Throwout bearing
Throwout bearing
Hey guys...
sorry to ask this but search is down and i'm kinda sorta really broke so no donating for now....
on my way to school today, i heard a weird sound coming from the tranny section while i was on the freeway. It sounded like a slight rough spinning sound which i kinda figured was the throwout bearing....unfortunately i dont know what it sounds like when its going out. It sounded only when I was in gear. I asked a second opinion of a friend of mine and of my mechanic and they both said it sounded like my throwout bearing was out. Is this normal? Should I get him to replace the clutch and p plate while in there? He said he could do the throwout bearing for 250. I asked him if he could change my clutch while he was in there and he said yeah he could do everything for 250. good deal or rape? what else should get done while he's in there?
thanks for the info.
that's not too bad for the labor price.. about average.
might as well get the clutch replaced while you're in there, because the throwout bearing is a part of the clutch job.
btw, I've got a brand new OEM TO bearing in a box somewhere in the garage if you want it. I'll make you a deal on it.
yeesh!that was quick!!long time no speak. i was checking out nopionline and they had the centerforce clutch for 230 or so but didnt say if it came with the bearing...there was also a gd on exedy or sumpth like that...which do you have and which would you recommend I get? any difference b/w bearings?
DO NOT get a centerforce. I've heard nothing but bad about them.
Supposedly Exedy is the same as the ACT, but I have no real proof. I'm running a LuK clutch, and you felt it. it'll grab good, but the pedal isn't nearly as heavy as the ACT.
get either the ACT, Exedy, or LuK. stay away from centerforce.
with any clutch BUT the LuK, you'll need a T/O bearing. the LuK comes with it's own.
I got mine from the local tranny shop. shop around online for it, they're out there. (google is your friend!)
I have ZERO time for clutch jobs! I can't even change my oil right now I'm so busy!
Originally posted by DaBoxSE
You should probably jump on this then!
http://forums.maxima.org/showthread....hreadid=192897
"Supposedly Exedy is the same as the ACT, but I have no real proof. I'm running a LuK clutch, and you felt it. it'll grab good, but the pedal isn't nearly as heavy as the ACT."
According to a friend, and before I installed my ACT clutch, I took a look at the clutch and it has an exedy tag on it. According to my friend, ACT uses exedy stuff.
H
H
"According to a friend, and before I installed my ACT clutch, I took a look at the clutch and it has an exedy tag on it. According to my friend, ACT uses exedy stuff."
thanks for the info....now where can i get either for less than 3bills?
Probably for the clutch DISC. But alot of the holding power is at the pressure plate.
H
H
Really? my clutch disc on my old ACT said UNISIA on it, not Exedy.. (or is it VISIUN?)
Same symbol as what was on my OE clutch disc when I pulled it off the car:
http://www.ee.utulsa.edu/~mblehm/pic...h/MVC-019S.JPG
I'll have some pictures up soon of the 'quality' of Centerforce.
Originally posted by James92SE
I took off my clutch and flywheel today (Centerforce and Stillen aka relabeled AASCO flywheel).
Originally posted by lophix
not bought...i mean lightening the stock wheel since it will probably have to be machined anyway....
Damn noobies:
https://maxima.org/maxfaqs/sub_perfo...Performance_5a
dang....thats a lot of weight difference....$160 to get i lightened? might have to look at that.
not really.. just make sure the shop isn't stupid. there's a large metal ring on the back, outer edge of the flywheel. that's what I had chopped off.
send them the pressure plate also so they can balance the whole thing as an assembly.
here's some pics for you to see what I did.
www.ee.utulsa.edu/~mblehm/pics/car/clutch
litch
123
01-04-2024 07:01 PM
James92SE
142
01-02-2024 09:23 AM
220k+ A32
25
10-03-2015 09:09 PM
Andy29
09-29-2015 05:32 AM
