Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-24-2004, 01:56 PM   #1
I'm needing a caw
Jeff92se's Avatar
VE30DE Oil Filter alternative. Since the 15208-60U00 has been discontinued
Nissan decided that the VG filter (15208-55Y00) would be suitable for all V6 3-gens. But as you know the VE filter also shared it's application with all Nissans using the VTC type intake cam sprockets. So there is a reason why this special filter existed:
Bill details the story here:
Nissan has discontinued the VE30DE - specific 15208-60U00 OEM oil filter.....
Us VE30DE users can use an OEM Toyota filter p/n 90915-YZZA2. The above thread has user results. I've also used this filter with good results.
A link to this filter being cut up is here:
http://www.autoxreview.com/reviews/P...il_filters.htm
Reviewer seems impressed with the results.
Pricing is an issue. Some users have paid quite a bit. I've have found a source for much cheaper: I bought 5 of these for $3.29 + $4.95(shipping). Will comment again when I actually receive them next week.
Link for the site:
http://www.toyotapartsworld.com/toypartpage.htm
Jeff92se is offline   Reply With Quote
Old 04-01-2004, 09:15 PM   #2
I'm needing a caw
Jeff92se's Avatar
Received them today. Correct p/n and the tracking info was sent the day after I ordered.
Old 05-13-2004, 08:20 PM   #3
RIP Cashj2002
Delvin's Avatar
Send a message via AIM to Delvin
I've been using the same Toyota filter for over a year with good results too. Just to add to what you said before about acquiring the Toyota filter. The person at the parts counter at the dealer said that part number is the same for most 4 cylinder car engines. You can go to the dealer and ask for a filter for a 98 Corolla instead of having to write down or remember a part number.
Delvin is offline   Reply With Quote
Old 07-28-2004, 03:54 PM   #4
WHAT NOW? 55y00 or toyota filter?
I have been using the 15208-60u00 religiously till this past oil change when my dealer said it was defunct and the 15208-55y00 is the replacement. Is Nissan copping out on the whole VTC issue? Will the 55y00 provide adequate protection? I already had the VTC sprocket assemblies replaced once and dont want to go thru that expense again. Should I stick with the 55y00 or go with the toyota as suggested
cleaner is offline   Reply With Quote
Old 07-28-2004, 04:02 PM   #5
I'm needing a caw
Jeff92se's Avatar
Bascily, you should be able to use whatever you want as the one actually designed for the VE is now discontinued.
If it were me, I'd go with the Toyota as that is what I use and is why I went to great lengths to write this FAQ sticky. I wouldn't have made this sticky if I didn't want to recommend it.
Old 08-04-2004, 03:53 PM   #6
Took your advice but what about oil type?
After several unsuccessful attempts to obtain the 60U00 oil filter ( including one unscruplous fellow that was willing to sell them to me at $35 a pop !), I decided to give the toyota a whirl. It is much smaller but fits just fine. Only prob is that I have become spoiled with age and since my nissan dealer refused to put a toyota filter on a nissan, I did the job myself. I forgot what a pain that damn plastic shield is that seems to be directly in the path of the oil pan drain, so as usual i made a damn mess! Anyways, it on there and many thanks for the info.
One last question, I was a tad perplexed at the multitude of oil choices out there, including reg 5w-30, high mileage 5w-30, combo synth/oil, and full synthetics. I went with the high mileage 5w-30 ( my car has 86K), although i wonder if next time i should consider a synth blend or full synth. Also , why do the high mileage oils >75 K not have the 'energy conserving' stipulation in their resume?...and does that mean anything?
Thanks again, cleaner....in PA
Old 08-05-2004, 02:39 PM   #7
High milage oils are probably thicker to better seal worn seals and parts, which is why they aren't energy conserving. Your milage is NOT high and if you don't have any leaks or burn too much oil, I would either just use a good conventional oil and change regularly, or a pure synthetic and change at longer intervals with a filter change in between.
You might want to ask in the Lubrication & Fluids forum, but that's it in a nutshell.
