Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-24-2008, 06:43 AM   #1561
My new exhaust that i made from scratch, been on for almost a week and its been great, i lost some low end torque (doesn't feel like a civic at least) but nothing that wont be fix later on with a set of JWT cams and other goodies. the pipe is 2 1/4 to the flex then it gets bumped up to 2 1/2 for the magniflow 50 state cat. bonus is i passed state inspection beter than i did the last time.
__________________
1991 GXE Resurrected from the dead
1989 SE gutted for parts and 5 speed.
300zmax is offline   Reply With Quote
Old 07-24-2008, 08:28 AM   #1562
Not a fan of the color but this y pipe does look like it would weight less than the warpspeed though I can't really see the area where the rear manifold is but it kinda looks like it exits at a bad angle.
3g94MaxGXE is offline   Reply With Quote
Old 07-24-2008, 08:36 AM   #1563
Quote:
probly not the best angle, its alot light than the OEM, i will put up more picks later.
__________________
Old 07-24-2008, 08:55 AM   #1564
What's it made out of?
Old 07-24-2008, 09:06 AM   #1565
mostly mild steel, the flex and the cat are stainless.
__________________
Old 07-24-2008, 09:45 AM   #1566
bummer, if it was all stainless I'd probably be begging you to make another one within the year.
Old 07-24-2008, 10:02 AM   #1567
i can do stainless its just hella expencive, this cost me $150 to $180 for material, flex and cat. half the price of stainless. summitracing.com is my suplier
__________________
Old 07-24-2008, 10:29 AM   #1568
I agree. warpspeed I believe sells the Y (no cat) in stainless for $265 and the regular for $200. However they don't seem to have the stainless one on their ebay which would make payment easier on me. If I could find someone who could make a stainless one that looks (and possibly performs) better for less it would be nice. Mufflers are cheaper per inch than these y pipes are.
Old 07-24-2008, 01:41 PM   #1569
how do y-pipes effect low end torque it seems their only purpose would be to releive backpressure which would cause a general increase in power across the powerband?
sleepyvg30e is offline   Reply With Quote
Old 07-24-2008, 01:48 PM   #1570
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
it's got to do with airspeed velocity and the amount of air that the exhaust puts out at different RPMs
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is online now   Reply With Quote
Old 07-24-2008, 03:10 PM   #1571
turbulence?
Old 07-24-2008, 03:14 PM   #1572
turbulence?
that's why we use wsp pipes... to avoid that. dunno so much about it as far as when it's most present, etc.
__________________
Old 07-25-2008, 07:30 AM   #1573
one thing that happens is that as the exhaust flows threw the pipes it causes a vacuum in the pipes that helps to pull airinto the cylinder heads (called scavenging) while the intake and exhaust valves are open at the same time. this is the effect equal length headers have on an engine as well as matching the flow as evenly aspossible from cylinder to cylinder. to much scavenging can be bad
__________________
Old 07-25-2008, 07:27 PM   #1574
kthxbye2u
xx-Marshall-xx's Avatar
Send a message via AIM to xx-Marshall-xx
Quote:
Originally Posted by capedcadaver View Post
is there oil in your crankcase vent system that maybe is entering the intake plenum thing? i dunno the configuration of a VE too well but gravity and airflow *could* be sucking oil into your clylinders IF you have an exorbitant amount coming in through your blowby hose or something. any blue smoke? and you checked all 6 plugs right?
Im re-stating my problem again
Cyl 2 and 5 are NOT firing.
-Coils are good
-plugs are good (they are dry and do not smell like gas) which could mean that the injectors are not working
-swapped power transistor
-looked at relay, didnt test it (dont know how, i will real the FSM later)
i dont know what else to check
__________________
SHIFT_chirp
*Butt Mods- NWP Full Spacer Kit - Ported TB - Port Matched Intake Manifolds - HAI - Spec Stage 1 HD Clutch - Advanced Timing 18° - WSP Y-pipe
*Eye mods- Rims - Stillen Front lip - E36 Retro fit - Full Amber Smoked CC
xx-Marshall-xx is offline   Reply With Quote
Old 07-25-2008, 08:28 PM   #1575
Quote:
so couldnt i just adjust the timing after the exhaust is put on or just install new cams?
