My Maxima = teh suck
Old 08-11-2006, 07:11 AM
"and falling like a rock"
89blackse's Avatar
Hey guys, got some questions for you all.
My car is a 92 maxima
engine VE30DE Turbo and Intercooled,
upgraded injectors, 300zx MAF, stock ECU
1.)The clutch is pretty worn as some of you know, so it has sat in front of my place for a couple weeks and the battery died a few days ago. I charged it up and drove it around for about 20-30 minutes just to charge the battery and such. I then parked it and left it for 2 days, then I tried to start it and it had 0 power, less than the last time I jumped it. Odd. So I jumped it and rolled out of the complex.
2.)I left it in first gear and ran it up to 4000-4500 RPM and a huge backfire/explosion could be heard and it was hell trying to keep it from stalling so I could drive it back to the complex, but it died at a stop sign. I jumped it again and drove it all of 20 feet back to the parking lot and it ran OK but white smoke was exiting the tail pipe, about as much as you would find running your car on a cold day. It also had a strong burning smell to it.
So did think I blew a head gasket?? Think my alt is crap??
Just so you know, I was off the boost and this was a very slow acceleration speed like 1 second per 1000 RPM rise.
I'll try to do a compression test tonight after work, also.
89blackse is offline
Old 08-11-2006, 07:48 AM
Alex_V
if your car runs, the alt is fine. If it starts then dies a few minuets after you start, then the alt is dead. The batterys job is to store egnough energy to start the car. The alt's job is to keep it running. It sounds like your battery is dead as when the car stalls it needs jumped, but it'll stay running for as long as you need right?
And it sounds like you had a backfire that pop'd the headgasket. If your going to just replace the headgaskets, dont leave that water in there! It'll rust the cylinders out and then you definitly need a new engine! My friend bought a Eclipse cheap, with a blown HG, and he left it sit for a few months, and the engine was filled with rust and other nasty crap, so get the engine clean asap.
And if the white smoke smelled sweet, its burning coolant and thats a blown HG.
~Alex
Old 08-11-2006, 09:05 AM
Maximahappy22's Avatar
YOUR ALT IS DEAD!!! same thing happened to my car...
Maximahappy22 is offline
Old 08-11-2006, 09:20 AM
maxitech's Avatar
How long have you had the car, and did you turbo it yourself?
maxitech is offline
Old 08-11-2006, 09:35 AM
89blackse's Avatar
About 2 months, put less than 5 tanks of gas since I got her to Kentucky.
Here she is:
http://forums.maxima.org/showthread.php?p=4976353
And yes hindsight is a *****
Old 08-11-2006, 10:25 AM
Jbr8k's Avatar
You can get the battery and or Alt. tested/recharged free at most Auto Part Stores.
I hope it's not the head gasket and something minor.. Good luck.
Jbr8k is offline
Old 08-11-2006, 11:59 AM
89blackse's Avatar
Thanks guys. The alt isnt my main concern right now, the white smoke is.
Now correct me if I'm wrong, but to fix a blown headgasket (if that really is all that is wrong) then I'm going to need:
Upper and Lower Intake gasket
Valve cover gasket front and rear
headgasket front and rear
Is there anything else, tools, etc...
I heard somewhere I will need a special tool to get the heads off.
I assume internetautomart.com is the best place to go may pick up another set of hood struts too.
Old 08-11-2006, 01:54 PM
mod or sell?
internetautomar's Avatar
I'm thinking that you now have a bad intake gasket.
run a compression check on all cylinders.
I doubt the blown head gasket.
internetautomar is offline
Old 08-12-2006, 08:35 AM
vansskaterfreek's Avatar
it sounds like you are getign too much fuel and not enough air.... or you have an intake gasket problem.....one of your injectors may be clogged from sitting maybe?
vansskaterfreek is offline
Old 08-28-2006, 10:46 AM
89blackse's Avatar
BUMP!
Update:
I know a friend who's Dad knows a brother, who knows a friend who thinks he can remove my engine, tear it down, replace all the gaskets from the heads up and replace the clutch for 1G ($1000) parts and labor.
1.) Is this a good deal?
2.) Should I buy the parts myself? If so how much would labor run for a job like this?
