Swapped trannies, now hood wont close....
Old 07-29-2003, 11:38 AM
KLoWnPR109's Avatar
WTF? Anyways, what are the symptoms of a bad hood latch? I dont think that it is because it seems to be getting hung up on something, but anyone had their's go out on them?
KLoWnPR109 is offline
Old 07-29-2003, 12:17 PM
STFU n00b!
Matt93SE's Avatar
they do tend to get rusty and stuff... how is it not closing? it'll go all the way down, but the latch won't lock, or do you have something stuck in there? (screwdriver, bolt, etc?)
Matt93SE is offline
Old 07-29-2003, 12:20 PM
KLoWnPR109's Avatar
it seems like i have something stuck on the driver's side, but there is nothing there. I took of my FSTB and my battery is still out.
It will go all the way down, but it seems to be kinda "flexing" in the middle like it's caught on the engine, but I'm sure it isn't. I stuck duct tape on various parts of the engine bay so that if it caught, I'd know where it was hitting, but none of it stuck.
Old 07-29-2003, 12:28 PM
STFU n00b!
Matt93SE's Avatar
hmmm... keep playing with it.. surely you'll find something soon.. not much anyone can do over a computer to help you find that one.
Matt93SE is offline
Old 07-29-2003, 02:36 PM
Walka's Avatar
damn man, that really blows.. all that work and you cant even shut the hood. im sure you have already checked a million times over.. but make sure you dont have a socket or bolt or anything in the track that runs along the top of the fender.. its almost too easy to put things in there. good luck man
walka
Walka is offline
Old 07-29-2003, 02:56 PM
MrGone's Avatar
just try to take your mind off it for a sec, the problem probably staring at you right in the face.
It could be worse though, you could be trying to bridge a wire to itself
MrGone is offline
Old 07-29-2003, 03:44 PM
KLoWnPR109's Avatar
she's alive
Old 07-29-2003, 03:46 PM
MrGone's Avatar
MrGone is offline
Old 07-29-2003, 04:06 PM
shavedmax's Avatar
didnt you swap the hood off the parts car? isnt it possible your hinges were bent?
shavedmax is offline
Old 07-29-2003, 09:13 PM
crazy4maxima's Avatar
that is the same thing that happend to me and a parts max. the hood hinge was bent . i had to sit on it to make it close, that is after we tired to bend it. lolz. i was madd as hell and i same damn and i just sat on it and down it went. i actually just jumped and butt slammed it down.. it worked, and it opened and closed properly. also check the hood struts. if they arent installed correctly they can make it hard if not possible to close it .
crazy4maxima is offline
Old 07-30-2003, 06:55 AM
GRNMAXDMON's Avatar
check the cable if its stuck behind ur headlight cuz that happened to me after i did the BMW headlight conversion. so check that as well.
GRNMAXDMON is offline
Miket2006
03-01-2021 03:55 AM
howardis
12-11-2019 06:10 PM
Unclejunebug
04-02-2016 05:42 AM
HerpDerp1919
09-29-2015 02:02 PM
Socalstillen
09-20-2015 11:46 PM
Quick Reply: Swapped trannies, now hood wont close....
