Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-20-2008, 04:47 AM   #1521
Quote:
Originally Posted by kobedaman24 View Post
just when i was making plans to do some mods to my car, it doesn't start. this car has had previous problems of not starting up and it seems to be happening again. im not sure if its a problem with the battery because the lights seem to turn on when i open a door, but the car won't start. previous times when it had done this, it was because i accidentally left the headlights on for about an hour, and the car wouldn't start and needed a jump. this time i was dusting the dashboard and cleaning the back with the door open, meaning the light was on for the door. i cleaned the car and was getting ready to go to kragen and the car wouldn't start.
when i attempt to start the car a bunch of lights turn on on the dash. the battery icon being one of them.
anybody know what i can do to solve this problem?
p.s the battery is rougly 2 years old. do you think i probably need a new battery? (this is what i thought the problem was, but i thought i'd get some professional help)
p.s.s i also think my car has a transmission problem because sometimes when it didn't start my dad used to hold the little overdrive button on the front of the shifter and move it to drive then to park. then it would start. i tried this and it didn't happen.. oh yeah and another transmission problem this car has is with a direct shift to "drive" gear. sometimes when i switch to D, it doesnt move, so i need to switch to 2, then D. my friend says i need to change the transmission fluid. do you think this will fix the problem?
this is probably the third time this has happened.. im having thoughts of selling the car if i cant get these things fixed with a low budget.
thanks for all your help
you definetly need to get your fluid checked but its not a serious problem for now if you dont know how long it has been since your fluid was changed then i would recomend a rebuild or 5spd swap like im workin on but basically all you need too do to start your car is sorta punch the shifter as far as it will go into park (try taking out shift lock brong it all the way down then back up again) if you cant even get the key to go all the way on then you need to shake the steering wheel side to side a lil to disengage some safety feauture. and i still bring the shifter all the way down to 2nd before D or else it will slip into nuetral
wait till it goes into fail safe mode atleast once before doing a whole rebuild or swap
__________________
Quote:
Originally Posted by Pearl93VE View Post
That is the single most depressing post ever in the 3rd gen forum.
sleepyvg30e is offline   Reply With Quote
Old 07-20-2008, 11:15 AM   #1522
WTB: Used working IACV for 91 Maxima
I want to try and replace the IACV but dont want to blow $115 bucks either. If anyone has this part laying I need a cheap but working one. Please post this in the classifieds if possible.
thanks
Nick
lennyseleven is offline   Reply With Quote
Old 07-20-2008, 03:51 PM   #1523
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
thanks
Nick
just go to the classifieds and look around at a few part-out posts. all 89-91 have your engine, and all GXE regardless of year (well, as long as it's a 3rd gen, of course) have your engine. if it's a 92SE, 93SE, or 94SE being parted out, don't even look in there because they have a totally different engine.
ctrl+f and see if IACV is mentioned in the post. if not, post and say "is the IACV still available" and go form there.
tho i think i have one that will fit your car... but it came off an engine with a broken timing belt so i can confirm that it works though.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 07-20-2008, 03:59 PM   #1524
ATF type?
ok i have a 93 se with a ve30 in it and i am wondering what kind of atf we are suposed to use. on autozone.com's manual thing it says dexronIII is that true? and i know that synthetic fluid is the best to use so is dexronVI ok to use?
93maximaguy is offline   Reply With Quote
Old 07-20-2008, 04:32 PM   #1525
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
Dexron VI is NOT ok to use.
Dexron IV is ok to use, just be sure that it is synthetic for longest trans life.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 07-20-2008, 04:42 PM   #1526
why isnt it ok to use? just to know?
Old 07-20-2008, 04:43 PM   #1527
buy a car from him?
it has different specs to it.
DEXRON VI is only to be used in vehicles specifying it, it is not backwards compatible.
__________________
96 Green A/T gone
Old 07-20-2008, 04:50 PM   #1528
wow that sucks the big one cause i just bought 6 quarts for $38
EDIT also it says on the bottle that it can be used where Dexron II/III are used
Old 07-20-2008, 04:54 PM   #1529
buy a car from him?
Quote:
why would you buy something without knowing if it works?
__________________
96 Green A/T gone
Old 07-20-2008, 04:57 PM   #1530
because it says on the bottle that it will work in dexronII/III aplications
EDIT it also say on multiple sites that it will work in earlyer versions of dexron fluid transmissions and im just trying to see if its true
Old 07-20-2008, 05:13 PM   #1531
buy a car from him?
when i last read the bottle i thought it said to the contrary.
maybe it was a different brand or my memory failing me
__________________
96 Green A/T gone
Old 07-20-2008, 05:17 PM   #1532
sorry hit post twice my reply is below
Old 07-20-2008, 05:17 PM   #1533
sorry i probly came off as a dipstick but i will post a link to valvoline's site and tell me what u think?
http://www.valvoline.com/pages/produ...sp?product=129
Old 07-20-2008, 05:39 PM   #1534
buy a car from him?
guess i remembered wrong
__________________
96 Green A/T gone
Old 07-20-2008, 05:40 PM   #1535
so do you think its ok to use?
