Sometimes transmission lets me shift quickly but other times I have to force it...
Old 08-24-2007, 08:02 AM
The Computer Guy
nForce's Avatar
Ive noticed that sometimes my tranny lets me into gear quickly and other times I really have to force it like I am about to break the shifter. This mostly happens in 1st and and 5th. Just about every time I am on a slight incline it wont let me into first so I have to go into 2nd and going up a hill in 2nd isnt the greatest . Anyone have idea why it lets me in somtimes and other times it doesnt? Could my linkage be the cause or maybe even my shifter bushing? I had to fab up a bushing for the shifter because the rubber was broken so I made a little wood piece and stuck it in between the metal and stuck a bolt though to hold up the shifter.
nForce is offline
Old 08-24-2007, 08:08 AM
¯\(°_o)/¯
Greeny's Avatar
The wood bushing may be causing the linkage to bind up.
Greeny is offline
Old 08-24-2007, 10:39 AM
STFU n00b!
Matt93SE's Avatar
could be the ghetto fix, but I'm going to bet it's your input shaft bearings.
when the bearing gets bad enough, the cage around the ball bearings comes apart in pieces and gravity makes it fall down into the shift linkage since its the lowest part of the tranny.
this is why it happens randomly-- sometimes the piece is there, others its now. get the car moving and the oil starts flowing around and the pieces move out of the linkage area. stop at a light and they settle back down there.
http://blehmco.com/pics/car/drivetrain/tranny/
look at pics 1405 through 1414.
Matt93SE is offline
Old 08-25-2007, 06:37 AM
I need a brake.
cheatham's Avatar
^^^ +1
Does the tranny humm when it is idling out of gear?
cheatham is offline
Old 08-25-2007, 09:53 AM
Call me Wookiee Goldberg
CapedCadaver's Avatar
Originally Posted by cheatham
^^^ +1
http://forums.maxima.org/showthread.php?t=533230 that's his other thread, concerning tranny noise.
nForce, you know, based on what matt said, maybe you lost another bearing (which would explain the noise on thatother thread), and those ***** and pieces are clogging up your shifter linkages. How 'bout dem apples?
CapedCadaver is offline
Old 08-25-2007, 04:17 PM
The Computer Guy
nForce's Avatar
Yea this makes sense...
I think the tranny oil isnt lubing the inside up properly. If I drive the car hard it shifts better and the sound goes away. But driving it hard means shifts of 4k or better. Could this be a theory? I have that cheapy GL-4 that napa sells the StarLube stuff in it..
I hope this car can last me little longer. I am already looking at a Audi S4 as a replacement if this was to die soon.
nForce is offline
Old 08-27-2007, 07:53 AM
The Computer Guy
nForce's Avatar
OK you all can me
I havent checked my clutch fluid in while and noticed I was OUT! This would explain why I could'nt shift into gear correctly and also means there is a leak in the lines some were that I cant see. so looks like ill have to monitor now my brake fluid and clutch fluid since both leak their self dry. At least I always have clean fresh fluid
nForce is offline
Old 08-27-2007, 08:33 AM
braxsusriely's Avatar
sometimes grinding
occasionaly when i'm accelerating down the on ramp i'll stay in 3rd till about 80 and then shoot for 5th but it tends to grind everynow and then so i have to go from 4th then to fifth? any ideas?
braxsusriely is offline
Old 08-27-2007, 03:10 PM
STFU n00b!
Matt93SE's Avatar
worn synchros. deal with it or rebuild the tranny for $1000.
Matt93SE is offline
Old 08-27-2007, 07:52 PM
hadman's Avatar
I think the culprit might be found in pic #1415...
hadman is offline
Old 08-27-2007, 07:58 PM
The Computer Guy
nForce's Avatar
Indeed
nForce is offline
Old 08-29-2007, 06:15 AM
STFU n00b!
Matt93SE's Avatar
He was my little helper.. he keeps the bugs from eating my tools.
(way cooler than that stupid green one that only sells car insurance!)
Matt93SE is offline
Old 08-29-2007, 07:56 AM
The Computer Guy
nForce's Avatar
haha or more like the new cavemen ones
nForce is offline
CorollaULEV
30
08-09-2021 08:11 PM
maxinout93
10-27-2015 01:29 PM
Max8
08-20-2015 07:20 PM
Quick Reply: Sometimes transmission lets me shift quickly but other times I have to force it...
