________
96 Green A/T gone
Old 09-12-2008, 08:46 PM   #1822
is it ok to leave the rears? i like the bose thumps
__________________
Old 09-13-2008, 04:27 AM   #1823
:squint:
BenStoked's Avatar
it depends on how you have it wired up. regardless, like brian said, it will be mismatched. and you may be surprised on how some 6x9s hit, too.
Old 09-13-2008, 09:55 AM   #1824
ok thanks for all you peoples help I will get to it this weekened
__________________
Old 09-13-2008, 06:18 PM   #1825
Quote:
Originally Posted by destroy452 View Post
Hi everyone. I have an engine problem on my 93 SE 5 speed. My wife drove the Max about 75 miles from the house and in died on her. I went and changed the Air Bypass hose on the intake manifold and it ran a little better. But when I started down the road, it ran smooth, but lacked power. Other symptoms include:
1: wouldn't idle. when I got near home, if I let off of the go pedal, it would go dead.
2: ran great in the upper rpm range (3000 plus) but weak in the lower.
3: No check engine light.
It felt like it bucked and choked and wouldn't go.
I'm going to check the plugs, change the fuel filter, and go through the diagnostic procedures according the the Factory Service Manual.
I'm thinking throttle position sensor, fuel pump, or ecu. PLEASE, any help would be greatly appreciated.
Scott.
Found out it was a clogged up catalytic converter. Took it off, knocked all the stuff out of it, and it has run fine since. Got to put a new flex pipe/straight pipe with O2 bung on it. In AL, we don't have smog checks. Thankfully
destroy452 is offline   Reply With Quote
Old 09-13-2008, 07:44 PM   #1826
buy a car from him?
your thump has a large amount to do with your H/U.
I've played around with different H/Us with the same speakers and the H/U makes all the difference in the thump.
__________________
96 Green A/T gone
Old 09-13-2008, 07:49 PM   #1827
:squint:
BenStoked's Avatar
rms, eq, or just simply quality?
Old 09-13-2008, 07:50 PM   #1828
buy a car from him?
Quantity.
the Bass hit harder on some H/Us than others.
of course I've seen many a OE H/U hit very hard.
__________________
96 Green A/T gone
Old 09-13-2008, 09:59 PM   #1829
Quantity.
i dont have a problem with the rear amps now but is it going to sound the same if i have the amp off , what difference would it make
__________________
Old 09-14-2008, 06:51 AM   #1830
:squint:
BenStoked's Avatar
if the bose amps are disconnected, you wont hear anything, unless the installers fubar'd something.
Old 09-14-2008, 07:49 AM   #1831
buy a car from him?
they could have been bypassed.
__________________
96 Green A/T gone
Old 09-14-2008, 04:33 PM   #1832
:squint:
BenStoked's Avatar
and i consider that fubar'd
Old 09-14-2008, 05:31 PM   #1833
buy a car from him?
I consider that a good thing
__________________
96 Green A/T gone
Old 09-14-2008, 05:41 PM   #1834
:squint:
BenStoked's Avatar
we are both talking about the bose amp AND speakers, right?
Old 09-15-2008, 12:03 AM   #1835
Quick question regarding rear 6 x9 speakers on 90 max se
hello,
i recently purchased blaupunkt speakers for the rear and a sony 420ip deck. i decided to pass on replacing the front speakers because im on a budget for this car.
anyways, i bought my stuff from crutchfield and they told me that i might not be able to replace the factory speaker covers for the rear speakers..
i was wondering if there is any way i can do that because i really like the blaupunkt speaker covers and it will really stand out.
any help is appreciated. thanks.
- kobedaman24
kobedaman24 is offline   Reply With Quote
Old 09-15-2008, 08:27 AM   #1836
:squint:
BenStoked's Avatar
Quote:
Originally Posted by kobedaman24 View Post
hello,
- kobmedaman24
you can do anything you set your mind to. here is some food for thought: the hole for the speakers isn't 6x9, so you wouldn't see the whole speaker, unless you cut the rear deck to fit it in.
the speaker grilles are attached to the rear deck cover. you could remove them, but I cannot be sure the blaupunkt covers will fit as replacements. you could go to the hardware store and buy some 1/8th plywood, swing by a car audio shop pick up some box carpet, and make a new deck cover to fit in place on the deck, with the speaker covers.
Old 09-15-2008, 10:43 AM   #1837
Send a message via AIM to kcidmil
The Bose Speaker/Amp setup that came in the 3rd gen Max was one of the worst setups I've heard to date for a stock stereo. Even my 88 Camaro with stock speakers and H/U sounds better. I'm with Brian on this one. A Bose Amp bypass is an improvement.
__________________
Fight back this year, do your tax return with Roman Numerals
Maxima Site
REBUILD STARTS THIS APRIL, AND THE BORE OVER WAS APPROVED AS SOON AS I FINISH THE "HONEY-DO" LIST
kcidmil is offline   Reply With Quote
Old 09-15-2008, 12:44 PM   #1838
:squint:
BenStoked's Avatar
Quote:
my meaning was that bypassing the amp to go to the bose speaker is not a good idea. if it is bypassed to aftermarket speakers, the everything is okay.
Old 09-15-2008, 02:23 PM   #1839
ohhhhh.... Well that now makes more sense.
__________________
Maxima Site
Old 09-16-2008, 12:09 PM   #1840
Suspension
I can't post new threads yet so ill ask in here: KYB GR2's w/ Ksport Lowering springs. Decent or bad idea?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
