Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-05-2009, 12:02 PM   #4441
Quote:
Originally Posted by CapedCadaver View Post
er.. the plug for the front injector subharness is on the driver side of the engine near where the EGR valve is.. there's a 2x2 plug (injectors) and a 2x3 plug (iacv) right around that area... i think it comes out from under where the vac hardlines and stuff are.
Ok now i'm stumped. All 4 wires between the injector harness and ecu harness ohm @ 00.5, so I assume that means virtually no resistance.
Now what? I'm stumped
koceja is offline   Reply With Quote
Old 11-06-2009, 09:17 AM   #4442
I've found that Warpspeed made a Y pipe for the VG engine, but are there any Y pipes / headers available for the VE engine?
__________________
Bill, 1992 Maxima SE, White, black leather seats, ATX with factory VLSD, completly stock.
2003 Altima SE 3.5, Black, black leather seats, HID head and driving lights, Dual Halos, Active tunning grill, Nismo CAI, Nismo STS, OBX Headers, Magnaflow Exhaust, Koni Adjustable shocks, Eibach springs, Maxima LSD, 20" wheels.
wpendl1 is offline   Reply With Quote
Old 11-06-2009, 09:28 AM   #4443
Call me Wookiee Goldberg
CapedCadaver's Avatar
then maybe the injector is just clogged.
do you have a spare distributor you could plug in and spin to make the injectors fire w/o the engine running? that way if you unplug all the injectors except #2 you can listen for it clicking.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 11-06-2009, 09:31 AM   #4444
Quote:
ypipe yes, headers no.
http://www.warpspeedperformance.com/nissan.htm
__________________
Old 11-06-2009, 11:09 AM   #4445
Thanks Wookie!
__________________
Old 11-07-2009, 07:10 PM   #4446
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
Quote:
Originally Posted by bigb007 View Post
So one of my fuel injectors died today. I went to start the car tonight and it ran really bad and had a check engine light. It was code 51- fuel injector circuit open. So, I used my trusty DMM to ohm out the injectors. Sure enough, the front center injector was open.
I have searched the forums, and have found that the front injectors are supposed to be quicker and easier to replace. Some say my front center injector can be done in 20 minutes.
My question is: How do I replace the front center injector in 20 minutes as claimed?
you can't on a GXE.
The SE you can
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 11-07-2009, 07:12 PM   #4447
Quote:
Originally Posted by internetautomar View Post
you can't on a GXE.
The SE you can
not on a 89-91SE
__________________
Old 11-09-2009, 01:03 PM   #4448
anyone know the size of the locknut holding the front hub on, on the 92 se? i dont have the right size and need to go buy one, dont want to get the wrong size
PMAX08 is offline   Reply With Quote
Old 11-09-2009, 02:13 PM   #4449
Quote:
axle locknut is 36mm. it's gonna be on hella tight tho so be prepared to strain a muscle or two haha. tightening torque is 230 lb/ft (iirc the highest torque of any bolt on the whole car)
__________________
Old 11-09-2009, 03:15 PM   #4450
great thanks, is it better to use a wrench when taking it off? a ratchet might break or no? will a well made 3/4'' ratchet hold up to 230 lbs?
Old 11-09-2009, 03:37 PM   #4451
er, a wrench probably won't fit inside the hub. i used a 1/2" breaker bar to bet it loose. 3/4" and 4ft handle should be better tho. i have broken breaker bars/ratchets on these things before... not on a maxima tho.
__________________
Old 11-09-2009, 04:50 PM   #4452
probably the stupid question of the day but does the old school VG30E used in Z31 and 2nd gens fit into 3rd gens without alot of work? for when i go turbo i'm wondering if it would just be easiest to get a VG30ET from a turbo Z31 and do a engine swap, it would be easy to get a engine from the junkyard and a fair bit of Z31 pop up
__________________
1992 GXE l 414,000km on original tranny and original VG30E l Pioneer Premier 12" 3500w subwoofer l 600w amp l JVC H/U l aftermarket fog lights l 2.5" Magnaflow catback exhaust l Momo summer rims l Stock winter rims l Sparco Sprint driver/passenger seat w/drivers 6 point harness l Sparco Volanti steering wheel l Castrol Syntec oil/premium Vpower gas
Future mods- 5spd swap, Z31 turbo w/intercooler
This winters mods- Z31 hood scoop, digital cluster swap, lowering springs
chrome91 is offline   Reply With Quote
Old 11-10-2009, 09:33 PM   #4453
Help
I have a burned up fuel injector. the wire connector reads a constant 13.43 volts going to that injector. The other injectors have a constant 0.34 volts going to them. If i replace the injector is it just gonna burn up again? what could cause this constant high voltage?
