Timing on SE
Timing on SE
I was just checking the timing on my 92 SE and it was quite variable. I put my timing light on the loop by the power steering reservior, and pulled the connectors for the AAC and throttle sensor. When I checked the timing the mark on the pulley would jump back and forth on both sides of the timing pointer. It's been my experience that the timing mark usually stays at the same place when the light fires, until you adjust it. Is this bouncing back and forth normal? Or is it an indicator of a timing problem, such as a bad position sensor?
I just rebuilt the VTC's and replaced the timing chain tensioners, since one was bad.
The car has a stumble or hesitation on take off from a stop. The rest of the time the car runs fine, but when the car is warmed up and I pull off from a stop, there's a hesitation or two, like it wants to stall, then when the rpm's start to rise it takes off and drives normally.
It sounds like you may be a tooth off on the timing. Did you turn the engine over a few times with a ratchet (not running) to see if the timing marks still lined up afterwards? I can't think of anything else that could have went wrong with that install.
sctludwig
09-01-2022 01:32 PM
kjlouis
10-03-2015 05:29 AM
trungg86
09-04-2015 04:58 AM
