trouble starting when warm?
Old 11-17-2005, 06:10 PM
4dscPat's Avatar
This started after I replaced my timing belt last week. The car starts fine if it hasnt been started in over an hour or so. It it's warm though, it will crank but not fire. I have to keep trying for a few minutes to get it to fire. Any idea what could be wrong? Last time it happened I'm pretty sure I saw grayish smoke waft up from the tailpipe.
4dscPat is offline
Old 11-17-2005, 06:13 PM
Alex_V
hows it idle air control valve? id pull a plug or 2 and see how they look. mine was like that and i got 6 new free spark plugs and that helped, but changing my iacv with a spare fixed it up. I also cleaned it before i put it on.
~Alex
Old 11-17-2005, 06:17 PM
4dscPat's Avatar
Hmm, my idle is often inconsistant. Would that keep it from starting? When it does finally fire, i have to give it gas for a second or two to keep it from dying.
4dscPat is offline
Old 11-17-2005, 06:20 PM
Suprise butsechs!!!
Dillbag's Avatar
yeah, sounds sorta like the IACV.
Dillbag is offline
Old 11-17-2005, 07:03 PM
decus's Avatar
Run ECU codes, could be a lot of things.
My guess would be CHTS. Seeing as it happened after the timing belt, you may have knocked the connector off/something. The CHTS is not used by the ECU when the engine is cold (closed loop)....hmm, i dont know. just a guess
decus is offline
Old 11-17-2005, 08:31 PM
4dscPat's Avatar
Whats the CHTS?
4dscPat is offline
Old 11-17-2005, 08:41 PM
decus's Avatar
Cylinder head temperature sensor, code 13 when u run the ecu codes.
decus is offline
Old 11-17-2005, 10:40 PM
Way out West
Cliff Clavin's Avatar
usually if you look it up as a part it will be under coolant temp sensor. They are like $20 at NAPA. When mine went out, it did throw a code 13.
Cliff Clavin is offline
Old 11-17-2005, 11:31 PM
decus's Avatar
Yeah, you have to be careful to get the right one. There is a CHTS which is at the front of the motor and another coolant sensor.
decus is offline
Old 11-18-2005, 01:03 AM
¯\(°_o)/¯
Greeny's Avatar
Being you just replaced the t belt im thinking your timing is off a little...
Greeny is offline
Old 11-18-2005, 07:00 AM
Grace_Imports's Avatar
Open loop is cold...closed loop is after warmup
Grace_Imports is offline
Old 11-18-2005, 07:15 AM
mod or sell?
internetautomar's Avatar
the CHTS is what tells the car when to change "loops"
internetautomar is offline
Old 11-18-2005, 07:18 AM
The Bulgarian Guy
maximapitko's Avatar
my bet would be water temp sensor like a few people above...
maximapitko is offline
97_GXE
09-15-2015 06:47 AM
QueensMAX
09-15-2015 04:14 AM
markevans999
09-10-2015 04:29 PM
trungg86
09-04-2015 04:58 AM
Quick Reply: trouble starting when warm?
