ECU Pin/Wire diagram?
Old 12-01-2004, 05:59 PM
Roo
Roo's Avatar
someone have a link to a ECU Pin/Wire diagram online?
bummers i can search the forum, that feature needs to come back!
long story short, i figured out my issue, computer somtimes wont kick on...
want to hardwire the ECU... need to know ground and power...
oh, car is a 1993 gxe i believe...
i tried looking here:
http://www.apexi-usa.com/productdocu..._safc_wire.pdf
http://www.apexi-usa.com/productdocu...AFC2Wiring.pdf
because they list most ECU layouts for installing an AFC, figured i could get the info from there but don't see maxima? is the maxima known as something different in japan or something?
-Roo
Roo is offline
Old 12-02-2004, 08:52 AM
MAXI's Avatar
try craig's how to site. i believe link is in the stickies.
MAXI is offline
Old 12-02-2004, 09:08 AM
Roo
Roo's Avatar
actually i found it and the wiring diragram on there...
unfortunatly is does not color code
so kind of confused as how to figure out which is which...
-Roo
Roo is offline
Old 12-02-2004, 10:32 AM
PRPmax's Avatar
what year is your car? I can get you the color break down and diagram.
PRPmax is offline
Old 12-02-2004, 10:34 AM
Roo
Roo's Avatar
1993 GXE... you rule dude!
-Roo
Roo is offline
Old 12-02-2004, 10:55 AM
PRPmax's Avatar
what engine do you have 12valve or 24valve?
PRPmax is offline
Old 12-02-2004, 11:21 AM
Roo
Roo's Avatar
sorry im a 300zx TT and Miata expert... heh
this maxi-pad is my daily driver...
although its mint with 50,000 miles, electrical issue up the **** with it... if your curious, here is the orginal post i made about this car with the problem i was having:
http://forums.maxima.org/showthread.php?t=342383
the third post from the bottom that Metho's made is 100% right... i made access to the ECU and could verify that in fact when the check engine light is on, ECU is on... when check engine light is off, ECU is off... whats weird is no matter what you can hear the ECU try to come on and can see some light coming out the window on the ECU (a bright white light of sort)... but only when the green and red LED light come on is when the ECU is at full power and the check engine light comes on and car goes vroom...
i know the maxima motor is pretty much a NA-Z motor for the most part...
this is what is printed on the VIN plate for engine type: VG30 (E)
this help you at all?
-Roo
Roo is offline
Old 12-02-2004, 11:45 AM
GRNMAXDMON's Avatar
'89-'94 SOHC SE & GXE = VG30E 12valve
'92-'94 DOHC SE = VE30E 24valve
GRNMAXDMON is offline
Old 12-02-2004, 11:47 AM
maximagxe90's Avatar
Hi,
first check on your vin for the engine that came with the car,
if it says h then you have a vg,
if it says e then you have a ve,
and it should say what kind of engine came with your car on the firewall,
if it say vg30 (e) then you have a vg30e,
if it say ve30 (de) then you have a ve30de,
maximagxe90 is offline
Old 12-02-2004, 11:53 AM
Roo
Roo's Avatar
i just stated this heh
looks like i have the 12 valver...
damn, V6 with 2 valves per cylinder... thats blows
-Roo
Roo is offline
Old 12-02-2004, 12:06 PM
GRNMAXDMON's Avatar
yeah it sucks a$$ doesn't it.
Old 12-02-2004, 12:10 PM
Roo
Roo's Avatar
eh, whatever don't really care its just the winter car...
im 100% positive doing a hardwire to the ECU will solve my problem... def. a grounding/relay issue going on somewhere.
-Roo
Roo is offline
Old 12-02-2004, 12:20 PM
GRNMAXDMON's Avatar
well good luck
Old 12-02-2004, 03:56 PM
Roo
Roo's Avatar
here, this is actually what im looking for, something like this!
this is a pic i took from my 91' TT 300zx's FACTORY SERVICE MANUAL...
any of you have a FACTORY SERVICE MANUAL with this type of diagram that you could just possibly scan these couple pages for me?
-Roo
Roo is offline
Old 12-02-2004, 05:16 PM
PRPmax's Avatar
Go here man... you'll love it
http://forums.maxima.org/showthread....=1#post3445409
PRPmax is offline
Old 12-02-2004, 07:08 PM
mod or sell?
internetautomar's Avatar
You do realize that hardwiring the ECU will only cause the ECU to short out because your aren't fixing the cause.
internetautomar is offline
Old 12-02-2004, 09:23 PM
Roo
Roo's Avatar
alright, then how would you go about solving this particular problem?
im all ears!
-Roo
Roo is offline
Old 12-03-2004, 05:39 AM
mod or sell?
this is one problem that has to be fixed with a multi-meter and possibly a scope.
you shouldn't try to have it diagnosed over the internet.
just my .02
Old 12-03-2004, 04:46 PM
Roo
Roo's Avatar
im not trying to do a full diagnoses over the internet, but isn't human nature to explain whats going on to other people and see what there input is on the matter if in a bind?
-Roo
Roo is offline
Old 12-04-2004, 03:39 PM
mod or sell?
it wasn't meant as an insult, but too many people think any problem can be diagnosed over the internet.
well they can't
and when it comes to problems with wiring and you apparently already know which wire.
Wouldn't it make more sense to track down the flaw and fix it?
Old 12-04-2004, 04:14 PM
maxmiles's Avatar
You said some times it works and sometimes it doesn't right??
I would definatly check the relays for the ecm/efi systems. They are kinda common.
maxmiles is offline
Old 12-04-2004, 04:21 PM
Roo
Roo's Avatar
correct it only happens sometimes...
yep - relays are on the list of things to check/replace...
btw, is there a way to pull the relay and test it?
-Roo
Roo is offline
Old 12-04-2004, 04:30 PM
mod or sell?
swap the relay for a known good one.
it's the time tested way.
gigabyte
01-06-2017 06:05 PM
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
BLACKKILA.GTR
09-29-2015 11:23 AM
QueensMAX
09-15-2015 04:14 AM
Jamie Bowen
09-06-2015 09:59 PM
Quick Reply: ECU Pin/Wire diagram?
