VE 5spd tanny question
Old 06-18-2004, 05:33 PM
Needs non-Maxima Friends
N34JZ's Avatar
My mechanic wants to know what is different between the trannys with lsd and without lsd is it just the differential or are the gear ratios or anything else different. he wants to know because he couldnt find a tranny with lsd but found a bunch of good ones without and he wanted to know if he could just change the differential out. Any thoughts or input?
N34JZ is offline
Old 06-18-2004, 06:04 PM
Ad·min·is·tra·tor
DanNY's Avatar
i believe it's the differential. the hump over that area is bigger on the LSD unit. anyone else can confirm?
DanNY is offline
Old 06-19-2004, 09:21 AM
I'm needing a caw
Jeff92se's Avatar
I compared a VG and VE 5-sp. The VE 5-sp has a buldge where the viscous coupling is housed.
I would think it would be much harder to find a VE w/o lsd than with. I guess you are talking about VG units.
I don't think you can put a LSD inside a non-lsd case because of space limitations.
I'd becarefull about using a VG tranny as I believe the output shaft sizes on the axles are smaller.
Jeff92se is offline
Old 06-19-2004, 11:42 AM
mtcookson's Avatar
input shaft bearing will break before the axles
mtcookson is offline
Old 06-19-2004, 01:43 PM
No turbo, no care!
Maxpwer's Avatar
True. True.
Maxpwer is offline
Old 06-19-2004, 02:06 PM
goon9's Avatar
Hook up with this dude.
http://maxima.cardomain.com/id/dmontzmax
He's done a VE 5-speed swap.
goon9 is offline
Unclejunebug
04-02-2016 05:42 AM
ef9
10-04-2015 08:43 AM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: VE 5spd tanny question