Mattx4 is offline   Reply With Quote
Old 11-11-2009, 07:14 PM   #4454
Also i am going to replace the exhaust manifold gaskets. is it possible to replace the rear (fire wall side) gasket without dropping the engine?
Old 11-11-2009, 08:16 PM   #4455
Quote:
depends on your definition of "alot of work". if it's 87 or newer it's basically pretty easy. if you want a z31 turbo manifold thingy then just take the manifolds and oil feed tube and whatnot and put it on your stock 9:1CR VG.. the reason that the z31 had such low compression on the turbo motor was b/c it had no intercooler.
now if it's an older motor, an a/b block instead of the newer w block, then the crank pulley might be an issue. they make a spacer (which i bought for my Z project, for this very reason) to allow you to put an EARLY model pulley on a LATE model motor. I don't think it would work out if you tried to go the other way around though (late model aka 3rd gen pulley on an older z/early 2nd gen motor)... but I could be wrong.
__________________
Old 11-11-2009, 08:17 PM   #4456
Quote:
a short or bad wiring maybe. which position injector? (front/rear, passenger side, middle, or driverside)
__________________
Old 11-11-2009, 08:54 PM   #4457
so i could take the turbo and stick it on my current VG30E? i might just do that then. the reason im fixed on the Z31 turbo is i dont want to go with a intercooler just yet. my cousins friend buys old rusted cars and turbo's them for fun when he's bored so i'll see if when a fresh Z31 turbo comes in he'll go with me and help me grab it all
__________________
Old 11-11-2009, 08:59 PM   #4458
eh, i mean you'll need bigger injectors and nistune or JWT ECU so you don't grenade the engine from running bad air/fuel ratios. but yea the z31t manifolds/turbo will bolt on as long as you swap some exhaust studs around into the "spare" holes on the um... LH head i think. Same setup Maxpwer has, with the turbo flipped around for better fitment in the FWD maxima. And there's no reason to avoid an intercooler.. it's easier to put an intercooler in now and run the 9:1CR motor than it is to skip the intercooler now and be stuck with a low-comp motor after you finally get around to tossing on an intercooler. Especially for how much of an HP difference that's gonna make.... but if you can't afford injectors and tuning software yet then just hold off until you can. not to mention you have to rig up your oil and coolant lines for the trubo, probably want a turbo timer, stiffer motor mounts, and a 5spd swap. i'd say do the 5spd swap first, then save up money for a properly tuned turbo setup instead of the ghetto untuned sh!t that indiana guy cobbled together.
__________________
Old 11-11-2009, 09:04 PM   #4459
hey. when my friend and i was putting my new raidiator in my car i lost some tranny fluid. now my car kind of pulls itself foward (just a little, only i knotice it because i drive it everyday). it didnt do this before... do i need more fluid. if so what kind should i get and where do i put it in.
Dinglekidd is offline   Reply With Quote
Old 11-11-2009, 09:07 PM   #4460
yeah 5spd swap first, wouldnt want to do it with my auto tranny because i rarely get over 3k rpm
this ECU (for after the 5spd swap), right? http://www.jimwolftechnology.com/cus...asp?PartID=147
i'll slowly gather everything then just go for a modest setup with a intercooler i guess, dont want ghetto crap. most intercoolers will fit with a stock front bumper right?
__________________
Old 11-11-2009, 09:25 PM   #4461
a/t ecu works fine with a 5spd swap, i got almost 32mpg highway on an a/t ecu and 5spd tranny. don't bother getting another ECU or Nistune software until after you already have the turbo setup in the works. just be sure to tell them it's for a VG30E 9:1CR turbo with whatever CC injectors, z32 MAF (you're gonna need one of those unless you're not planning to make very much HP since the SOHC VG MAF doesn't register an increase beyond a certain airflow level), 5spd, and whatever emissions spec you use. Or get nistune and you can tune it as often as you like (even save multiple tuning profiles for differeng fuel grades, etc) yourself using a laptop and USB cable. You can probably drag and drop a downloadable profile that someone else made using the same CR/injector/maf/etc setup as you, to give you a good baseline, then you can make small adjustments from there. o and make sure to get a wideband o2 sensor (with narrowband emulation)
__________________
Old 11-11-2009, 09:25 PM   #4462
oh it pulls itself foward when im at a complete stop.... i forgot to mention it earlier
Old 11-11-2009, 09:29 PM   #4463
looks good, i'll see if i can find any Z31 turbo around here
just out of curiosity with a Z31 turbo/intercooler, how much more HP approx. would be gained? i'm looking to get the Max to at least 250hp, but preferably 300
__________________
Old 11-11-2009, 09:45 PM   #4464
depends what year turbo (or if you swap it out for some other same-flange turbo), how aggressive your tune is, and how efficient your intercooler is but maxpwer's t3/t4 hybrid setup using those manifolds makes over 300WHP. Dunno what PSI and the exact specs of his turbo, but with a stock z31 t3 turbo you can easily do 250-300.. i mean without an intercooler and at medium-low pressure the z31 turbo made 205hp. jack the boost up and add an intercooler and the gains shouldn't disappoint.
