Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-22-2001, 09:09 PM   #1
My wife's 93 Maxima's antenna won't go down when you cut the radio off. You can hear the antenna motor run and then cut off but antenna does not move. You can't push it down by hand either. Can someone give me some help with this problem?
Thanks Very Much.
spurgeonchapman is offline   Reply With Quote
Old 06-22-2001, 10:22 PM   #2
Quote:
Thanks Very Much.
Search.
__________________
2008 Infiniti M35
ARC 4200SE
ARC 2300SE
ARC Flatline 12D2
Rainbow CS 365 Profi
C-Dawg is offline   Reply With Quote
Old 06-22-2001, 11:33 PM   #3
90maximaSE
I hear you.....
Thanks Very Much.
Man my 90 Maxima does the same. The motor is burned out that is why it does that. You would have to replace the motor to get that fixed. & I don't know how much that would cost.
Old 06-22-2001, 11:43 PM   #4
Re: I hear you.....
Quote:
Are you positive its the motor? It could be the mast.
superdesi is offline   Reply With Quote
Old 06-23-2001, 09:27 AM   #5
Re: I hear you.....
If you can hear the friggin motor, then IT is not broken. The mast is messed up. If you do a search for a power antenna I am SURE that you can find an answer to this problem. I have posted the answer 3 separate times that I can remember.
__________________
2008 Infiniti M35
ARC 4200SE
ARC 2300SE
ARC Flatline 12D2
Old 06-23-2001, 03:48 PM   #6
Re: Re: I hear you.....
Quote:
Well my problem is definately the motor, since when I completely disassembled the antenna, I found the mast in good shape.
Lucky for me I bought a brand new antenna assembly (OEM) for $50.
Old 06-24-2001, 01:34 AM   #7
90maximaSE
Re: Re: Re: I hear you.....
Thank you, I knew it could be the motor. But someone just wanted to run their mouth. Anyway my motor is burned out too.
Old 06-25-2001, 12:09 AM   #8
Send a message via AIM to Mr. Nismo Send a message via Yahoo to Mr. Nismo
It is your antenna mast, it could be broken in more that one place and that it is why you cant push it up or down.
Mr. Nismo is offline   Reply With Quote
Old 06-25-2001, 08:05 AM   #9
Quote:
Thank you. My thoughts exactly.
__________________
2008 Infiniti M35
ARC 4200SE
ARC 2300SE
ARC Flatline 12D2
Old 06-25-2001, 08:07 AM   #10
Re: Re: Re: Re: I hear you.....
The guy said that he could hear the motor running but the antenna would not move. That is why I said the mast was messed up. I ain't flaming on anybody.
__________________
2008 Infiniti M35
ARC 4200SE
ARC 2300SE
ARC Flatline 12D2
Old 06-25-2001, 09:58 AM   #11
He's Baaack!
PrinzII's Avatar
Send a message via ICQ to PrinzII Send a message via AIM to PrinzII Send a message via MSN to PrinzII Send a message via Yahoo to PrinzII
I have had this issue since I have had my Maxima. I went to a shop and they told me it was the mast. The technician told me that the rubber seal around the mast has become more constrictive over time and will not allow the antenna to retract fully. I already have an appointment to fix this ($145) but I would love to do this cheaper.
__________________
Shift_Cactus
Quote:
Originally Posted by Fishhunter911
We do things our way, I am sorry if yo do not like it. Rules get broke, things get done about it. end of story....
Quote:
Originally Posted by AM_BlackMax View Post
some people are better persons when they say NOTHING
PrinzII is offline   Reply With Quote
Old 06-25-2001, 11:43 AM   #12
jav5150
fixed it..
Quote:
Hey, fellas..it's a simple fix. You need to order the part from the dealer. There's two little slots on the top ring around the antenna shaft (mounted to car) Tap the ring in a counter clockwise motion..it will screw off. You will then be able to pul the antenna out. You will find what looks like a white plastic (rip cord)..remeber these from toys when we were kids...that cord needs to be replaced..and then (From an on posotion) the new cord with antenna can be fed into the shaft...good luck. This should be fairly easy.
Old 06-25-2001, 11:50 AM   #13
Are you talking about the little rubber O-ring? I have thought about taking mine off. I have yet to have a problem with the antenna again since I replaced it but I was just curious.
__________________
2008 Infiniti M35
ARC 4200SE
ARC 2300SE
ARC Flatline 12D2
Old 06-25-2001, 03:45 PM   #14
It can be one of two things
First, pull the mast off (gently) and examine it. If it seems like all of the teeth are present, then turn on/off the radio with the mast out.
If the motor turns for only 2 seconds, then the motor is bad. But if it turns and the gears churn, then it just probably needs a little lithium greasing inside.
77% of the time, it is the mast. But it ALSO can be the motor, as it was in my case.
Old 06-25-2001, 04:12 PM   #15
Re: It can be one of two things
In your case it was the motor but it may be that the mast is broken in more than one place. Even if you pull ot the mast there may be other fragments of the mast stuck inside. In order to find out whether there are more pieces that are stuck inside is to pull out the motor and disassemble it. Also check the teeth to see if they are worn out and the base of the mast to see if it is broken.
Old 06-25-2001, 08:21 PM   #16
Re: Re: It can be one of two things
Thanks for all the info. I am getting new mast to start out with. Problem is I have removed the chrome ring and still can not pull the mast out of the car. Can't pull it out and can't push it in. Whats the scoop on this? It is presently fully extended.
Old 06-25-2001, 08:28 PM   #17
jav5150
Re: Re: Re: It can be one of two things
You will have to remove the motor through the access panel located directly to the right as you open your trunk. It is a *****, but I've dealt with worse. Good luck, bro.~J~
Old 06-25-2001, 10:47 PM   #18
Have someone help you by turning on and off the radio. That will give you a little leverage.
Old 06-26-2001, 06:18 AM   #19
Send a message via AIM to GoLdEn MaX Send a message via Yahoo to GoLdEn MaX
I had the same problem, ur probably goin to need a new one. It cost me $100 for a new power antenna, including install..
__________________
Looking for a 97 and up max in ny. Email me.
GoLdEn MaX is offline   Reply With Quote
Old 06-26-2001, 08:22 PM   #20
Antenna Won't Go Down
Ok people, it was the mast. Motor is OK. Got new mast from dealer at 33.00. Piece of old nylon cable was hung in motor so I had to take out the whole thing to get it out. Reinstalled it and fed the new mast cable into the motor.
Problem: Antenna sticks up about 2 inches. What did I do wrong?
You can only feed in so much cable before the motor picks it up. Looks like cable may be too long.
I sincerely appreciate the help so far and maybe someone has the answer to help me finish the job correctly.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
