Daytime Running Light Problem
Old 02-04-2003, 09:50 AM
stephenho56's Avatar
Mine is a 93' Max. Canadian Model. The Daytime Running Light has been acting strangely these few months. While the car is running during the day, the daytime running light keeps turning on and off automatically. Has it ever happened to your car? Is it the problem of the Daytime Running Control Unit or the Relay? Where are they located?
stephenho56
stephenho56 is offline
Old 02-04-2003, 03:56 PM
max4me's Avatar
Hi
The Daytime Light Control Unit is located under the dash behind the brake pedal or there abouts. It is piggy backed with the Time Control Unit so look for two modules about 2 1/2" square by about 3/4" deep. I have one if you find that you need one.
Jeff
max4me is offline
Old 02-04-2003, 07:46 PM
Aphrodisiac's Avatar
Re: Daytime Running Light Problem
stephenho56
how do you know?
Aphrodisiac is offline
Old 02-05-2003, 08:58 AM
tmuscedere's Avatar
daytime light
On my car I removed the light control unit took it aparts and resoldered the joints in the unit. The unit has worked fine since.
tmuscedere is offline
Old 02-05-2003, 11:33 AM
Re: daytime light
i found out the location of the daytime running light unit already.. it's like a small black box.. with 2 harness connected to it. i have no idea how to take it apart.. also.. i don't know where is the exact location to solder the joint.. and you tell me more about that? if anyone has an extra one.. does it work fine? how much is it? i can't stand it anymore.. i am in new york.. people in front of me thought that i was flashing the headlight to make them drive faster.. don't wanna get hurt one day.. thanks..
Old 02-05-2003, 12:13 PM
Re: Re: daytime light
after i located the daytime running control unit, i tried to shake and slam the unit while the engine is idling. it didn't make the light turns off at all. i started to puzzle whether it's the problem of connection and joints within the unit. that's really strange.. the light only turns on and off while my car is running.. really frustrated..
Old 02-06-2003, 12:42 PM
tmuscedere's Avatar
daytime lights
I think I have a unit at home kicking around, the joints that go bad are the ones that are in the relay area. A small flat head screw driver will take off the lid.
Old 02-06-2003, 01:39 PM
are you talking about the relay (brown or blue) or a relay inside the control unit? i opened mine already, but i broke the cover.. that's alright i think.. i looked at the circuit board carefully, and i can't find any problem with joints or print.. i really can't tell any problem with anything inside the control unit.. but i just soldered all connectors' "foot" anyway.. really give me headache..
Old 02-07-2003, 07:15 AM
tmuscedere's Avatar
daytime
Once you have the cover taken off, (yeah, it broke on mine too). The joints that I resoldered were the 4 connections on the 2 relays that are on the circuit board. They didn't look bad but I resolderd them anyways. Have not had a problem since.
Old 02-10-2003, 01:04 PM
hi tmuscedere,
do you really have the working daytime running control unit available? do you wanna sell it to me? how much?
stephenho56 93 max.
Old 02-10-2003, 06:29 PM
Damion's Avatar
If youd rather I can tell you how to disable the DRL system email me for info
Damion is offline
Old 02-11-2003, 08:38 AM
YUP.. HOW TO DISABLE THE DAYTIME RUNNING LIGHT? HOW MUCH TO BUY A DAYTIME RUNNING UNIT.. I WANNA KNOW BOTH OPTIONS PLEASE....
kjlouis
11-24-2018 06:09 AM
homeyclaus
09-03-2015 06:15 PM
maxinout93
08-20-2015 02:17 AM
Samedi
08-13-2015 04:05 PM
yat70458
08-03-2015 01:16 PM
Quick Reply: Daytime Running Light Problem
