starter woes
starter woes
i replaced my starter this summer. as it got colder, i noticed it made a noise like the car was arlready started when i would initially start it. I searched here on the org, and found a this to be a common problem on fourth gens. I found directions to take the starter apart and re-lube a certain part, but since it has a lifetime warranty i just returned it for another one. Now the second starter started to make this noise as well. Is there a problem with my flywheel(5spd)? Is this a problem for any other 3rd gens? Should i take it apart and re-lube it or just return it? thanks a bunch.
Justin
Justin
Re: starter woes
[QUOTE]Originally posted by avusblue92se
[B]i replaced my starter this summer.
You may have a bad spot on the fly wheel ring gear. If makes the noise again, turn the motor over a little(it's a stick right)and try the start again.
If it starts then it is the fly wheel gear.
ALL the Best
ALL the Best
maybe true, but it only happens when it is cold. also when i had tranny work done last year, the flywheel was supposed to be fine. bizzump.
Yeah same thing happened to me, its also the second winter. ever since i had the starter changed. it sometimes happened in the summer too. Havent worried yett? I posted once, no one replied. its a mystery, would love to find out what it is, but got no money. also have a short since last oct thats another story =)
try searching in 4th gen forums under the term "donkey whine" and someone gives a link to instructions how to fix a similar problem. i would like to see if any of you guys think it is worth a shot. thanx,
Justin
Justin
i replaced mine with an aftermarket one, duralast, from the autozone.
any one ever tried the repair for this on a third gen?
I replaced with a Genuine Nissan starter and have never looked back since. I would suggest it is possibly the poor build quality of the aftermarket starter.
thanks for the responce man. maybe i should look into getting a nissan starter. i am real sick of this noise and it has only been occuring for a two weeks. do you remember how much the nissan starter cost?
Justin
Justin
Justin
Justin
Good luck. Call Courtesy if you are going to DIY.
maxima297
09-30-2015 03:32 PM
homewrecker
09-23-2015 03:41 AM
