Where the $%#* is my coolant going!?!?
Alright, newly replaced radiator, upper and lower coolant hoses, no leaks visable there. No leaks from heater hoses, no wet carpet inside, and coolant reads 0 hydrocarbons, so where oh where is roughly 32 oz every 3-5 days going?!?!?
Park the car with the engine situated roughly in the middle of the paper.
Start the motor and leave it idling while you go have a beer.
Find the wife/girlfriend and bring her to the garage after about an hour.
Remove car from above the paper and ask wife/gf to roll around naked on the paper - I can guarantee you she will find the wet spot and you will know the exact location of the liquid leak and the answer to the mystery.
Originally Posted by LvR
Properly clean an area in the garage and put down dry brown paper (the stuff they use to cover books with) on an area about 2m but 2m. Make sure the motor is cold (morning) and the cooling system is properly filled.
LMAO dude thats genius! I'm gonna try that tomorrow, I mean later...
I would try the radiator cap first. Not only because it's the cheapest, but because if you can't find any leak it's most likely the cap isn't holding pressure on the system and the water is boiling at a lower tempature than usual.
Time for a new cap from the dealer, yay 16 bucks here ya go!
+1 for rad cap, then +1 for water pump.
Had a similar problem - and couldn't see the puddle 'cause I have a gravel driveway. Went to a conference one week, and saw the puddle under the car (and following the slope of the underground parkade).
m
m
foodmanry
09-24-2015 12:02 PM
