starting/power issue
ok i havent seen any threads with anything like this before but if there are could someone point me to them.
heres the deal twice this week i've gone out to my car and it won't start, it wont even crank, heres the strange part when i first get in the car all of my dash lights will turn on and the seat belt will cycle but when i turn the key i lose all power. the first time it happened i pulled the battery cable and touched it to the terminal and there was no arc so i thought "great i have a drain somewhere and the battery is dead", so i leave and about an hour later my buddy comes and gets ready to give me a jump, just to humor myself i try to crank it one more time b4 we hook up the cables and lo and behold it starts up like nothing....
then this afternoon i go out and start it and i have the same problem, so i pull the neg. cable and it arcs i put the cable back on and try it and it starts right up, whats the deal anybody ever had anything like this before? just to clarify there was no cranking at all no noise of any kind i dont even remember hearing the fuel pump click running.
thanks this sucks because because i'm at school now and this isnt a problem i want to have right now.
My guess would be the battery terminals, As you said that you took off the positive and there was no arc? well if the negative post is not making a connection it wouldn't arc. Then you said that when you took off the negative and it arced and then you put it back on and it started! right? I'd say that your problem is a bad ground at the battery.
Check and clean all your connections on the positive and negative cables on both ends of them....sounds like you have a loose connection....
here is the part i would like to stress, when i first got in the car i had power-lights, seat belt, warning chime, when i turn the key to start the engine i loose it all and it doesnt come back on.
i dont think it is the alt. because that has no effect on the starting of the car unless it didnt charge the battery when it was running i dont think that would be an issue, and since the car started up right away when it did start i dont think the battery has a low charge.
Originally Posted by Josh
the cables have all been off it the past 3 months and the connections cleaned.
I'm not just talking about the cable connections on the battery...I am also talking about the other ends of them same cables....The starter conn....and the ground connection to the engine block....
...i loose it all and it doesnt come back on.
"thanks this sucks ... isnt a problem i want to have right now."
- all problems suck. Thats what Life is all about. Tune on this: heaven is destination.
- all problems appear at worst possible time. LifeTime...
1. Even New Battery may have internal cut, awakened by 500A draw. Small few amps pwr for lights etc will still be possible.
2. Power is delivered via cables to starter solenoid. Take both on the floor and tHeres u problim. Throw em at the laughing magpie, DIY new and better.
http://www.cardomain.com/ride/748507/10
3. Solenoid is energized via relay, I u are so confident, no problem bypAssing. That really doesnt hlp if no juice. http://www.cardomain.com/ride/748507/5
I bet its no.1.
Or its 1.b; caused by alternator rectifier [drying the battery overnight]
swapped like this, clic on http://www.cardomain.com/ride/748507/23
03-12-2020 12:06 AM
BrandonCause
09-14-2015 10:41 PM
