I need to correct procedure of bleeding cooling system
Old 12-22-2004, 03:13 AM
barmaglot's Avatar
I need correct procedure of bleeding cooling system
of Maxima J30 VG30E.
I know, what nissan publish a special TSB about this. And standart bolt for bleed sysstem does not work properly.
Please, give me a link to this TSB if you know.
Sincerely yours
Stanslav aka Barmaglot
Moscow, Russia
www.clubmaxima.ru
barmaglot is offline
Old 12-22-2004, 05:20 AM
¯\(°_o)/¯
Greeny's Avatar
Here is a link...http://www.autozone.com/servlet/UiBr...3d801f449f.jsp
Welcome to the org....
Greeny is offline
Old 12-22-2004, 05:53 AM
barmaglot's Avatar
Thanks!
This procedure is known to me, but i read some time agow nissan TSB, about this. Now i miss link to this TSB.
The air bleed port plug dont bleed all air bulbs. And nissan recomend lift front of the vehicle about 3 feets, open radiator cap, and race engine ~2000 rpm about 10 minutes, until air bulbs comes out from radiator. After that fill radiator fully, close radiator cap and fill coolant tank to MAX level.
I not 100% sure in this, but i look for link to this TSB
Old 12-22-2004, 06:05 AM
Wiking's Avatar
- TSBs http://maxima.theowensfamily.com/tsb
- The only way is to get all air out in extreme difficult cases, is to open the bleed valve tiny bit, drive one hour (over2500rpm) adding juice. Close. Done.
- Cooling - Maxima.org last/this week:
http://forums.maxima.org/showthread....=1#post3499240
http://forums.maxima.org/showthread.php?t=361759
http://forums.maxima.org/showthread.php?t=362106
http://forums.maxima.org/showthread.php?t=363118
http://forums.maxima.org/showthread.php?t=360258
Wiking is offline
Old 12-22-2004, 06:06 AM
Ad·min·is·tra·tor
DanNY's Avatar
Originally Posted by barmaglot
Thanks!
the procedure is what i usually do...but my driveway is on an incline so i don't have to jack the car up...but this method works.
DanNY is offline
Old 12-22-2004, 06:15 AM
barmaglot's Avatar
I use this procedure too. It works good, but i bet with friends about this, and need this article.
Early i find this TSB in tis forum, 1 or 2 years agow, but now search function is stopped :-(
Old 12-23-2004, 07:14 AM
aziphrale's Avatar
If you look below at wikings post. he gave the tsb at the top. If you go to that page it has it there in pdf form. just as nissan sent it out. I just did this last week and it owrks great.
aziphrale is offline
Miket2006
03-01-2021 03:55 AM
Socalstillen
09-26-2015 12:01 PM
Colossus
09-09-2015 05:46 AM
Quick Reply: I need to correct procedure of bleeding cooling system
