Your 3rd gen ever leave you stranded?
Old 09-13-2005, 07:38 AM
ArcticDC5's Avatar
Has your 3rd gen ever left you stranded or broke down on the road? What was the cause if it did?
168k thus far and 2 years of ownership with no breakdowns. It did have trouble starting once, but after a few attempts it cranked right up.
ArcticDC5 is offline
Old 09-13-2005, 07:45 AM
MAXI's Avatar
Nope!
MAXI is offline
Old 09-13-2005, 07:46 AM
Pervis Anathema's Avatar
VG - Dead battery
VE - Busted tranny
Pervis Anathema is offline
Old 09-13-2005, 08:05 AM
MrGone's Avatar
Busted starter once
Slave Cylinder once
MrGone is offline
Old 09-13-2005, 08:08 AM
maxitech's Avatar
Starter died once. But it was around town so I wasn't exactly stranded.
maxitech is offline
Old 09-13-2005, 08:18 AM
tripleGmax's Avatar
na .
tripleGmax is offline
Old 09-13-2005, 08:32 AM
¯\(°_o)/¯
Greeny's Avatar
Twice...........Fuel pump both times.....Cheap idiotzone replacements....
Greeny is offline
Old 09-13-2005, 09:30 AM
Getting back to his roots
Mizeree_X's Avatar
Fuel pump once on each of my Maxes. Only the first time was I truly stranded, the second time it wouldn't start in my driveway.
Mizeree_X is offline
Old 09-13-2005, 09:38 AM
¯\(°_o)/¯
Greeny's Avatar
Actually the car never got towed....My wife was driving both times it quit,she called me,i told her to bang on the fuel pump/tank area where the f/p wiring harness goes into the cover plate in trunk.....And she fired up and come on home.....Replaced the pump....
Greeny is offline
Old 09-13-2005, 09:46 AM
STFU n00b!
Matt93SE's Avatar
Yup...
http://www.imagestation.com/picture/...0.jpg.orig.jpg
http://www.imagestation.com/picture/...2.jpg.orig.jpg
Matt93SE is offline
Old 09-13-2005, 09:50 AM
I'm needing a caw
Jeff92se's Avatar
1st: Tore a rod though the block
2nd: Tore up a piston ring. Engine ran but smoked out everyone behind me
3rd: Well technically the car stranded me. Someone drove off in the damned thing! Stupid car, starting and all
Jeff92se is offline
Old 09-13-2005, 09:53 AM
¯\(°_o)/¯
Greeny's Avatar
Linky no worky....
Greeny is offline
Old 09-13-2005, 10:06 AM
Priority05's Avatar
1. Fuel pump
2. Water pump
Anyother time I usually got her home ok. Heck I bought the thing with 75k. and now its 380,000+. Thats not bad!
Priority05 is offline
Old 09-13-2005, 10:42 AM
STFU n00b!
Matt93SE's Avatar
Linky no worky....
1. pic of car being towed off track
2. pic of hole in oil pan with protruding connecting rod.
then again, it had 223,000 miles and it blew at the track.
treat it like a race car, expect to work on it like a race car.
Matt93SE is offline
Old 09-13-2005, 11:17 AM
maximaboi's Avatar
just my flat tire and bent rim . didnt want to start one night but all I had to do was give it a little gas and it never did that again.
maximaboi is offline
Old 09-13-2005, 12:01 PM
505max94se's Avatar
never left me stranded
It almost did when I busted the cv joint/axle. I drove to the mechanic very slowly (only time I let someone else work on my car). It wasn't completely broken until the mechanic test drove it.
505max94se is offline
Old 09-13-2005, 12:12 PM
nismosleeper's Avatar
Two years ago, at 245K the crank snout broke. Paid some smuck 300 to throw in a used vg. He messed up when he did the tensioner on the t-belt, so around 90 miles later, the belt slipped teeth. Then I put an engine in myself, and no problems except a fuel pump fuse yesterday. Very reliable for how hard it is pushed.
nismosleeper is offline
Old 09-13-2005, 12:17 PM
souporman's Avatar
On 2 occasions I was left stranded when the alternator died. Once when the tranny blew.
souporman is offline
Old 09-13-2005, 12:21 PM
OBEEWON's Avatar
Bad maf, car bucked like a horse. Had to stay in a hotel and drive in safe mode the next day for over 60 miles at about 35-40 mph to the nearest place that had a maf. Then had to Sea foam the hell out of it before it would run right. The whole back of my car was black from running rich in safe mode.
OBEEWON is offline
Old 09-13-2005, 01:26 PM
Greenbuggy's Avatar
my '90 did, VG/auto, automatic completely died one day, wouldn't engage in any forward or reverse gear. Had a friend get a truck and pull my dead car to a party where we proceeded to drink ourselves stupid, had AAA take the car home later...
Not all bad tho, this prompted me to find a nice 5-speed car for $300 thru ebay...
