Blower motor running all the time
I have a '90 Max and the heater/A/C blower motor runs on high continuously can not turn it off or use slower speed had to take the fuse out this morning. The car has climate control and I'm wondering if the "brain" in the dash went bad. Last week I put a new head unit in. Don't thing that had anything to do with it though. Anyone ever have this problem? Thanks.
Thanks for the quick reply. I'm not familiar with the temp. sensor. I do remember seeing a hollow tube going to a 1" square louvered like opening next to the control panel. Does this go to the sensor? Thanks
Originally posted by eric93SE
Depends which engine you have. For the VE engine, its located near cylinder #6, and it has a red connector!
Thanks Again,
Pat
The following is for automatic climate control:
This should not be hard to diagnose. You have to locate 2 items and disconnect them. Both are located on the passenger side. Remove the glove box and the right side kick panel on the passenger’s foot area. The items you are looking for are the blower hi relay and the fan control amp. The relay is located behind the kick panel probably blue in color. There will be four wires connected to this relay. (black, green w/orange tracer, white w/ red tracer, and brown w/ black tracer). The fan control amp is behind the glove box with 3 wires to it. (gray w/blue, brown w/ black and black). Hopefully after disconnecting one of these will cause your blower motor to shut down. Replace the part that causes the blower to shut down when disconnected. If your blower continues to work after disconnecting these items then you have a short to ground and will be a little work to locate. Let me know how you do.
Pat
Hey dsantos,
Finally got around to diagnosing the problem. In Balto. we've had 3-days of 100 deg. weather; need to get the AC going. I checked the blower amp first. Sure enough the blower stopped. After disconnecting the harness with the 3-wires you mentioned the fan control only operated the blower on high. Just ordered a new blower amp $80!! A strange looking device with a bunch of 1/8" X 2" cast metal tubes on the back; looks something like a heat sink. What the heck does this thing do?
Thanks again for the help,
Pat
Pat
alixc
08-11-2020 01:48 PM
Finkle
09-27-2015 09:53 PM
MaximaDrvr
08-19-2015 08:20 PM
