3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Hey everyone I've been lurking on this site for many years. I own a 96 se 5mt. My brother has a 93 se 4at. I'm having a missfire problem with his 93.
Symptoms:
-Power loss and missfire apparent when in drive. As the car warms up, the missfire gets worse. NO CEL's
-Problem has gotten worse and worse as the months went by. A gradual change in performance. It seems like the car is running lean.
-Coil packs are good. All have perfect resistance and I checked for spark.
-Coolant temp sensor, and tps were checked, all good.
-The MAF isn't outputting any voltage. That makes me think it's bad. The weird thing is that there's no CEL and the car isn't in limp mode (i can rev it as high as I want).
-I suspect the injectors, but the front 3 I know are good (hard to test rears). I inspected all of the spark plugs and cannot see any differene in condition across the board.
hey guys! so i recently bought a 90 maxima auto with only about 112 thou on the odometer. but on the flip side its got a few problems... first it idles real rough and theres a poping sound comming from the muffler. im guessing i have an exhaust leak somewhere? then sometimes the car just up and dies and kills the battery it will putt putt and then just die. next is a huge electrical issue, i have no acc power so when i put the key in and turn it on i have no radio or anything, checked all the fuses but everythings fine but i did notice that on the positive battery terminal there is a clip thats about 4 inches long that is missing so im guessing it shorted out because theres no wiring there its just the clips plugged in im guessing that would have something to do with my acc power? and does that little clip have anything to do with the alternator charging the battery? any help would be great sorry for the jumpy post let me know if you need any more info thanks
zach
also my main concern is that the little 4 inch clip going from the positive terminal to the harness always melts the wire i try to hook up to the clip how would i go about fixing that?? its from clip 2 to clip 3 in the picture and its holding me back from all my accessory power i know that for a fact i just dont want it to hurt anything else
Fluff:
I just received one of my favorite cars as a gift. A shiny 1992 Maxima GXE. Sadly, it does have some problems. I've spent an hour or so trying to find an answer to one problem in the forums here. Then I spent two hours making a list of all the other things I found along the way that solved other problems. There's a huge wealth of knowledge here, and I'm very grateful. I also have a sizable list of things to order from the good folks at Courtesy Nissan, and my wife is going to let me buy them all.
Actual Problem:
However, my original problem remains unsolved. About 50% of the time, when I shift from neutral to drive, the transmission doesn't engage immediately. I can shift to 2 then back to D and it'll go, or I can wait about six seconds in D and it'll finally engage. The FSM doesn't have a diagnosis for this, and the only mention of this problem I could find in the whole internet is this site, provided solely for your entertainment. My mechanic wants $390 to replace the neutral safety switch. Since all articles here regarding that part deal with non-starting vehicles, I'm actually a little leery regarding his diagnosis. Also, I figure I can do that for $90. Any advice?
if it's the thing on the brake pedal, then your brakelights would not work. otherwise it's the green plastic box in the passenger side kick panel. pm nc90gxe and ask him if he still has his (i did his 5spd swap in march but i don't think we ever removed the green box)
Do you recall the name of this green box? Because i can always call the grab a part place.
Fluff:
Actual Problem:
Not an auto guy, but it sounds like your shifter bushing(s?) may be going out.
I want to get a high performance alternator for my 1994 maxima, does anyone know where i can find one please???
idk how much output you"re looking to get but i found a 150amp output one? and considering a the stock one is what 90 amps thats a upgrade for you! just do a google search and go from there. heres the link i found... http://www.maniacelectricmotors.com/hiou150ampal2.html
i just got a 92 maxima for FREE!!!! anyways. the trans has a problem, i can drive it, but it does not go into drive.... what im saying is when you put it in drive it will go through 1st and 2nd, but wont shift out of secounf, when it gets to the shift point out of 2nd it just revs... until you put it into 2nd manualy then it goes but stays in second. have no idea about these cars i know i tried switching o/d off, and the power/comfort swith, iv delt with bad auto tranny before and replaced many, but they have always just went, this one shift very smooth through 1st and 2nd... just wont go into drive gear, tranny fluid is fine, fresh, any ideas or someone had this experience with this same problem????
sounds like 3rd gear isn't working....... here's an idea... warm the car up FULLY... then accelerate to like 50mph with the shifter in 2 (yes this is safe... 2nd is good for 75mph on the automatics) and stabilize your speed at 50mph, then shift it into D with overdrive enabled (ie, yellow light OFF) and see if it'll go into a gear, or if it still just free-revs. If the tranny seems to work at higher speeds like that, then you know your o/d (aka 4th gear) works, and that your only issue is 3rd gear. Either way you'd probably need a new tranny to fix the issue.
also which engine do you have? VE (oil cap on front valve cover... 92-94 SE) or VG (oil cap on a stalk on the rear valve cover... 89-94GXE and 89-91 SE)?
__________________ PieceOut.FallToPeacesNew to the forum? CLICK HERE!!!! 1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress! 2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z 1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09 2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
does anyone know the name of the part/ where I could get:
The rubber bumper that the spring sits on. It sits between the bottom of the spring and the strut. (Donut Shaped)
tia
__________________
CAI, EGR removed, FSTB, DZ springs, SS brake lines, Cross Drilled Rotors, ES Poly bushings, 9007 upgrade, Front lip and repaint, fogs, 2x alpine type s 10's, pioneer HU Alpine Amp,
$9 shipping minimum on all orders. so if you have other OEM parts that you plan on ordering anytime soon, and can afford them, minus whale go ahead an order them with it.
