How to fix broken lugnut stud
Old 12-27-2005, 10:14 AM
slickblack94's Avatar
Hi. I recently broke off the drivers left front lugnut stud,and was wondering
if it could be pounded out? Or do I need to replace cv half shaft? ty dan
94 maxima se super black
slickblack94 is offline
Old 12-27-2005, 10:33 AM
garbury's Avatar
I have done this in my 240, not in my maxima, but from looking at my maxima FSM it looks to be the same procedure. It is just a stud pushed through the hub. What you need to do is pull the hub assembly out (the part that has all 5 lug studs). Then just hammer the stud out, I used a vice to hold it in place, and an old chevy valve rod to punch the broken stud out. Buy a new stud at a local automotive shop, or dealer. I paid about $1.50 for the stud so price shouldn't be prohibitive. Then once you get the stud out, place the new stud in and either hammer that thing back until it fully seats, or use some sort of trick. One thing I learned afterwards is you can use the lugnut to draw the stud all the way up to the hub just by tightening it. After that you're all set, just stop torqueing your lugnuts like the Hulk and use a torque wrench to the right specs (72-87 ft/lbs). You'll be surprised how little that is.
garbury is offline
litch
123
01-04-2024 07:01 PM
tarun900
19
12-20-2021 06:57 PM
D Mason
06-21-2016 04:43 AM
leatherneck
09-30-2015 09:16 PM
Quick Reply: How to fix broken lugnut stud
