reverse lights
reverse lights
all the sudden my reverse lights stopped working.. is a 93 VE 5spd. i checked the normal stuff, fuses, bulbs, ect...any ideas ? i though of the reverse switch but i dont know where it is ?
look for limited slip differential gear oil.. there is a plug in the front of the trans that a 1/2 inch rachet can fit into. I would use a breaker bar though(same a rachet but doesn't turn) I think I had to use about 4-5qts. Just fill it till oil over flows out of fill hole.
One word of advice..... (don't ask how I know)
ALWAYS...ALWAYS...ALWAYS!!!!!
Remove the fill plug BEFORE you remove the drain plug!!!!
There's very few feelings worse then having all your gear lube neatly in the drain pan with NO WAY to add fresh (or used) lube back in!!!!
(like I said, don't ask!)
That should do the job. One thing, did you check your fuse (left bank 6th from the bottom - 10 A)? If that is good confirm that the switch is bad? All you need is a multi meter. From that plug I told you about, follow the wire to its connector. disconnect connector and with car in reverse, probe the green wire and the red wire with black tracer. If you have continuty, the switch works.
fastcarny
10-06-2015 10:42 AM
-ReLLiK-
09-08-2015 12:02 PM
Maxima30
09-07-2015 06:13 PM
