Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-30-2007, 09:44 AM   #1
Wanna Go Muddin?
Greeny's Avatar
9007 bulb upgrade**With Pics**
Hey guys,After looking at the 4th gen 9007 bulb upgrade thread,i decided to make the 3rd gen forum a similar thread with pics to help out..
The 9004/9007 bulbs share the same harness connectors,but the wiring is different..The 9004= high beam/low beam/ground...9007=high beam/ground/low beam...
Also,the 9007 bulbs key slots are different from the 9004 bulb housing..You can either cut the 2 bottom nubs out of your headlight housing,or cut slots in the sides of the 9007 bulbs to match the stock headlight housing nubs..
Instructions
The middle wire[red/w yellow stripe] and the black wire need to be swapped
Be sure to use solder on the wire connections to ensure a good long lasting connection..Then use electrical tape to shield the wires from each other..
I decided to my dremal tool to cut slots in the sides of the 9007 bulb instead of cutting the nubs out of my stock headlight housing,just incase i want to return to 9004 bulbs in the future,but i guess you could still use the 9004 bulb anyway..
Greeny is offline   Reply With Quote
Old 05-30-2007, 09:45 AM   #2
Wanna Go Muddin?
Greeny's Avatar
The stock headlight nubs i mentioned earlier,the two bottom nubs can also be cut off,so the 9007 bulb can fit into the stock housing
Just reaim the headlights and all done
Old 05-30-2007, 10:21 AM   #3
Send a message via AIM to aw89maxSE
__________________
Infiniti M35
http://www.cardomain.com/ride/2348761 2000 SE *Sold*
http://www.cardomain.com/ride/290861 1989 SE *Sold*
aw89maxSE is offline   Reply With Quote
Old 05-30-2007, 10:22 AM   #4
i assume 9007's are brighter hence the need to do this?
onyx10 is offline   Reply With Quote
Old 05-30-2007, 10:30 AM   #5
03 E55 AMG, 93 G20, and
Send a message via AIM to mikekantor
most of the increase seems to be on the low beam brightness, but at a slightly higher power draw:
http://candlepowerinc.com/pdfs/9004_9007.pdf
mikekantor is offline   Reply With Quote
Old 05-30-2007, 10:33 AM   #6
Wanna Go Muddin?
Greeny's Avatar
Quote:
Yes,the 9007 is 55 watt low beam/65 watt high beam..Compared to 9004/ 45 watt low beam/65 watt high beam..
But the biggest advantage of the 9007 bulb is how the filament is oriented compared to the 9004 bulb..The 9004 filaments shine from top to bottom of the headlight housing/vs the 9007 filament shines from side to side across the headlight housing..this concentrates more of the light from the bulb on the reflective material in the headlight housing..
9007 left....9004 right
Old 05-30-2007, 10:54 AM   #7
I Has Pushrods!
maxitech's Avatar
So does this upgrade get your seal of approval, Wayne? And more importantly, do the new bulbs blind oncoming traffic, as hinted at in mikekantor's link?
maxitech is offline   Reply With Quote
Old 05-30-2007, 11:03 AM   #8
Wanna Go Muddin?
Greeny's Avatar
Quote:
Yes,it definitely gets a thumbs up from me..
As long as you adjust the headlights[usually down] they do not blind oncoming traffic..
After i done this mod,i drove my car directly to a large high school parking lot near my house to adjust my lights accordingly,that way i did not irritate half the town with my spotlights..
__________________
3rd Gen parts--> http://forums.maxima.org/1st-3rd-gen...-part-out.html
Old 05-30-2007, 11:52 AM   #9
If you dont mind, it would be great to see a night time low beam comparison with 9004 in one headlight and 9007 in the other.
Old 05-30-2007, 12:00 PM   #10
Wanna Go Muddin?
Greeny's Avatar
Here is a before aiming the light shot..
I will get a some better comparison shots tonight with my wifes gxe as the 9004 rig..
Old 05-30-2007, 02:21 PM   #11
what can my max do for me
i think some of the other write ups incorporate the use of a relay. is that something unique to the wiring of the 4th gens? can the 3rd gens' harness handle the higher draw?
__________________
October, 2009 - the conversion to electric begins.
for sale - anything related to internal combustion is up for sale
DaWifey's90 is offline   Reply With Quote
Old 05-30-2007, 02:42 PM   #12
I just did this same mod yesterday. Went from 9004 PIAA Star Whites to 9007 Phillips XtraBrights +30 bulbs and the difference is quite noticable. Sure the light is not a clean white like with the PIAA bulbs, but they are a bit brighter. Tonight I'll post a night pic of the adjusted 9007 bulbs in my '91 SE.
autobotguy is offline   Reply With Quote
Old 05-30-2007, 02:42 PM   #13
Wanna Go Muddin?
