Deactivating Stock Alarm
i have a aftermarket alarm on my 92 gxe and sometimes when i unlock the car with my remote the stock alarm goes off and its really annoying can someone tell me how to deactivate the stock alarm so it wont go off any more when i open my doors
Will
Will
Do you carry your key on your remote entry fob?
When the stock alarm is going off, a) stick the key in the driver's door lock, b) lock the door manually, c) unlock the door...
Very simple and doesn't involve having to unplug the stock system.
Mine does this every once in a while also. Don't quite understand why, but the solution seemed easy enough.
Best thing to do is take it back and have em do it right. They screwed up like that on an install on one of my Nissans, I fixed it myself so that wouldn't happen. You need to have it set up so when it arms it arms factory alarm and disarm does likewise. Believe it requires a couple diodes. What's happening is you are locking the door with it open, and that sets the factory alarm.
Originally Posted by ???Craig B???
TCU = time control unit (controls dimmer, wipers, dome light fadeout, etc)
of course.....i was just discussing traction control & lsd tech stuff with a buddy when i posted that....so traction control was on the brain.
:attention
thats funny my first maxima is a white 92 gxe auto and it came w an aftrmrkt alarm and does the same thing it took me a while to figure it out but here goes ...if i use the aftrmrkt remote only it locks+unlocks the doors w\no fac alarm arming but if i lock the doors w\the door lock button it arms fac alarm then i press arm on aftrmrkt remote ..now i got 2 active ...and when disarming if i dont first unlock w\the key it sounds the fac alarm cause it detects the locks unlocking i dont know if this is how its supposed to be but i learned to live w\it
Oy Vey, dude! Trust me when I tell ya that's NOT how it's supposed to behave - if it's hooked up correctly.
People... (and Craig can back me up on this, cuz he and I have gone over this with I-don't-know how many org-y members..) some alarm systems come with a dedicated wire to disarm/rearm factory security systems, while (again, like Craig pointed out) a simple diode-isolated wire running from the factory security disarm wire (hmmm....wonder if I should tell 'em WHICH wire to tap into, or let them do their OWN research???) to your unlock wire on the alarm system will not only disarm the aftermarket alarm, but also disarm your factory alarm as well.
Or, just do like R92max said and take it back where you got it from and MAKE them do it right!
04-16-2020 05:15 AM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