Symptoms:
Ay ideas?
I went ahead and ordered a new MAF. I figure if it doesn't change anything I'll return it.
You can actually test the rears at the harness, which was news to even me until just recently
It's been my luck on two VE's that it's always an injector on the rear that goes bad
I know you said they tested fine, but are the coilpacks cracked?
Also, are you sure it's misfiring and not just getting "heat soaked"? VE's are notorious for bad knock sensors that really, really bog the car down once the engine warms up
__________________
Desperately looking for a 5 speed axle carrier bracket. Either VG or VE will work. PM me if you have one!
Good working door lock timers $20 shipped. PM me if interested
I have a 89' maxima GXE and the fourth setting on my AC does not work. One, two, and three work fine but when I switch it to four it cuts out completely.
Any suggestions on fixing this problem?
__________________
89 Maxima GXE 222K on Original Motor
could be your wiring maybe?
If your wiring is bad, you might need a new CCU (climate control unit)
__________________
1992 GXE l 414,000km on original tranny and original VG30E l Pioneer Premier 12" 3500w subwoofer l 600w amp l JVC H/U l aftermarket fog lights l 2.5" Magnaflow catback exhaust l Momo summer rims l Stock winter rims l Sparco Sprint driver/passenger seat w/drivers 6 point harness l Sparco Volanti steering wheel l Castrol Syntec oil/premium Vpower gas
Future mods- 5spd swap, Z31 turbo w/intercooler
This winters mods- Z31 hood scoop, digital cluster swap, lowering springs
I would check the High Blower Relay.
Quote:
Originally Posted by Shoveller
Need new shocks in the front (and probably rear too). What brand do y'all suggest? Not performance, but a nice comfy ride.
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
having major issues with my maxima...cylinder number 2 and number 5 arent firing...well i assume this i can take the plugs of the coil packs and the engine doesnt change at all. and now when im driving it it will loose all spark im guessing. the only thing keeping the rev's up is the motor turning as soon as i take it out of gear it dies completely. but i can start it right back up and it will run for a min or two like that ok and then do it again. but sometimes it just comes back on without me having to restart it. im pretty mechanically inclined guy but this is stumping me....im thinking the ICM (ignition control modual) any help would be appreciated
I assume it's a stick.
chances are you have 2 bad injectors.
check the resistance on the injectors ro make sure they are within range. once those are functioning right you will probably have no other issues.
96 Green A/T gone
trying to check the back injectors can anyone give me a better description on where that middle coupler is so i can test the back... the 3 on the front read 12.2 11.8 and 65.3 LOL
96 Green A/T gone
yea im pretty sure there is at least one more on the back side that is bad. im just gonna get all new ones you can get remanufactured set for like 160 bucks. thats all six so im just gonna do that i think
and you will do it, again, in about six months, nine times out of ten.
There is no such thing as a "reman" injector for our car.
buy new ones. it'll cost $600 or so, but you will only do it once, even if you double your current mileage.
there are several pages of sworn testimony by first-hand witnesses that reman injectors are actually "remanufactured" in a secret factory, in the 7th level of hell, by demons, supervised by Satan himself . So trust me... you don't wanna use them.
I know for a fact the coil packs are perfect. Thanks a ton for the help with the rear injectors!!! The car has always had a bad heat soak issue. I've never gotten any cel's with the car either????
"heat soak" = bad knock sensor.
the CEL on the third gen is about as useful as christmas tree lighting. nice to look at, but rarely does anything useful
96 Green A/T gone
Does anyone have a audio color code schematic ohmed out the speakers and I
know whats what however still no sound I'm still using the bose/amplf/speaker
help. 1994 maxima
96 Green A/T gone
alright so i plan on messing around with my front bumper alil. i was curious if anyone took a 4th gen bumper and bolted it right up to a 3rd gen with no problem. i wanna do the swap to look cleaner and have normal foglight housings so i can run hid foglights
it wouldn't fit at all. nowhere close.
96 Green A/T gone
my maxima came with the awful, skinny 2 spoke wheel so i bought a 4 spoke wheel that also came with the maxima. i had searched on here and it looked like it was a direct swap, but the the set ups for the steering wheel are completely different. the 2 spoke has this thing bolted to the back of it that rotates when the wheel turns which the 4 spoke does not have, it just has this metal rings that the electrics run through.
can anyone that has done this swap help out?
I can't see what you are talking about (yes, steering wheels ). can you provide pictures?
Do you mean the different factory steering wheels that came with 3rd gens? like the one that has the push horn and the one with the buttons?
EDIT- guess not, late post.
That thing RHD? if it is epic win
__________________
hmmm..... try pulling the thing with the wires off the steering column. it looks like it might've broken out of the back of the 2-post wheel...... note the 4 holes that match up with the holes in the back of the wheel?
i like the PRND2L lights on the cluster. what're the 2 oval-shaped buttons next to the comfort/power switch? also i would get SO confused trying to indicate in your car since in the US the headlight/indicator switch is on the left side of the wheel.