__________________
Quote:
Originally Posted by Pearl93VE View Post
That is the single most depressing post ever in the 3rd gen forum.
Old 07-25-2008, 08:31 PM   #1576
also cant find any oem headers anywhere i can find the rear manifold but not anything else except aftermarket can somebody tell me where i can find this part cuase mine are cracked through
Old 07-25-2008, 09:32 PM   #1577
scavenging is good when the cam is timed right either stock or a little advanced. it helps draw fresh air in the engine. you would need to adjust the cam timing to get the most out of it. with my mustang it helped alot with the cam being advanced a few degrees and the long tube headers. max oem manifolds flow pretty well accualy. you can get pacesetters but i dont like them personal opinion
__________________
Old 07-25-2008, 09:42 PM   #1578
http://www.autopartswarehouse.com/se...=1991%20Nissan
maxima headers, well some of them i think.
__________________
Old 07-25-2008, 10:08 PM   #1579
so if i get stock headers and an aftermarket y-pipe should i advance 2-3 degrees or higher
no this sites only got pacesetter and they got a bad deal on them too
__________________
Old 07-25-2008, 10:59 PM   #1580
-Coils are good
when you said the plugs ad oil on them i figured maybe they had enough on them to actually cause the misfire. which is why i said that.
did you hook a multimeter up to the injector plugs in question (harness side) and look at voltage while motor is running? can't use a test light (will kill ecu) but multimeter in 20vdc mode is ok to use.
__________________
Old 07-27-2008, 12:47 AM   #1581
what is this cable
http://i47.photobucket.com/albums/f1...g_01/Cable.jpg
My car 92 VE has rough idle, i found this cable hanging below the airbox. where is this cable connected to?
Entong is offline   Reply With Quote
Old 07-27-2008, 01:22 AM   #1582
that's eerily similar of a picture i took of my car... i have the same red/black strap on my tranny jack. is that a pic of your car for serious? weeeeird if it is. my car is even the same color as yours haha.
anyhow that's the transmission ground wire.
__________________
Old 07-27-2008, 02:10 AM   #1583
Yes, that is your car's pic, I was searching for my car's rough idle when i saw your post(pic). same cable as mine. I can't take a clear picture of mine so i borrowed yours if you don't mind.
Thank you,
Old 07-27-2008, 02:24 AM   #1584
Thank you,
oh it's fine i was just like whaaaaat if by chance you had the same color car and the same style of tranny jack as i do. there should be a clip on the tranny that that clips into, and it should have a loom at the other end bolted onto one of the tranny mounts or something... depends if a/t or m/t as to where exactly it bolts in.
__________________
Old 07-27-2008, 12:36 PM   #1585
92 headlight problem
My right headlight does not want to work. The bulb is fine because it works on the left side. The cable also gets electricity. Im guessing that it does not get enough electricity. Sometimes i turn it on and it works. The connectors are all clean.
GUS'MAXIMA is offline   Reply With Quote
Old 07-27-2008, 01:00 PM   #1586
92 shaking problem
My car begins to shake uncontrolably when i put it into drive. It is worse when i stop at a light and stay at an idle. Once i pass 30 it goes away. What can it be. When in park or nuetral it does not shake. sometimes it hesitates.
__________________
BLACK 1992 NISSAN MAXIMA SE
Old 07-27-2008, 01:04 PM   #1587
:squint:
BenStoked's Avatar
Send a message via AIM to BenStoked
Quote:
usually the problem is the switch. you can get another at the junk yard, and hope it works, get a new one at the dealer, and cry about how much more empty your wallet is, or try to clean the contacts in your current switch and hope you get everything back together good, and it at least works. a few of us have done this, and been okay, while others were forced down another path...
removing the switch isnt hard, just remove the plastic pieces around the steering column, and there are a couple of screws holding the switch in place after that.
