Those with short throw shifters
Old 09-26-2005, 08:10 AM
MaXtUneD's Avatar
When I installed my st shifter, Shifting became notchy.....Like you can feel it going into gear..Its not smooth..
I think I read somewhere that the mounting plate that the shifter goes through has a bushing...
What other parts can I replace to get a smoother shifting between gears???
MaXtUneD is offline
Old 09-26-2005, 08:15 AM
OBEEWON's Avatar
if you tighten the shifter seat too much then shifting will be more difficult. do you have a pacesetter? if you do the ball isnt the best matierial, but if you grease the snot out of it that should help a little.
OBEEWON is offline
Old 09-26-2005, 08:18 AM
¯\(°_o)/¯
Greeny's Avatar
Mine was kinda notchy....then i put some high temp grease on all the pivot pionts..That helped......
Greeny is offline
Old 09-26-2005, 08:37 AM
D-sta's Avatar
I installed a stillen short shifter and no problems whatsoever. Just on the install the first time, I installed it a bit too tight and then loosened it and it's been great eversince.
-Diego
D-sta is offline
Old 09-26-2005, 08:50 AM
¯\(°_o)/¯
Greeny's Avatar
-Diego
Yea...I also loosened the bottom bolt a little when i greased up the ball and the bottom part.....If you get it too tight it will be hard as he!! to get in gear...
Greeny is offline
Old 09-26-2005, 09:41 AM
MaXtUneD's Avatar
So Im guessing their aren't any bushings that I can replace to help smooth it out?
MaXtUneD is offline
Old 09-26-2005, 09:44 AM
¯\(°_o)/¯
Greeny's Avatar
No need to do that unless they are bad.....Just try some of things mentioned above and it should smooth out for ya....
Greeny is offline
Old 09-26-2005, 09:52 AM
I'm needing a caw
Jeff92se's Avatar
You can't get away from the phyiscs. Nissan crappy tranny + short throw shifter = notchy like a *****. You can run synthetic and keep the adjustment to about 50% shorter but it only helps it and doesn't eliminate the notchiness.
Jeff92se is offline
Old 09-26-2005, 11:38 AM
MrGone's Avatar
along with replacing, or filling the actual rubber shifter bushing.
MrGone is offline
jmlee44
10-02-2022 02:13 PM
Fbana41
08-29-2016 12:18 PM
maxinout93
10-31-2015 02:04 AM
atriuum
09-28-2015 01:19 PM
Quick Reply: Those with short throw shifters
