Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-11-2007, 12:38 PM   #81
Wanna Go Muddin?
Greeny's Avatar
Quote:
Originally Posted by LI89Max View Post
Funny thing is .....I cant find that thread.
At the top of the page..
*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Greeny is offline   Reply With Quote
Old 12-11-2007, 08:34 PM   #82
Quote:
Originally Posted by the2ndrunner View Post
Its a 1992 maxima SE. Would a turn signal switch from a 1990 work in my car?
Quote:
Originally Posted by internetautomar View Post
Pretty sure not.
if they're both outtry comparing #s
i know this is an old thread, but yes you can. i took apart an older 90ish switch and put the parts into my 92 switch. not a direct swap, but if you're willing to do a little surgery, it should work just fine.
maximal is offline   Reply With Quote
Old 10-26-2009, 09:57 AM   #83
I know this is an old thread but...
When your headlights go on and off randomly and you have daytime running lights (Canadian models) the cause is bad soldering on the daytime running light module (see Greeny's photo (above). Specifically, it is the two relays in the module that actually have breaks in the solder that binds them to the circuit board.
Solution:
1)Locate the module to the left of the steering column - see Greeny's photo (above)
2)Remove the module and extract the circuit board
3)Using a soldering iron, resolder (re-melt) the connections of the relays (they have visible coiled copper wire on them).
4)Insert the board back into its case and tape / tie it back together (because you busted it up when you removed the board)
I ended up resoldering about half of the board, just to make sure. You can find which relay is worse as one will be cooler than the other (after running the car for a bit).
Problem solved!
__________________
Fast and Repairable
Datsan is offline   Reply With Quote
Old 10-26-2009, 10:29 AM   #84
Send a message via AIM to Roymg Send a message via Yahoo to Roymg
Quote:
Originally Posted by Greeny View Post
My car had the same problem except it was the brights that would not work....
I'm glad i could help.......
A headlight on one side was comming on by itself when in a non driving mode and key off. I took out the light sw, module at the steering column and sprayed the contacts with TV Tuner cleaner. I used no sand paper because I did not want to bend the cu. reeds. It worked fine after that. A new module cost about $60 bucks at Nissan.
Roymg is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