I'd like to buy the gaskets from the resident parts-ore but I may buy the clutch kit local from a member of lexistreets.com cause I still don't really know what clutch to get yet.
Thanks guys
Edit: O I'll prolly be adding a new alt and battery to the mix as well. That should take care of everything.
Old 08-28-2006, 05:34 PM
Alex_V
Buy a clutch your self. You have a boosted max that needs a STRONG clutch, he may buy a stock one and pocket the money. Check out the other boosted 3rd gens and the FI fourm for clues on which one to get.
~Alex
Old 08-28-2006, 06:37 PM
Get Off My Lawn
Chris Gregg's Avatar
Water in oil? Oil in your water? Did you do the compression check as suggested? I might be off base, but my first thought was rings. Let us know what you find.
Chris Gregg is offline
Old 08-29-2006, 03:37 AM
89blackse's Avatar
Good idea Alex_V, that would be a nasty surprise after 10k miles I'm sure.
No not yet Chris, work has been relentless, just this week I'll be putting in 7 12hour days in a row! However I have some time off coming up this weekend and will try my damn'dest to do the compression check. I'll post the results here so you guys can do a logic check on my findings.
Either way I won’t be able to pay for any of this till the end of next month
Old 08-29-2006, 04:39 AM
sublunary's Avatar
first time ive ever heard of anyone turboing a ve30de and i never knew why no one did. every turbo ive seen on here was done on a vg
sublunary is offline
Old 08-29-2006, 05:29 AM
Hectic's Avatar
brad92se has a sick black turbo max. probably a couple others. i think it's tougher with the variable timing and all. just a guess though.
Hectic is offline
Old 08-29-2006, 07:37 AM
yottabit's Avatar
Is your maxima the one on streetfire?
http://videos.streetfire.net/search/...b2faebbe37.htm
Someone has a turbocharged ve on there but its listed as a 93..
Anyways all I know is check your oil for white gunk and check your antifreeze for bubbles or oil.
yottabit is offline
Old 08-29-2006, 07:53 AM
89blackse's Avatar
Yeah I've see that car on cardomain somewhere, looks like crap on the inside IMO, you can see some of if you look at his steering column, the way it's painted. nasty
Although my gauge cluster is just as nasty.
Old 08-29-2006, 08:24 AM
2 VE's are better than one!
James92SE's Avatar
That sucks real bad. Did you contact the guy you bought it from? Or has he disappeared now that he's got the money?
James92SE is offline
Old 08-29-2006, 08:30 AM
89blackse's Avatar
The former owner was Maxtuned as known on the .org he has my money so he is good to go. Of course the car ran more or less perfectly when I test drove it, and of course he said that it was my driving that has brought all this out...whatever I've moved onto paying this beast off and fixing her at the same time. Not too sure how much longer my 89 is gonna hold together though
He does want to see the clutch when it comes out, so maybe he does care...
Old 08-29-2006, 09:03 AM
Alex_V
the 93 in the video is 93GXEturbo's.
What clutch did the car have in it? The FI guys seem to be raving about the centerforce 6 puck clutch.
~Alex
Old 08-29-2006, 10:10 AM
89blackse's Avatar
~Alex
Claimed Spec stage 2 clutch.
Here is the f/s listing:
Old 08-29-2006, 10:35 AM
Hectic's Avatar
i feel bad for you man. i'm sure you paid a decent chunk for that car, drive it for a couple months and it farts out on you. just not fair. hopefully you get it up and running without any big loss. good luck.
Hectic is offline
Old 01-05-2007, 07:11 PM
Taking my Maxima to the Max!
mrkanda's Avatar
Digging up old threads is my game
So, what became of this car? Did you get it fixed? How's it running?
Currious....
mrkanda is offline
Old 01-05-2007, 08:13 PM
89blackse's Avatar
it is still not up and running. I lost my job in Dec so I may have to sell it as is to help pay rent, but I doubt I could do that to her.
In other news it still smells nice on the inside.
halfpol
10-17-2022 12:16 PM
MaximaDrvr
08-19-2015 08:20 PM
MikesChevelle
08-06-2015 11:36 AM
Quick Reply: My Maxima = teh suck