__________________
Old 11-11-2009, 09:46 PM   #4465
Quote:
check the tranny dipstick and add dexron-III fluid as needed. trannies that are low on fluid do some weird sh!t not to mention it's not good for them to be low (or too high)
__________________
Old 11-11-2009, 09:49 PM   #4466
ok thanks. it had me worried. your the best bro(no homo) lol
Old 11-11-2009, 10:01 PM   #4467
looks good, i just need to get some minor things done like Eibachs on (cant stand the body roll on stock GXE springs), and then start hunting down a 5spd tranny
__________________
Old 11-11-2009, 11:32 PM   #4468
It can be done. I changed the rear manifold gasket and the studs on the heads and didn't need to drop it.
jbbons25 is offline   Reply With Quote
Old 11-11-2009, 11:37 PM   #4469
Quote:
from above or from below, or a painstaking combo of the two?
__________________
Old 11-12-2009, 12:43 AM   #4470
Yea. Had to keep goin up and down. But I used a car lift and I don't want to know how hard it would be without it.
Old 11-12-2009, 07:17 AM   #4471
I found a guy with a rusty Z31 turbo that has a good tranny and engine, he said the turbo is in good shape and he would take offers on just the turbo or the whole car. pick n pull sells turbo's for $68.99, is $100 a decent offer for a good Z31 turbo (not the whole car)?
__________________
Old 11-12-2009, 03:08 PM   #4472
well see what he wants for the full exhaust manifold/crossover, and turbo, and downpipe flange. cuz you'd probably need all of that just to make your life easy by using all matching parts.
__________________
Old 11-12-2009, 04:20 PM   #4473
It's the front passenger side injector (#2 cylinder). i got the connection off without removing the intake. the plug is getting spark but when i pull the plug wire it doesn't change the way the car runs. this is the only injector connector putting out any substantial voltage constantly whether the ignition is on or off. And about the exhaust manifold, can i get it off to change the gasket without dropping the engine? It's the rear (firewall side) manifold.
Old 11-12-2009, 04:24 PM   #4474
did you have to remove all of the studs to get the gasket in or did the header clear the studs and come all the way off??
Old 11-12-2009, 09:40 PM   #4475
bish wants to sell it whole now, i would consider taking all the turbo parts and making the Z31 a NA track car but i dont think its JDM so i dont really want it
i posted a online ad and i found a guy who owns a Nissan only junkyard, he said he should have a 5spd 3rd gen and a Z31 turbo
__________________
Old 11-13-2009, 01:02 AM   #4476
It can be taken off with the studs on. I changed the studs to make sure I had the superceded ones installed. Two bolts were used on the rear manifold
Old 11-13-2009, 07:33 AM   #4477
seriosly dude? JDM doesn't mean sh!t......... other than having the wheel on the other side of the car. and in a country that drives on the right side of the road, it's a safety hazard to have the wheel on the wrong side, otherwise cars worldwide would have it on the same side no matter what side of the road they drove on.
__________________
Old 11-13-2009, 04:49 PM   #4478
meh i just like JDM lol, i would kill for a JDM 3rd gen Maxima but a guy i know in Japan said he see's very few. i prefer driving on the right too/feeling of it
the guy with the junkyard says he has a turbo Z31, and he has Z32 and Skylines. Hes 7 hours away from me but if i can get the full turbo setup and 5spd it would be worth it
__________________
Old 11-18-2009, 09:16 AM   #4479
hey guys. I'm replacing a fuel injector on my 91 se. besides the intake gaskets, are there any other O rings or gaskets i'm going to need? any advice?
Old 11-18-2009, 10:56 AM   #4480
you'll need new fuel injector o-rings, do not reuse the old ones, they will fail and leak.
courtesyparts.com has all the part #'s and drawings you need.
__________________
CAI, EGR removed, FSTB, DZ springs, SS brake lines, Cross Drilled Rotors, ES Poly bushings, 9007 upgrade, Front lip and repaint, fogs, 2x alpine type s 10's, pioneer HU Alpine Amp,
Garf is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