Greeny's Avatar
Quote:
I'm pretty sure the relays allow you to bypass the stock wiring/and draw current directly from the battery,not sure though..
Here is the 4th gen write up thread..
Leather Seat Back
__________________
Old 05-30-2007, 04:25 PM   #14
Send a message via AIM to Gunther
Is this with upgrading the wiring harness for the headlight? If not I'd assume it would help, right?
Gunther is offline   Reply With Quote
Old 05-30-2007, 04:39 PM   #15
Wanna Go Muddin?
Greeny's Avatar
Quote:
Did you read the instructions/first post?
Old 05-30-2007, 04:45 PM   #16
I Has Pushrods!
maxitech's Avatar
10b!tchslaps
__________________
MODS: VLSD 5-Speed Swap, Exedy Stage 1 Clutch, Turbo Manifold Studs, Koni/Eibach Suspension, Suspension Techniques F & R Swaybars w/ Blehmco RSB Links, Unorthodox Racing UDP, Blehmco Grounding Kit, WSP Y-Pipe, Place Racing CAI, Custom STS, Polyurethane Front & Rear Bushings, Q45 Front Brakes (Blehmco S.S. Lines, Brembo Rotors, Axxis Metal Master Pads), Courtesy Nissan FSTB, Blehmco RSTB, Blehmco Stage II LTB, NissanWorks TB & IACV Spacers, 9007 Headlight Bulb Conversion, GXE Fog Lamps, Sound System (Infinity, JVC, Polk, MTX), 2k3 SE 17" Wheels w/ 225/50R17 Hankook HR Ventus II Tires - 186K miles (bought 8/03 @ 87K miles)
Other Toy: '96 Corvette LT4 6-Speed, 75K miles (bought 3/09 @ 60K miles), Black on Black, Fassstt!!!! Stock, for now...
Old 05-30-2007, 08:12 PM   #17
Wanna Go Muddin?
Greeny's Avatar
9007
9004
__________________
Old 05-30-2007, 08:14 PM   #18
I can has?
Pearl93VE's Avatar
Send a message via AIM to Pearl93VE
hah, where's the love for the wifey's car?
But yeah, seems like a worthwhile upgrade... and eeaasyy
__________________
Pearl93VE is offline   Reply With Quote
Old 05-30-2007, 08:20 PM   #19
Wanna Go Muddin?
Greeny's Avatar
Quote:
She does her own mods....
Old 05-30-2007, 08:27 PM   #20
looks pretty nice. def an upgrade from the 9004s.
why not try fitting in 9012 HIRs? they're among the brightest halogen bulbs on the market. i don't know how hard it'll be though, since the base of the 9012's are 9006 based.
__________________
Eclipse CD5100
Arc Audio 1500-XXK
Arc Audio 4150-XXK
Arc Audio XEQ
DLS Iridium 8.3i
DLS Nobelium 12
Boston Acoustics SL65
Hushmat, Cascade Audio Deflex, Audison ST Interconnects
Berk Technology short ram intake - Greddy SP2 Cat-back Exhaust - Viper 791XV alarm - 5000k HID headlights and fogs - T-Rex billet grill - IPCW LED tails - 20% tint on sides, 15% tint back window - Suede headliner
AscendantMax is offline   Reply With Quote
Old 05-30-2007, 08:40 PM   #21
Wanna Go Muddin?
Greeny's Avatar
9006 bulbs are a completely different design from the 9007/9004 bulbs..
Also,the main point of this mod is it's simplicity to do,it took me all of 30 minutes to do this with marked improvement from the 9004's..In short,lets keep it simple..
__________________
Old 05-30-2007, 08:52 PM   #22
i have to find a 9006 "upgrade" for my high beams now that i have HID's
Old 05-30-2007, 09:15 PM   #23
IM OUT
95turbo gxe's Avatar
Send a message via AIM to 95turbo gxe Send a message via Yahoo to 95turbo gxe
looks good for a turd gen!
__________________
Currnent MODS:_______
TURBO 6SPEED DEK_________
Hx35w turbo______________Z32 BBK with 04 Rotors
Emanage Ulitimate______________D2 coilovers
E01 boost controller__________
Jwt flywheel_________________18" Anv z wheels
under drive pulley____________Duel fx35 Projectors
95turbo gxe is offline   Reply With Quote
Old 05-30-2007, 09:19 PM   #24
JPW 4 Heisman
Michael's Avatar
Send a message via ICQ to Michael Send a message via AIM to Michael Send a message via MSN to Michael Send a message via Yahoo to Michael
Well I didnt read all of this Wayne but I will say that you made one mistake (well not really a mistake but not how I would have done it) by cutting and re soldering the wires.