Old 07-20-2008, 05:45 PM   #1536
buy a car from him?
if they are saying it is then they are responsible if it causes a failure.
__________________
96 Green A/T gone
Old 07-20-2008, 05:56 PM   #1537
so if it screws my trans then they have to pay for a new one correct?
edit well im realy nervous about doing this now but i am going to try it
Old 07-20-2008, 07:33 PM   #1538
Send a message via Yahoo to 94se5spd
Random
I drive a 92 SE 5spd (Im sure as any veteran on here knows it has a VE) It has random spells when it noses over like you've shut the key off while your accelerating. The tach will also drop straight to zero instantaneously when it does this. Then within a few seconds it will take back off and the tach will jump back up where it is suppose to be. I dont know what it would be. Do any of you all know what it is?
__________________
1992 Maxima SE 5spd
NGK V-Power's gapped to .050
Timing advanced 4*
93 Octane
94se5spd is offline   Reply With Quote
Old 07-20-2008, 07:56 PM   #1539
:squint:
BenStoked's Avatar
Send a message via AIM to BenStoked
Quote:
sounds like the engine is stalling. do you ever push the clutch, and it just magically resumes normal operation while still disengaged?
BenStoked is offline   Reply With Quote
Old 07-20-2008, 08:42 PM   #1540
does climate control die too when this happens, and turnsignals, etc? basically i'm asking if everything that is part of the IGN-ON circuit is dying, or JUST the motor. if the motor lost, say, spark or fuel for a brief moment the tach should stay up if you're in gear. but it seems to me that if the tach is dying then your entire IGN-ON circuit is shutting off for some reason. which might be a dying relay. or it could be that your CAS has an intermittent connection issue. does CEL EVER come on when the engine stalls out like that?
my friend has a probe that randomly shuts the injectors off, but the ignition relay is fine... it may be the engine cont relay on his car or something. but his CEL never comes on b/c the engine is still rotating and the tach on his never drops. we have not solved his problem, but it's slightly different from yours. so i'd start with swapping in a new (or known good) ignition relay.
__________________
Old 07-21-2008, 02:32 AM   #1541
thanks a lot for the help, it started! would you or anyone else happen to know how much it would cost me to get the transmission fluid checked/changed, or can i do it myself (if i can do it myself, how much will the cost be?)
thanks
kobedaman24 is offline   Reply With Quote
Old 07-21-2008, 11:15 AM   #1542
thanks
do not do it yourself
unless you know for sure the owner changed the fluid everytime he was supposed too since the car was made, these old cars for some complicated reason cant be flushed if u go too long without doing the flush the tranny will break down and you will have to buy a new one most mechanics are gonna have you sign a waiver saying basically if your car breaks from doing a tranny flush its your problem not theirs
if you really wanna try a flush do go to anyone but a certified nissan mechanic at a dealership but i would reccomend rebuilding it or swapping it
__________________
Old 07-21-2008, 11:48 AM   #1543
crabapple's Avatar
Send a message via ICQ to crabapple
Whoa. Whoa. Whoa.
1st of all, your "transmission problem" is very likely your shifter linkage bushing. Costs about $3 and about an hour of your time. Do a search and you will find detailed instructions here on how to change it. Don't go rebuilding or swapping your transmission
2ndly, you can CHANGE your transmission fluid yourself easily. Flushing is a little more complicated because you have to remove hoses but at this car's age it would probably be a better idea to change out the fluid, drive it for a couple weeks and change it again and repeat.
crabapple is offline   Reply With Quote
Old 07-21-2008, 03:40 PM   #1544
1st thanks for the tip on the shifter linkage bushing
2nd do a search yourself and check out all thepeole who flush a tranny that hasn't been maintained properly and count how many people end up with a busted transmission and explain to me why every mechanic i ask about it tells me the exact same thing
Old 07-21-2008, 07:00 PM   #1545
the metal particles and crap floating around inside there kinda keep some of the worn seals and stuff from leaking. fresh fluid has none of that. meaning when the levee breaks, cryin' won't do you no good.
__________________
Old 07-22-2008, 10:30 AM   #1546
Under neath your car in front of that cat is the shift linkage adjustment, i would suggest adjusting that before anything else. i had the same problem when i replaced my tranny, after adjusting it it was fine, its two nuts on a shaft with a bracket inbetween them losen the one toward the front of the car a 1/2 turn to one full turn the tighten the rear nut. you my need PB blast to loosen the nuts takes 15 minutes.
__________________
1991 GXE Resurrected from the dead
1989 SE gutted for parts and 5 speed.
300zmax is offline   Reply With Quote
Old 07-22-2008, 10:46 AM   #1547
Quote:
eh, bushings first. that way if all it was was bushings, then you don't have to go back and readjust anything. if your car is cool you can replace the under-shifter bushing in 5 minutes, including jack-up time. you can replace the upper bushing on the tranny in 2 minutes.
__________________
Old 07-22-2008, 10:57 AM   #1548
Quote:
true good point. and for the price of the bushing its a good idea to just change them out.
