Trunk Light
Old 04-28-2007, 11:07 PM
gapboi210's Avatar
Trunk Light
The trunk light doesn't work and the bulb is good. Is there a mercury switch somewhere? I pulled the cover off the inside of the trunk lid and all those wires looked ok. Those, I am guessing might be for the trunk release.
gapboi210 is offline
Old 04-28-2007, 11:24 PM
mooze's Avatar
have you tried a replacement bulb just in case? bulb might look god but may be burned out.
mooze is offline
Old 04-28-2007, 11:29 PM
gapboi210's Avatar
yeah already tried that
Old 04-28-2007, 11:40 PM
mooze's Avatar
checked fuses?
mooze is offline
Old 04-28-2007, 11:48 PM
gapboi210's Avatar
that was checked too
Old 04-29-2007, 12:00 AM
mooze's Avatar
i would check your switch next. where is it i have no idea but i would think its built into the trunk lid. i say this because i recently did work to my trunk and removed the latch. when i closed me trunk all the way down and put things on top to keep it down the light would still be on. so inside somewhere is my best guess
mooze is offline
Old 04-29-2007, 12:18 AM
gapboi210's Avatar
i am guessing it grounds through the latch when it is closed. I guess I need to check for power
Old 04-30-2007, 01:49 PM
stevex's Avatar
Check the wire on point where is trunk lid wrist (crank, joint). probably on that point wire is broken but you couldn't see it.
stevex is offline
Old 04-30-2007, 04:55 PM
gapboi210's Avatar
looks like i need to pull the loom off and inspect it like u said. Doesn't look fun. I almost thought about getting one of those $1.99 stick on push lights. Ha ha ha
fastcarny
10-06-2015 10:42 AM
rnb754
09-14-2015 11:39 PM
Maxima30
09-07-2015 06:13 PM
rbaker100
09-06-2015 02:46 PM
Hailstatejig
09-02-2015 06:52 AM
Quick Reply: Trunk Light