Its very easy to take the wires out and swap them. Just take the orange locking piece off and remove the pins and swap them around. Thats what I did when I did the swap and it makes it much easier and you dont have to worry about your wires where you cut and reattached.
and also you can still use the 9004 bulb after cutting the nibs out of the housings (you really cant screw up putting the 9004 back in even with the other nibs cut since its pretty much common sense) so no need to really cut the bulb. This is easier because you dont have to cut new bulbs when you blow the old ones.
Just a couple of minor things I would (and actually have) done. I just dont like cutting factory wiring for anything...especially on old Nissans.
Trust me Nforce...even high watt quality 9004s do not match even stock 9007s. Dont believe me ask PA. When he bought my old 92 he said he would probably put his high watt 9004s in until he drove at night with my pretty much stock (cool blues I think) 9007s. They may appear just as bright but the light placement and the way it lights up the road beats the 9004 hands down.
__________________
Roll Tide Roll!!!
Michael
Michael is offline   Reply With Quote
Old 05-30-2007, 09:21 PM   #25
Quote:
I didn't mean changing the harness to power the bulb correctly, I've read on here about using a larger guage wire to the headlights to get a better output, I wasn't sure if you did that or not...
__________________
Old 05-31-2007, 12:52 AM   #26
Well here are some pics of the light output on a brick wall.
...and yes, I know my fog lights are aimed high.
__________________
- autobotguy -
1990 Nissan Maxima SE
20% tint, Vortex Classic Muffler w/o resonator
Pioneer / Kenwood audio
191k miles
Old 05-31-2007, 01:53 AM   #27
Send a message via ICQ to Lordrandall Send a message via AIM to Lordrandall Send a message via Yahoo to Lordrandall
Nice addition to the thread Michael. I may actually do this if I don't have to cut the harness.
__________________
92 SE 5-speed - 96 S14 SE 5-speed
Lordrandall is offline   Reply With Quote
Old 05-31-2007, 04:52 AM   #28
Wanna Go Muddin?
Greeny's Avatar
I can always count on micheal to critique my work..
Old 05-31-2007, 07:44 AM   #29
Can your stock harness take the extra juice without overheating?
redwood_usa is offline   Reply With Quote
Old 05-31-2007, 08:02 AM   #30
Its only like 22% extra, I'm sure its within tolerance considering the heat they get from being near hot engine parts and the radiator in the first place.
Old 05-31-2007, 08:13 AM   #31
JPW 4 Heisman
Michael's Avatar
sorry I dont mean to...I just dont like cutting the factory wiring on anything and try to find a way around it. I am also lazy and try to find the easy way to do anything
__________________
Roll Tide Roll!!!
Michael
Old 05-31-2007, 08:20 AM   #32
Wanna Go Muddin?
Greeny's Avatar
Hehe..No problem michael,i was just bustin yur chops..
Swapping the wires around is actually the best way,i just never thought about taking the plug apart..
Old 05-31-2007, 09:21 AM   #33
best of both worlds: attach insulated male/female ends and swap at the heart's content
crappy image I googled:
Old 05-31-2007, 11:12 AM   #34
JPW 4 Heisman
Michael's Avatar
OK so I decided to get the sockets off my parts car in the woods to show how to remove the wires from the socket since it can be tricky.
the first step is to push down and out on one of the tabs that holds the orange clip in:
Next you do the same thing to the other side:
Here is a shot of the back of the socket without the clip in place (its been sitting in the weather for several years...yours will probably not have the junk behind it):
Next you will need a thin piece that comes to a point like a thick needle or something. This is important because you have to get under the clip or you will not be able to lift it...a thumb tack will work if its long enough.
you angle the tip down until you get under the clip that holds the wire in place and then lift up and pull the wire right out:
Old 05-31-2007, 11:13 AM   #35
JPW 4 Heisman
Michael's Avatar
here is a pic of the wires out of the socket ready to be swapped:
here is a pic looking into the socket to show the clip that has to be raised to get the wire out (not the correct wire out but its just to show how the clip looks to give you a better idea of where it is):
Here are the wires swapped:
Here it is with the cap back on and the socket ready to be used:
Old 05-31-2007, 11:24 AM   #36
Quote:
Mine has held up nicely for the the past 2 years+
Pervis Anathema is offline   Reply With Quote
Old 05-31-2007, 12:15 PM   #37
has anyone tried the Hella optilux 9007 (apparently they're a 100/80w bulb)?
or would this be the definition of overkill?
__________________
Old 05-31-2007, 12:27 PM   #38
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
it is the cause of melted original harnesses.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 05-31-2007, 01:11 PM   #39
I ran 100/80w in my VG for over 4 years without problems. They were noticeably better than stock but not as good as lower wattage 9007s. I used an upgraded headlight harness to avoid electrical malfunctions.
Old 05-31-2007, 03:55 PM   #40
Wanna Go Muddin?
Greeny's Avatar
Thank you michael for your addition to this thread,,
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