Bman is offline   Reply With Quote
Old 10-02-2004, 12:19 PM   #8
Send a message via MSN to Loe max
I bought my Yota filter for $4.19 a pop and had a local oil place change it for $13.22 They didn't have a problem with using my own filter, albeit smaller than OEM, at all.
After the oild change, I decided to look on purolators website to see if there was an aftermarket equivalant to the Toyota 90915-yzza2 filter, It seems as though purolator has one with a part# of L14476. What do you guys think?
http://www.pureoil.com/ProductFinder.aspx?action=IG and type in the Toyota Part # without the dash inbetween.
From this spec sheet http://ecat.arvinmeritor.com/smartlink/?partnum=L14476 it looks as though there is an anti-drain back valve.
Here is a list of cars that this filter is also used for http://www.pureoil.com/ProductFinder.aspx?action=WUG type in part# L14476
I think if you want to use OEM filters, I'm will to bet that stepping into your nearest GEO or CHEVY dealer will be cheaper than a Toyota dealer
Loe max is offline   Reply With Quote
Old 01-13-2005, 11:37 AM   #9
I'm needing a caw
Jeff92se's Avatar
Quote:
Why not order from the place I recommended?
If you want to use the Purolator, I'd just cross the Nissan p/n and not the Toyota one.
Don't know what you mean. I recommeneded the Toy filter because it's a good quality filter. Not because it's an OEM filter. I don't know if the GEO or Chevy filters are crap or not. Even if they use the Toy engine, I don't know if they use the same Toy filter. Alot of assumptions there. Unless you actually buy one and cut it up to compare.
Old 01-14-2005, 06:50 PM   #10
Nah, as nice as it is to save that money, I would prefer to buy retail and help local business owners. The price of the filters isn't too drastic from the internet site you linked above.
I did that also, but it comes up with the same Purolator part# as the VG engine. I though that was a no no for VE's?
Your right, it was an assumption which is why I said "will (meant willing) to bet". I was going by the Purolator guide. I used the Purolator's part # for the Toyota filter to check what other cars use the same filter, and they list GM vehicles also using the same Purolator part #. I'm not sure if that is the correct procedure?
Old 01-15-2005, 10:38 PM   #11
Yes, I suppose it is, but instead I would try to crossreference the proper Maxima filter instead and see if any other OEMs use such a filter.
The reason why the Toyota filter was chosen is because the Nissan filter that replaced the 60U00 was the same as the VG one and considered inferior by design/construction, while the Toyota filter just happens to fit and has superior construction. It's perfectly okay (from a fitment/specification point of view) to use a filter for the VG engine on the VE, and in fact that's what most filter makers specify.
If you can find another OEM filter as well made as the Toyota one, but crossreferenced with the VG/VE filter I'm sure we'd all like to know, although I don't believe that many other non-Nissans do.
Old 04-12-2005, 08:54 PM   #12
Absolutely wonderful information!!!!!!!! I've had my Max for just 6 months and have been so frustrated with the tick, this is just a great example of shared info. Thank you!!!
I can't make a new post as a "newbie" so I'll hijack this thread for a sec ( admin please excuse the intrusion ) Hey all, I'm Cy. A reformed Mazda (ford) Probe head, who moved on to an NX1600. After a VERY serious car accident I'm a proud owner of a 92 Maxima SE. I just wanted to say that this is the type of info and sharing I became used to owning a Probe. Like the Probe this model ( strickly speaking ) was only produced for a few years, and takes true lovers of the model to keep them going. I look forward to learning from all of you, and your experiences. Thanks again
CyMax is offline   Reply With Quote
Old 04-12-2005, 10:23 PM   #13
Way out West
Cliff Clavin's Avatar
Send a message via AIM to Cliff Clavin
Wasn't this a sticky before?
Wassup with that, MrGone?