Greenbuggy is offline
Old 09-13-2005, 01:51 PM
I miss my VE
VEvolution's Avatar
GXE for 2 years -
1)Transmission
2)Alternator
3)Timing Belt
SE for 1 month -
Thankfully, nothin.
VEvolution is offline
Old 09-13-2005, 02:09 PM
Maxima of the Month Dec. 07
bru91's Avatar
Last thursday it wouldn't start in my garage. Turned out to be the battery.
bru91 is offline
Old 09-13-2005, 02:11 PM
tripleGmax's Avatar
i take mine back, three times ive been stranded because my battery had a leak and would cause a crazy build up of green poop on the battery terminals. that was a pita. now i rock an optima redtop
Old 09-13-2005, 02:34 PM
Brad92SE's Avatar
Once, when I blew my tranny.
Brad92SE is offline
Old 09-13-2005, 02:35 PM
twinkle's Avatar
Only once but it was my fault, I changed an accessory belt, and put the water pump pully on backward, so it shredded the belt, and would have overheated if i had not parked it, so i had to fix it :shrug:
twinkle is offline
Old 09-13-2005, 02:37 PM
maximaboi's Avatar
red tops rule!
Old 09-13-2005, 03:37 PM
Maximan190's Avatar
yes... coming down an on ramp, tranny got stuck in 3rd gear
Maximan190 is offline
Old 09-13-2005, 05:50 PM
vansskaterfreek's Avatar
mine hasnt yet...but many problems are starting to occur
vansskaterfreek is offline
Old 09-13-2005, 05:55 PM
goon9's Avatar
Slave 3 times.
BAttery once.
Thrice because of ignition system.
goon9 is offline
Old 09-13-2005, 06:10 PM
Mattster's Avatar
203400 miles and never broken down when we first bought it like 6 years ago the alternator was bad and kept dying but thats when it was my brothers now it runs nicely.
Mattster is offline
Old 09-13-2005, 06:52 PM
il massimi bassi
96ItaliaSE's Avatar
my first ve never left me stranded...just with whiplash and anxiety from all the bucking and stalling. Damn Coilpacks!
96ItaliaSE is offline
Old 09-13-2005, 07:09 PM
¯\(°_o)/¯
Greeny's Avatar
Greeny is offline
Old 09-13-2005, 07:23 PM
spyhunter84's Avatar
only once and it was an alternator issue
spyhunter84 is offline
Old 09-13-2005, 07:31 PM
mod or sell?
internetautomar's Avatar
left stranded = never (at least it's own fault)
repairs that could have left me stranded? at least once
internetautomar is offline
Old 09-13-2005, 07:34 PM
¯\(°_o)/¯
Greeny's Avatar
Elaborate
Greeny is offline
Old 09-13-2005, 08:13 PM
4dscPat's Avatar
Automatic tranny died on the way to school, had to get it towed. Also lost the waterpump/ps belt tenioner on the freeway, but that was my fault. I was able to limp it into a hotel parking lot a few minutes at a time, and got a ride from my mom. Went back and fixed it in the parking lot a few days later.
4dscPat is offline
Old 09-13-2005, 10:29 PM
maxmaxima91's Avatar
Thankfully in the 65000 miles ive owned my max its never accually been stranded. I did blow a boost coupler on the highway a few weeks ago, but i had already been leary about it so i had taken the tool to fix it with. I quick fixed it next to the highway
maxmaxima91 is offline
Old 09-13-2005, 10:39 PM
hadman's Avatar
Alternator last year, and a bad tranny back in 96. That same tranny is strong as ever btw
hadman is offline
Old 09-13-2005, 10:51 PM
maxima92se's Avatar
mine has 165k miles on it and i have had the alternator go out on me but everytime i used the battery to drive to the shop before the battery went out and this happened twice so never been really stranded and next when my water pump belt broke and i still drove the thing to the closest shop before the thing overheated. but other than that it runs beatifully.
maxima92se is offline
Old 09-14-2005, 12:03 AM
MrGone's Avatar
oh and the starter on mine wasn't too bad because Keelan ran across the street and gave me a push :-) I think Jeff was there when that happened too because I accidently went past the onramp and there were 4 3rd gens pulling illegal u turns lol
Actually now that I think about it, I think Jeff already left.. it was Me, antonthegrey, Spipedong90, and littlepiggie ( ). I remember because I was the fastest one through the I-90 tunnel run and whooped that SLK320
Clutch Master Cylinder was in a parking lot so it wasn't bad, just made me go WTF at first lol. Just bad timing because I was supposed to be meeting up with es_amixam and Jeff92se. antonthegrey wouldn't let me borrow his car either . The worst part about that is it had just flash hailed about 1.5" of hail and then anton's car was broken into about 10mins before he got off work and I had to leave mine in the same parking lot... Worst night of my life, I was almost certain there would be a few thousand dollars of stuff missing from my car (and I had already spent 30mins gutting my car :-( )
AAA+ membership > *
one tow home pays for the entire membership :-D
no more modified daily drivers for me though
MrGone is offline
Quick Reply: Your 3rd gen ever leave you stranded?
