Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-04-2003, 02:04 PM   #1
How difficult to replace Power Steering Fluid Reservior Hose
don't know if it's the right term. During the winter, I found out the both hoses underneath the PS fluid reservior were leaking. I didn't replace them, but poured some fluid in. Now I think it may be the time to replace. But any idea where to get those hoses and what procedures to follow in order to have at least amount of fluid lost?
Thanks!
buzzhd is offline   Reply With Quote
Old 08-04-2003, 09:37 PM   #2
get Haynes and/or FSM before posting thread like this, as it is a basic procedure. read stickies and check FAQ as well. hoses are fairly inaccessible, btw. and fluid loss during replacement is the least of your worries.
bonzelite is offline   Reply With Quote
Old 08-04-2003, 09:53 PM   #3
I just found out my high pressure power steering hose is a goner too, and I have to replace it ASAP....
__________________
1992 SE 5-speed
-2k Courtesy FSTB
-JWT Intake
-Armor-plated paint!
-RSB somewhere in holding pattern....
Bman is offline   Reply With Quote
Old 08-04-2003, 10:09 PM   #4
if it is any consolation, i am replacing my power steering hoses as well. as we speak, the car is torn apart in the driveway receiving valeo clutch, fidanza flywheel, tranny rebuild, power steering, center pulley bearings.
Old 08-06-2003, 01:40 AM   #5
I did some shopping today, and got myself the high pressure hose for $63 Cdn... not bad compared to the $40-something folks in the US consider "cheap" for this thing I suppose.
I was looking at the new hose and I'm kind of surprised it looks so simple. I haven't yanked my old hose off yet, but it seems as if it's just held in by one large bolt on each end.... Is it really that straightforward, or am I in for an unpleasant surprise tomorrow?
Good luck to all of us doing this repair!
PS: I was going to ask what the torque specs are for those bolts but I found it: 36-51 ft-lb
Old 08-06-2003, 01:44 AM   #6
the inaccessability of the hoses is the thing.
Old 08-19-2003, 09:43 PM   #7
Just to update how this came out, I changed the hose last week, but it was tougher than I thought.
The problem actually wasn't access to the lower bolt (reached from underneath), but with having tools powerful enough and the right sockets. The lower bolt was on pretty tight, and "swing room" was relatively narrow. The top bolt was also tight, and I didn't want to ruin the bracket that was sitting on those rubber insulators by torquing the heck out of it. The socket is probably actually 22mm since this is a Japanese car, but I found 15/16" to fit a tad better actually.
Since they were on sale and I always wanted them anyway, I went nuts and bought myself an electric impact wrench and both SAE and metric socket sets. Then I went and bought a real 18" breaker bar (which I'd also always wanted - my father really liked that too). The former got the top nut off fast and painlessly, and the latter gave me enough torque (without a cheater bar) to break loose the bottom.
Installation was fairly simple, but like one of Rosenken's early posts said, the hose has to twist slightly to fit (mine is also a Beck/Arnley). No leaks anymore! However, my pump is still making moaning noises like it did when it was low on fluid. I'm beginning to wonder if this is because the bolts aren't aligned as well anymore in relation to the hose fittings (they have a hole through them), and flow is being restricted.... I'd like to check that out someday, but then I'd have to do the messy removal over again.
__________________
1992 SE 5-speed
-2k Courtesy FSTB
-JWT Intake
Old 08-20-2003, 02:12 AM   #8
good going. that is good info. i have this situation currently.
__________________
quality over quantity
Old 01-25-2004, 04:03 PM   #9
Lil 8
jkmay01's Avatar
Send a message via Yahoo to jkmay01
say bman i have the same thing going on now with the power steering hoses. question is though which hose is the high pressure and which is the low pressure? The two small hoses underneath the power steering resovoir seem to be common pressure hoses, and the larger hose that runs to the rack is part specific i got a price for that one for about $39 the other hoses seem to be sold on a roll for about $9 bucks. But I have checked my chilton and haynes books and they dont really touch base on the hose size? do you know the hose size or diameter of the teo hoses underneath the resovoir? let me know!! thanks!!
jkmay01 is offline   Reply With Quote
Old 05-24-2005, 11:26 AM   #10
I'm needing a caw
Jeff92se's Avatar
Anyone want to chime in with the p/ns for the VG and VE? I can include this thread in a sticky.
And I have to do this replacement soon as I have to refill my reservoir every few days. Haven't tracked down the specific leak but it looks like the high pressure hose everyone replaces.
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is offline   Reply With Quote
Old 05-24-2005, 11:51 AM   #11
Wanna Go Muddin?
Greeny's Avatar
92-94 VE autozone part #80100
92-94 vg #71445
89-91 vg and se #71446
Greeny is offline   Reply With Quote
Old 05-24-2005, 11:57 AM   #12
Wanna Go Muddin?
