only running on 5 cyl
Old 07-19-2006, 12:08 PM
4thgradedropout's Avatar
ok so my car has been running verry rough latley we checked all the spark plug wires when wire one is removed there is no change in idle but all the rest a drop accurs. we checked the pressure and it is at 120. we cleaned all injector connectors. you can here injector one clicking on but it still is only at 5 cyl..any idea?
4thgradedropout is offline
Old 07-19-2006, 12:50 PM
¯\(°_o)/¯
Greeny's Avatar
120 is a little low compression,i would make sure it is not a bad spark plug wire or spark plug.Try switching the wire to another cylinder and see if the miss transfers to the other cylinder,same with the spark plug ..
If they check out ok,then it may be the injector..
Greeny is offline
Old 07-19-2006, 01:24 PM
mtcookson's Avatar
120 is quite low. is that 120 on a single cylinder or multiple?
mtcookson is offline
Old 07-19-2006, 01:33 PM
¯\(°_o)/¯
Greeny's Avatar
I may be due to the cylinder being saturated with fuel..
Greeny is offline
Old 07-19-2006, 09:22 PM
the spark plugs seem fine my dad said it was burning to white meaning it was not getting enough fuel
Old 07-20-2006, 04:57 AM
mod or sell?
internetautomar's Avatar
so your injector is plugged, pull them and get them cleaned. as long as they all ohm out good you should be ok with getting them cleaned. otherwise replace with new ones, because when one goes the others usually aren't far behind.
internetautomar is offline
Old 07-22-2006, 02:14 AM
TxMaxima93's Avatar
what is the avg price on injectors I think I maybe having the same problem. Also my lifters on my hood are shot are they easy to replace i picked up 2 for 29 each at AutoZone.
TxMaxima93 is offline
Old 07-22-2006, 09:09 AM
so you what can i clean them with?...we used carb cleaner to clean the connections....
Old 07-22-2006, 07:33 PM
mod or sell?
$95 an injector for your car.
Old 07-25-2006, 08:16 AM
colinnwn's Avatar
I support (and generally do) give my business to members of the forum (ie. InternetAutomar and Kaleb from Courtesy Nissan).
But... I am working on replacing 3 injectors for a car worth less than $500. I looked for as cheap as I could get. I had several sources strongly discourage me from using rebuilt Nissan injectors. Apparently they are not really rebuildable and frequently don't even last their warranty period.
Parts America has new Beck-Arnley injectors for your car for $57 plus $9 core and free shipping. I would plan on eating the core charge, because I was unable to get the injectors out of my 1990 without destroying the top of the injector with channel locks. Good luck.
colinnwn is offline
Old 07-25-2006, 05:31 PM
mod or sell?
if there is a core, then they aren't new. or PA screwed up <- more likely
there is a cheap new injector but it is absolute crap.
I'd recommend used over rebuilt any day of the week
let us know if they are new or rebuilt.
they may just be reboxed Venom injectors which means you'll have to do the job twice (or 3 times as was the case with one set i sold)
Old 07-25-2006, 05:35 PM
¯\(°_o)/¯
Greeny's Avatar
I have a set of six used injectors still in the rail,110,000 miles on them..
For sale...
Greeny is offline
Old 07-25-2006, 07:35 PM
aminus21's Avatar
If you are on a budget, I would definitley recommend used over rebuilt. Even though the reman ones usually come with a lifetime warranty, whereas used would come with no warranty, reman ones have a very bad record of failing..And though u would get your next set free, i wouldnt wanna go through all the labor again....Get used or new OEM....
aminus21 is offline
Old 07-26-2006, 09:43 AM
mod or sell?
OEM = Bosch
Old 07-26-2006, 02:43 PM
ok so here is the deal i will be selling the car before winter and leaving maximas. i have had way to many problems(all four struts bad/broke window regulator/broken speedomiter/warped roaters/bad cv right side shaft/all motor mounts bad/replaced left and right controle arm and passenger side wheel baring/2 oil leeks/two exshaust leeks/and new tires) and that is just major items. now i have loved my maxima don't get me wrong but i am just looking for a quick fix so i can sell it. i have spent way to much money on a car that blue books at $885 and looking into something newer..so should i go rebuilt or just go to a junk yard or try cleaning them?..(sorry about typos)
Old 07-26-2006, 06:55 PM
mod or sell?
Junkyard off a running motor
Old 07-27-2006, 05:14 PM
Jon94SE's Avatar
couldn't it also be from an ignition problem? I'm having that problem myself intermitently
Jon94SE is offline
Old 07-27-2006, 09:26 PM
no the car starts just fine and i think we found out it is bad piston...
Old 07-28-2006, 03:21 AM
¯\(°_o)/¯
Greeny's Avatar
I have pistons too...
Greeny is offline
Old 07-28-2006, 06:11 AM
"and falling like a rock"
89blackse's Avatar
hahahahaha, you sure you're not "The Parts *****!!" in this thread...
89blackse is offline
Old 07-28-2006, 08:19 AM
aminus21's Avatar
pretty normal for a 15 yr old car...
aminus21 is offline
Old 07-28-2006, 08:42 AM
¯\(°_o)/¯
Greeny's Avatar
Greeny is offline
Old 07-28-2006, 09:24 AM
what is the fireing order of the injectors?/spark plugs?
Old 07-28-2006, 09:33 AM
mod or sell?
Old 07-28-2006, 01:36 PM
maximus104's Avatar
is the firing order the same for the VE
maximus104 is offline
Old 07-28-2006, 01:44 PM
¯\(°_o)/¯
Greeny's Avatar
Yes.
Welcome to the org..
Greeny is offline
Old 07-29-2006, 02:33 PM
anyone now anything good to take of the gree gung that grows on the connectors for the fuel injectors?
Old 07-29-2006, 02:45 PM
¯\(°_o)/¯
Greeny's Avatar
I used a small wire brush...You can get them at wallyworld for a few $$
Greeny is offline
captchaos
03-15-2016 12:18 PM
junito1
09-23-2015 12:14 PM
JoshG
51
09-21-2015 10:41 PM
RWCreative
09-21-2015 11:01 AM
ballerchris510
09-10-2015 09:35 PM
Quick Reply: only running on 5 cyl