BenStoked is offline   Reply With Quote
Old 07-27-2008, 02:18 PM   #1588
just wondering should i relplace a broken antenna mast or get one of those in glass antennas on ebay? (because i cant find them in stores) thanks
__________________
1993 SE / VE30DE / 114k / TK3 Sapphire Blue Pearl / MagnaFlow Cat / WarpSpeed Y /
FSTB / KYB GR-2 / Brembo Blanks / EBC Red Stuff / Poly Links / 30% Tints / 5000k HID Heads & Fogs /
Clear Corners / LED Interior
New in the fam- 2007 black on black Maxima SE
3000k Hid Fogs / Slotted RotorPros all around
coolsun is offline   Reply With Quote
Old 07-27-2008, 02:22 PM   #1589
Sounds like you've got a misfire to me.
Old 07-27-2008, 02:40 PM   #1590
Quote:
I think it would look neater and sleaker if you replace the broken antenna mast. you can probably get one at the junkyard. there are some antennas with the motor and different rings on ebay as well for 20.00.
__________________
Old 07-27-2008, 05:55 PM   #1591
i cant seem to see ot find the mast on ebay anymore for our 3rd gen but the new ones with the motor are $20 but shipping is another $12 so is there any other places for cheap thanks
__________________
Old 07-27-2008, 08:38 PM   #1592
Does anyone happen to know what color dot the #3 (near the firewall, middle injector) fuel injector has on a '94 VG?
I'd look at the clip that has the dot but that was broken off.
The plastic is seized together where the wiring harness connects, so I can't really check the other injectors to find out.
YearOfTheGus is offline   Reply With Quote
Old 07-27-2008, 08:53 PM   #1593
Thanks for the help. That was exactly what was wrong with it.What i did was remove the big plastic piece ontop of the pedals and the plastic around the steering wheel. Then i removed the two screwes and it came out. I seperated the clear part from the black to clean it better. I cut little peices of sandpaper very fine grade and sanded the bottom of the contacts and the top. The clearence of the pieces were almost all the same. Then i put it all back together and it worked perfectly. thanks
__________________
Old 07-27-2008, 09:16 PM   #1594
I guess if you want to stick with the original antenna you should go to a junkyard where you can get the antenna mast instead of the whole system. You will defenetly get a better deal. I saw some fin like antennas that come with the new BMWs on ebay that look cool but i dought they will work on our 3rd gen maximas.
__________________
Old 07-30-2008, 05:17 PM   #1595
Big Problem! Throttle body hose nipple broken!
OK I have a 1989 Nissan Maxima 3.0L SOHC heres my problem, I went to check my oil and noticed coolant all over the the place. Traced the leak to a loose hose and when I went to tighten the hose the nipple the hose slid on to broke off. I have the FSM but I cant find what the hell this hose is exactly. Here are some pics. Any suggestions ? Any type of like hammer on replacement or am I going to be installing a new throttle body kit? Here are some pics:
ajan246 is offline   Reply With Quote
Old 07-30-2008, 06:44 PM   #1596
It's either time for a new TB or you could have the old nipple welded back on. As far as where the hose is there is a big wad of them right in front of the IACV and it should be an easy find if you just look. I'll see if I can find a pic of the one you are looking for.
Didn't find a good pic but look where the red circle is, the hose should run along in that area. If you have to you can remove the dual duct to check for it.
Old 07-30-2008, 07:05 PM   #1597
hey thanks for the quick reply. I found the hose no problems do you know what it is? I have no clue what the purpose of the hose is... its carrying coolant but for what I'm not sure.
Old 07-30-2008, 07:18 PM   #1598
I'm sorry don't really know much about this stuff. I was only able to help you because I pulled off my throttle body this week and had to disconnect it. Good to know I'm picking up at least a little useful info along the way.
Old 07-30-2008, 07:27 PM   #1599
How difficult is it? Pretty straight forward? unbolt and bolt back on?
Old 07-30-2008, 07:34 PM   #1600
Quote:
it's to heat up the throttle plates quicker so your throttle won't stick in cold cold weather. that way as your car warms up, the throttle will warm up with it, and be nice and smooth when you start driving it. doesn't matter nearly as much, if at all, in the summer. i have mine bypassed. you can bypass yours, or i've got a spare TB you can buy.
__________________
Last edited by CapedCadaver; 07-30-2008 at 07:43 PM. Reason: forgot to quote! forgot this was teh n00b thread!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