__________________
Cliff Clavin is offline   Reply With Quote
Old 04-12-2005, 10:40 PM   #14
Wanna Go Fast?™
MrGone's Avatar
Linked it in another sticky
MrGone is offline   Reply With Quote
Old 06-22-2005, 02:59 PM   #15
Just went on http://www.toyotapartsworld.com/toypartpage.htm and i can't seem to find the 90915-YZZA2 filter. The closest thing is the 90915-YZZE2.
aussie983 is offline   Reply With Quote
Old 06-22-2005, 03:13 PM   #16
STFU n00b!
look closely at the picture... you can see it says YZZA2 on the filter.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 06-22-2005, 07:57 PM   #17
yeah i know, but the site doesnt list that particular part number on the drop down menu. thats why im confused.
Old 06-25-2005, 01:15 AM   #18
Send a message via Yahoo to KindBud419
Switch to a K&N Filter HP-2008. Thats what i use its ez to remove
KindBud419 is offline   Reply With Quote
Old 07-02-2005, 01:26 AM   #19
VE Powah!!!
Duckman540i's Avatar
Send a message via AIM to Duckman540i
Well I just put in the Toyota 90915-YZZA2 now called the "90915-YZZF2" (same filter) I used to get VTC Tick 50% of the time on over-night cold starts for about 1-2 min. With the Toyota Filter, it has eliminated it completely! Good little filter, real small compared to the Nissan one, but a perfect fit. I payed $6.45 @ the local Toyota dealer and it's worth every penny! I highly suggest this filter!
__________________
'92 SE 5-Speed:
Super-White, Black Leather, All Options.
Mods: Way Too Many To List
Duckman540i is offline   Reply With Quote
Old 07-13-2005, 09:49 AM   #20
Send a message via AIM to john93se
can it make a difference?
I've been using K&Ns and Mobiles, and in the beginning I was using FRAM's tough guard. I was wondering (because my VTCs are already shot and making noise) if putting the Toy filter on would make any difference at all?
Thanks,
John
john93se is offline   Reply With Quote
Old 07-14-2005, 04:08 PM   #21
VE Powah!!!
It should make a difference for awhile, it helps.
__________________
'92 SE 5-Speed:
Old 07-14-2005, 04:16 PM   #22
this filter is for a 4 cyl. does the toyota filter for a 6 cylinder fit?
max723 is offline   Reply With Quote
Old 07-15-2005, 05:22 AM   #23
Quote:
Ok, thanks for the tip. I didn't know if trying to find the filter was worth my time. As said above, they don't have the yzza2 or whatever the original name was, or the new one that was mentioned available on that site.
Old 07-21-2005, 09:41 PM   #24
Quote:
Not only does it fit but from what I have seen and heard it flows the same.
Old 08-06-2005, 11:54 AM   #25
Josh's Avatar
Send a message via AIM to Josh Send a message via MSN to Josh
i went to the yota dealship to day to get my filter and they said that they changed the part# from yzza2 to yzzf2, when i took it home it looked to be the same filter as the old one. just an FYI for everyone...let me know if this is wrong.
__________________
The Orger formerly known as 92graymax
CAI, FSTB, 1.3" Eibachs, Tokicos, grounding kit, more little fun stuff.
Josh is offline   Reply With Quote
Old 08-18-2005, 11:42 AM   #26
Does anyone know if I'm going to have to go to the stealership for one? Looking at the site mentioned in the first post, I don't see the yzzf2 at all.
TIA
Old 09-04-2005, 11:30 PM   #27
Send a message via ICQ to CBRKelly
hmmm, so I guess its safe to say the discontinuation has also occured here in Australia?
CBRKelly is offline   Reply With Quote
Old 09-05-2005, 09:39 PM   #28
Quote:
I have not used the Yota filter yet, but the the K&N filter while pricy is great, very little tick, for the first 1.5k anyway
Old 09-05-2005, 09:42 PM   #29
After Google-------> http://usatoyotaparts.com/Products/p..._22_33313.html
I hope they still have them, I just ordered 4.
Old 09-05-2005, 09:48 PM   #30
Wanna Go Fast?™
MrGone's Avatar
Quote:
The K&N and Napa Gold filters are the same, except for the nut.
