headlight issues
Old 05-03-2005, 07:06 PM
mtnbikeair's Avatar
headlight issues
My right headlight wont turn off. From the time i bought the car about a month and a half ago the right headlight wont turn off. I have just left it unplugged because i have had more things to work on, and now i have made it far enough on my list to fix this problem. If the headlight is plugged in it is always on, when i turn the car/lights off it stays on. So any ideas?
mtnbikeair is offline
Old 05-03-2005, 07:17 PM
maximal's Avatar
fix the light switch. take it apart, clean the contacts, and bend the metal a little bit so that it's not making contact in the "off" position. or you could just get another light stalk/stem (whatever you call it).
maximal is offline
Old 05-03-2005, 07:18 PM
mtnbikeair's Avatar
The left light goes off though. Its just the right one that stays on. The light switch works fine, it controls the left one like it should. The right one just has a mind of its own... so i doubt its the light switch itself...
Old 05-03-2005, 07:35 PM
maximal's Avatar
well, it wouldn't hurt to check. that's how i fixed mine. my right high beam wouldn't turn off, and when i took it apart, i noticed that it was making a connection in the "off" position.
maximal is offline
Old 05-03-2005, 07:37 PM
mtnbikeair's Avatar
Well if you have taken yours apart, whats the easiest way to get in there?
Old 05-03-2005, 07:55 PM
maximal's Avatar
i think all you have to remove is the steering column cover (right behind the steering wheel). i think there were 6 screws holding it in. then 2 screws hold the switch in.
maximal is offline
Old 05-04-2005, 06:53 AM
mod or sell?
internetautomar's Avatar
I'd check the relay
internetautomar is offline
Old 05-04-2005, 06:55 AM
mtnbikeair's Avatar
Well i got my dad to look at the repair manual which has the wiring diagrams because we thought it was the relay, but according to that manual there isnt a relay... can you tell me where the relay is, or direct me towards information about it? Thanks buddy
Old 05-04-2005, 07:07 AM
Wiking's Avatar
High time have functional lights - and a relay. Better to see... Use your functional light as source for the relays.
http://www.cardomain.com/memberpage/748507/11
Wiking is offline
Old 05-04-2005, 05:11 PM
ItsNoMaxima's Avatar
Also take a look in the underhood fuse block to see if the fuse is burned or melted. First guess woud be the relay, second burned wiring. I had a problem with mine that hte headlight would not turn on. Now it's jsut mickeymoused to the left side so they both light up and function properly.
ItsNoMaxima is offline
Old 05-04-2005, 07:17 PM
mtnbikeair's Avatar
Can anyone tell me where the relay is specifically? The diagrams will help me, but i havent found the thing yet...
Old 05-04-2005, 08:14 PM
tripleGmax's Avatar
do yu have the fsm? that might help. pm me bout it.
tripleGmax is offline
03-12-2020 12:06 AM
MaxLife17
06-27-2019 01:37 PM
Vistance
09-17-2015 05:17 AM
mpbclutch33
09-08-2015 06:21 PM
MaxLife17
09-08-2015 02:36 PM
Quick Reply: headlight issues