Greeny's Avatar
Internetautomart has the same vendor so the part #'s will be the same.
Old 06-14-2005, 05:02 PM   #13
I'm needing a caw
Jeff92se's Avatar
http://www.partsvoice.com/ipc/part_c...signgallery16/
Nissan part numbers:
dohc ve: 49720-96E10
sohc vg: 49720-86E02
Both are $175.xx. I found it cheaper here: http://www.nissanparts.cc/cart/?pn=4...=18&submit.y=5
$133.xx for either one.
But Brian has it way cheaper. Not sure about the brand/quality though.
__________________
Sold Jan 14, 2006'
Mod list:
Old 07-26-2005, 04:26 PM   #14
I'm needing a caw
Jeff92se's Avatar
I completed this install over the weekend. I too have this 'whine' bman mentions. I actually didn't have any whine until I replaced the hose. I didn't really following the bleeding instructions though as they were pretty simple. I thought it would just bleed itself over time. I've had to top off the fluid once or twice.
As anyone experienced this whine and corrected it? If so, how.
__________________
Sold Jan 14, 2006'
Mod list:
Old 07-28-2005, 11:27 AM   #15
Lil 8
jkmay01's Avatar
same here jeff had my high and low pressure hoses changed. prior to changing them i had no whine @ all!!! but as soon as i had them changed i got teh whine. I didnt need to top off fluid, but figured after driving for a while the system would bleed the air out, but still have a small whine.
__________________
http://www.cardomain.com/ride/273358
Mods for the 2k Se max
Front-Strut tower brace
Steel braided Goodridge G-Stop brakehoses
Steel Braided Clutch Hose
Aluminized Mandrel bent y-pipe
Slotted-Cross Drilled Rotors
Black tint Halo Headlight Lenses
Black tint Foglight Lenses
10K Hid Headlight
10K Hid Foglight
Cleared out Front and Rear bumber lenses
Polarg Blue Bulbs for exterior lights
UpComing Mods
RSB
89 Max
mods: Slotted-Cross Drilled Brembo Rotors, Front-Strut tower brace,
Steel braided Goodridge G-Stop brakehoses, Pacestter Short throw shifter
TIG Welded By Warpspeed
Rear Sway Bar by Suspension
Techniques
Old 01-29-2007, 10:57 AM   #16
Dang it!
I'm having the same whining noise too in my car!
I tried to by some of that band-aid Lucas Oil leak solution- but that works like sh**!
It's looking like this part costs around $60 bucks, right?
Any ideas if this is an one-person job? About how long did it take anyone? A day? Weekend?
writes1 is offline   Reply With Quote
Old 01-29-2007, 07:55 PM   #17
hi
Send a message via AIM to bvtran
it's pretty easy to replace, but it will takes lot of times though depending one what you wanted to replace.... say, I'm about to go thru the same mess too. I just got 2 high pressure hoses power steering hoses from Napa. But I noticed we also have a small diameter hoses that run between one of the high pressure hose to rack (2 ft long), and 2 small pieces about 3 inches each running to and out of the reservoir. Does anyone here know what am I'm talking about? Could you please tell me what is the diameter size of those small hoses? And what should I refer them to Napa people, such power steering xx diamter hoses?
bvtran is offline   Reply With Quote
Old 01-29-2007, 11:48 PM   #18
I was looking in my book (Haynes) on which hose I should replace. The book doesn't say anything!
How do I know which hose to replace? My leak is coming from the large hose that runs behind the engine, near the firewall. It begins (or ends) near the passenger-side strut mount.
Ideas?
Old 01-31-2007, 12:45 AM   #19
hi
parts are expensive man.... $60 you wished!
Old 01-31-2007, 08:04 PM   #20
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
Quote:
power steering hoses are like $40 ish for the pressure hoses.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 01-31-2007, 08:27 PM   #21
hi
not true! we got 4 types!!! 1 return high pressure, 1 outgoing high pressure, reservoir hoses, and one 24" long (probably low pressure) that run between driver side of the rack to one of the big high pressure metal line.
comeon man, you sell them and you didn't know? j.k
Old 01-31-2007, 08:29 PM   #22
hi
plus, don't forget rack is $161 and pump is $98 + taxes at Autozone (cheapest) + new tie rods ($30 ebay) but it doesn't apply here.
Old 01-31-2007, 08:42 PM   #23
buy a car from him?
cheapest =/= best.
Old 02-19-2007, 11:44 PM   #24
01 Maxima SE, 5-spd
aksansai's Avatar
Pain in the *** if you don't remove anything, but I had to do the same thing. My hose was dry-rotted to the point that fluid was seeping through the rubber.
__________________
AksanSai
aksansai is offline   Reply With Quote
Old 03-08-2007, 01:38 PM   #25
Some of the power steering hoses went out on my 94 SE. Is there a big enough difference in quality to justify paying $160 for the dealer price vs $40 for the pressure line assy?