Old 09-05-2005, 09:49 PM   #31
Quote:
I think that is a bad thing then isn't it??? But the nut is cool !!
Old 09-06-2005, 07:48 AM   #32
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
NAPA = Wix.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 09-08-2005, 08:19 AM   #33
My knock is now gone
I picked up the Toyota 90915-YZZF2 filter and took it to my local Jiffy Lube and they said no problem using it on the oil change. But when the change was done they called me into the garage and my VTC were hammering (not knocking). Tech below could feel the oil rushing throught the little oil filter. I trust everybody hear but I had to take it for a road trip. Had tech replace the filter with a shop filter recommended in their books for the Maxima. Now no knock. I tend to think the previous owner had use the 10W oil as apposed to the 5W oil. Either case I don't care, cuz my Max is running quite at Idle. Any other thoughts about the thicker oil causing the rattle?
Payload is offline   Reply With Quote
Old 09-15-2005, 03:39 PM   #34
Send a message via AIM to fuzzyuu
Guys! We are in trouble... I think. I just picked up a 90915-YZZF2 from the Toyota Dealer in Burnsiville, MN and it's NOT the USA made one. It's made in Thailand, and looks like a pile. Anyone else gotten any of these?
I will post pictures when I can... crappy digital camera not working right...
fuzzyuu is offline   Reply With Quote
Old 09-16-2005, 01:46 AM   #35
As I said, I would get pics up. Here they are, but I thought I would start another thread in case 56Kers come here and don't want to look at pictures. Still wondering if anyone has used these filters VS. the USA made ones, which is all I have used in the past.
http://forums.maxima.org/6th-generation-maxima-2004-2008/352062-pics-300zx-4-piston-brake-conversion-post4327857.html
Fuzzy
Old 09-29-2005, 06:08 PM   #36
Just another vote of confidence - I've been running the Toyota filter in my 92 SE for 3,000 miles now and while I haven't noticed a cutdown on ticking or anything, it's at least doing as good of a job as the old one.
lecherous84 is offline   Reply With Quote
Old 09-29-2005, 09:48 PM   #37
The Toyota parts book I looked at with the service mgr. at the dealership implied that the new part replacement yzzf2, like all Toyota filters has a backflow valve... as kind we like to have on the VE30DE. He was unable to verify this by looking at it....
blackmax42 is offline   Reply With Quote
Old 10-16-2005, 01:15 PM   #38
Might I offer you guys a suggestion?
I'm sure most of you haven't heard of Union Sangyo Nippon filters. They're available from worldpac sources like www.thepartsbin.com and the like. They're a japanese company with operations in a few places. I belive their filters are made in malaysia. These are *excellent* quality oil filters. I still have one from my old 91 Maxima SE (wrecked) that I plan to use on either my '81 Datsun 210 or 86 Pulsar. Not only are these filters excellent quality, but they are also *sticklers* for making their filters just like the OEM peice, right down to the color and part number. Every valve and spring and the like will be in place just as it was in the factory filter.
I was surfing around for parts and remembered this thread and the different filters, so I thought I'd post.
This is their take on the good old 15208-60U00:
versus my 15208-55Y00
I have a friend with a 300ZX who uses the upper filter because it mimics the old Nissan piece so well. I've been using their version of the VG filter on all my Nissans for some time now. They were great on my now-dead Maxima. As we can see in the pics, both filters use a nice red silicone anti-drainback valve. The blue filter does not use a bypass valve, however...which is weaksauce.
Just a suggestion. Take it for what you will. If only their website was as good as their filters.
PulsarDriver is offline   Reply With Quote
Old 10-25-2005, 12:41 PM   #39
This is going to be a bloatload of pics, but bear with it!!!
Denso First Time Fit filters are great & a more traditional style construction than the common $3-4 Denzo filters preffered by many people.
Toysrme is offline   Reply With Quote
Old 10-25-2005, 12:41 PM   #40
First time fit VS Purolator
Normal:
Toyota Denso YZZA2 (North American OEM), Toyota Nippon (JDM/Asian OEM), TRD (Unknown)
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
