What should I use to fill my motor mounts?
Old 09-25-2005, 01:27 PM
4dscPat's Avatar
My front motor mount is toast, and I want to fill it wity some type of polyurethane. What product do you reccomend? I have heard both good ad bad things about Window Weld.
4dscPat is offline
Old 09-25-2005, 02:20 PM
505max94se's Avatar
Do not use window weld. Just get the regular 94a polyurethane.
505max94se is offline
Old 09-25-2005, 02:27 PM
Im izz sexay
Scope's Avatar
Fill them up with polyurethane.
Scope is offline
Old 09-25-2005, 02:34 PM
MrGone's Avatar
polyurethane
MrGone is offline
Old 09-25-2005, 02:50 PM
kcidmil's Avatar
That way you'll know when they're starting to go again.
kcidmil is offline
Old 09-25-2005, 05:53 PM
4dscPat's Avatar
After some reading, I decided to go with the 60a from mcmaster carr. I wonder if I could do all 4 mounts with 1 pound? I was only planning on doing the broken front mount, but if I have extra I'll do more.
That site has everything I would need to build a 60 foot tall man eating flame throwing destroyer mech.
4dscPat is offline
Old 09-25-2005, 06:14 PM
nismosleeper's Avatar
One pound will work for all of them if you don't spill any. Done it twice. If you are on a budget, window weld does work decent as well, and it probably closer to the 60a. Good luck
nismosleeper is offline
Old 09-27-2005, 01:06 PM
4dscPat's Avatar
Took out my old mount today. I couldnt remove the bolt that goes throug the mount and attaches it to the bracket, so I ended up taking the whole thing out with the engine bracket. Drenched it in liquid wrench, and I still managed to round off the bolt and teh nut head with a 6pt socket.
What now?
4dscPat is offline
Old 09-27-2005, 01:13 PM
Getting back to his roots
Mizeree_X's Avatar
What now?
Cut it off w/ a hacksaw, and buy a new one?
Mizeree_X is offline
Old 09-27-2005, 07:50 PM
If you are talking about the aluminum bracket on the rear tranny mount, then just leave it on. You could also cut it off, but it isn't hurting anything as it is.
Old 09-28-2005, 10:10 PM
Suprise butsechs!!!
Dillbag's Avatar
What's wrong with window weld? I must have missed the poly thread.
Dillbag is offline
Old 09-29-2005, 11:49 PM
89badmaxse's Avatar
marine 5200 thats what i used
89badmaxse is offline
Old 09-30-2005, 06:58 AM
Does that work well? How stiff is it, and do you feel the idle?
Old 09-30-2005, 06:29 PM
NWP Engineering.com
Aaron92SE's Avatar
I used the 80a at www.mcmaster.com. The part number is: 8644K11
1 pound was barely enough for all four of my VE Auto mounts. I spilled a very little bit b/c my duct tape leaked. Trust me, it will leak on you too if you aren't VERY careful about making a good seal with the tape.
Some pics of my polyurethane motor mount job can be found here: http://www.iwdwebdesign.com/maxima/morepics.htm
Aaron92SE is offline
Old 10-01-2005, 12:16 PM
4dscPat's Avatar
Mine leaked hellas. Stupid cheap ducttape.
Man, I should have worn gloves. this stuff is impossible to remove from your hands.
4dscPat is offline
Old 10-01-2005, 01:01 PM
NWP Engineering.com
Aaron92SE's Avatar
Yeah, one thing I found out is when you first mix the resin, don't pour it in right away. That stuff is slicker than oil! It will leak past the duct tape no matter how well you think you sealed it up. But, if you wait a few minutes atleast, it will thicken very slightly. And then you better fill all your mounts very quickly or it will thicken up too much too quickly. Fun stuff! And very messy.
Old 10-01-2005, 10:29 PM
what can my max do for me
DaWifey's90's Avatar
feelin really dumb
guess i have some serious searchin to do...never heard of refilling mounts...have always just replaced them....then again i haven't priced out replacements for the max....gotta love finding out there's more stuff u don't know
DaWifey's90 is offline
Old 10-02-2005, 02:33 AM
OBEEWON's Avatar
use nitrogen, it will give you better gas mileage, and you can cruise at any altitude...
http://forums.maxima.org/showthread.php?t=431777
OBEEWON is offline
Old 10-02-2005, 11:05 PM
89badmaxse's Avatar
it works awesome very nice and stiff. idle isnt to bad car feels normal to me.
AaronL
08-08-2020 10:31 AM
D Mason
06-21-2016 04:43 AM
Unclejunebug
04-02-2016 05:42 AM
knight_yyz
11-01-2015 01:34 PM
Quick Reply: What should I use to fill my motor mounts?