__________________
Old 07-22-2008, 11:46 AM   #1549
i was looking at the NWP spacer for the VG engines and i saw something odd in this picture, to the right of the IAC is a vacuum devise of some sort, does anyone know what that is, its not on my car i have a 1991 max automatic
__________________
Old 07-22-2008, 11:57 AM   #1550
good eye. those pics are of my car, since i was the prototype car. the part is a backpressure transducer for the EGR system. aka EGRC-BPT. it does something. i don't know what. all mine seems do is make duck-call noises when i rev the engine.
my fed-spec 1990GXE with a 1994 California Spec engine
http://i164.photobucket.com/albums/u.../90GXE_BPT.jpg
a typical fed-spec VG
http://s164.photobucket.com/albums/u...1SE_no_BPT.jpg
__________________
Old 07-22-2008, 12:47 PM   #1551
that makes sense, cool. so does it make you feel like your playing duck hunt again, lol
__________________
Old 07-22-2008, 12:58 PM   #1552
The normal VG has one too, it's just mounted lower. If you look from the side of your engine it's clearly visible.
3g94MaxGXE is offline   Reply With Quote
Old 07-22-2008, 12:59 PM   #1553
ntrly
i'm taking it off tho b/c i live approximately 3000 miles from the closest place i'd need that emissions system. well i'm actually swapping in an 89 fedspec motor and putting that motor in another maxima.
__________________
Old 07-22-2008, 01:00 PM   #1554
crabapple's Avatar
I think we largely agree. A flush can cause more problems than it solves on high mileage cars w/o a history of regular fluid changes. That's why I told him to change the fluid himself and repeat the procedure 2 or 3 times. That is a compromise between a total flush and just leaving the old fluid in there. That's what I did after 150k+ miles with no ATF change and have had no problems whatsoever.
As far as mechanics, well, I've dealt with a few good ones and a lot more not-so-good ones so I take anything they say with a gigantic grain of salt.
Old 07-22-2008, 03:17 PM   #1555
i agree thats why i said its possible but if u really wanna do it to save some money compared to a rebuild then go to a dealership they are gauranteed to have the tools to do it right and the knowledge of what really causes this problem that way some retard at jiffy lube doesn't destroy his tranny and stick him with the bill
also if u were about to change your battery because your transmission wasnt in park then you probably know less then the jiffy lube guy and way less than a certified nissan mechanic
you may have more knowledge of how trannies work u may have a way better treated transmission or u couldve just gotten lucky but in the end an old tranny needs a reuild and doin a proper flush would increase the time from now till the when the rebuild has to be done compared to any DIY job
__________________
Old 07-22-2008, 03:40 PM   #1556
my brother had the dealership flush his tranny. they said flushing a poorly maintained tranny might kill it. he said do it anyways. a month later his car was at a transmission shop. EOS.
__________________
Old 07-22-2008, 10:42 PM   #1557
Hey everyone, first off great forum, im on it almost every day and its been really helpful. Alright, im needing to pull my timing belt off on my 89 auto VG30E to re-time the engine (stupid friend... "every time the piston goes up its a compression stroke") and im trying to take the water pump/power steering belt off and i cant seem to find the tensioner on it, i found the one for the PS but it doesnt loosen up the belt whatsoever, anyone know an easy way to get to the tensioner for said belt? Also my timing belt cover is all beaten up and the timing indicater is actually slightly moble, the top cover is off and gone but im not sure whats holding on the bottom cover (how many screws, any of them in hidden areas) any help would be greatly appreciated, thanks
yourripper is offline   Reply With Quote
Old 07-22-2008, 11:15 PM   #1558
Quote:
there should be a lock bolt on the PS tensioner... undo that and beat on the tensioner a time or two with a screwdriver->hammer and that should loosen it. as for timing it, there's marks of where to line everything up... and marks on the belt, so it should go straight on if you line it up right.
__________________
Old 07-23-2008, 05:25 AM   #1559
Lock up problem solved? i think.
hello, i am having a problem with my transmission. i have a 1991 maxima with automatic transmission. lately the while driving down the highway (between 50 and 65mph mostly) the car will shift in and out off lock up. it does it on flat roads and not on hills that i have noticed. if i go faster than 65 it stops. on board diagnostics come ok. fluid is full and clean, and the tranny was replaced about 20k miles ago. enegine has 205k and runs well. any ideas.
thank you.
follow up on my lock up issue, after doing an oil change the other day i noticed that the vacuum hose on the powervalve was missing. after digging around i found a replacement hose and fixed it. since then the issues that i was having with lock up not staying on while driving 50 to 65 mph have stopped. im not sure if this would have an affect on the tranny but it has been almost 400 miles since i fixed the hose with no issues and increased gas mileage!
thanks again for all the help!
__________________
Old 07-23-2008, 07:21 AM   #1560
it may have somehow ended up that the vac leak caused by the powervalve hose being gone had a trickle-down effect by causing you to drive the car differently without knowing you were doing so.. like perhaps having to use more throttle than you should, thereby making it say "oops too much throttle for lockup!"
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