Navorama is offline   Reply With Quote
Old 03-08-2007, 02:18 PM   #26
Quote:
Probubly a little and qauilty. Take into consideration they overcharge.
__________________
goon9 is offline   Reply With Quote
Old 03-12-2007, 04:57 PM   #27
I finally got around to replacing the power steering hose on my 94 Max SE this weekend. I went with the Gates hose for 50 bucks. Thanks to all for your previous posts! The 15/16 socket with the impact wrench worked great on the top bolt. I used a huge craftsman 1/2 flex head ratchet for the bottom bolt. The job was a piece of cake until I tried to put the top bolt back on. The parts store and the Gates catalog crossed the part to P/N 363060. This is what I wrote to Gates this morning:
Subject: Gates Hose OEM Compatibility Issue
I installed one of your high pressure power steering hoses this weekend. It did not provide the same fit as the original. I had to twist the hose at least 45 degrees (with pliers) so it would mount flush. I also had to change the bolts on the bracket that the hose mounts to on the top because the metal connector on the hose is also angled incorrectly. Let me know if you would like the before and after pics. I have two concerns: First, I am concerned about the impact of the additional stress on the life of the hose. Lastly, your hose should not be sold as a suitable sub for the Nissan part it is designed to replace (49720-96E10). I should not have to modify a bracket and crank on a hose with pliers and require an extra set of hands to force it fit.
I called them after their initial response to order another part and they discovered an error with their catalog and provided the following info:
According to research information from Nissan I was able to come up with the following; 1994 Nissan Maxima V-6 SE 3.0 L 24 Valve ENG.;
Jan. & Older 1994 = OEM # 49720 96E10 = 360670
Feb. & Newer 1994 = OEM # 49720 40U15 = 363060
PM me if you want the pics. Nav
Old 03-12-2007, 06:30 PM   #28
buy a car from him?
it's not gates' fault it's the moron at nissan who decided when to change model years :.
feb 94 is when they started production of the 95 maximas.
that's why when I look up parts for a VE I look under 93.
It's experience that is my teacher, something you won't find at autozone.
__________________
96 Green A/T gone
Old 03-13-2007, 05:45 AM   #29
Good production info on the 94 Max, however, this does not negate the manufacturer's responsibility or accountability for incorrectly cataloging the parts they provide to retailers. They have had over a decade to get it right. I like working on my car as much as everyone else in this forum, but I’m not happy about having to do the same job twice...
Old 03-13-2007, 02:45 PM   #30
Update: The Gates Corporation provided outstanding customer service. They thanked me for helping identify the catalog problem and they are sending me the correct replacement hose along with some additional belts and hoses.
Old 03-13-2007, 03:14 PM   #31
Wanna Go Muddin?
Greeny's Avatar
Nice..
This action from gates really shows how a good manufacturer/distributor should react when a dissatisfied customer comes calling to right a wrong on their part..They realize this will keep customers coming back,and word of mouth is a very powerful tool..
__________________
3rd Gen parts--> http://forums.maxima.org/1st-3rd-gen...-part-out.html
Old 03-13-2007, 03:48 PM   #32
Boomer Sooner
Send a message via Yahoo to Black92GXE
Niiiice - its good to see someone is grateful instead of passing the buck. Good job Gates! Guess I'll have to keep them in mind when I have to do this very same thing to my max.
Black92GXE is offline   Reply With Quote
Old 09-28-2008, 12:47 PM   #33
what did you guys, who had the whining noise after replacing the hose, do to fix the problem? was it the hose's fault? was it not properly bled?
i'm going to have to fix this also because of a leak. is the autozone #80100 the part to get? thanks.
beefbowl is offline   Reply With Quote
Old 09-28-2008, 02:53 PM   #34
buy a car from him?
depends on what year,motor,model, options you have.
__________________
96 Green A/T gone
Old 09-28-2008, 03:29 PM   #35
i have the ve 93 se automatic. i see internet auto supply has the Gates for $40 + shipping for the #360670 and autozone has a Duralast #80100 for $32 b&m. are these the same hoses? if not, then which is better?
Old 09-28-2008, 03:42 PM   #36
buy a car from him?
the big difference is who gets the money. 1 is me, 2 is a big company that doesn't give a dam about anything but the almighty dollar.
__________________
96 Green A/T gone
Old 09-28-2008, 08:32 PM   #37
Quote:
thanks for your help.
Old 09-28-2008, 09:08 PM   #38
i replaced mine at 3am 2 winters ago. it was a pita but very do able. no expensive tools needs, just lack of sleep, and back up cars fuel pump busted! all in all not that bad
__________________
1991 GXE Resurrected from the dead
1989 SE gutted for parts and 5 speed.
300zmax is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
