Engine "whirring" noise
My 1990 GXE has developed an engine noise that is driving me crazy!
Symptons:
Can be heard at lower RPM's when eng speed decreasing. If I take RPM's up to 1500 in nuetral/park and let off the gas I get the infamous "whirrrrrrrrrr" I removed ALL accesory drive belts but noise still is present.I listened with a stethoscope at various engine locations but noise seemed to be present at all of them. I thought possibly the timing belt tensioner but I just changed the T/belt and tensioner last night and still same "whirrr" when engine speed decreases back to idle . Car runs normal except for noise.
Anyone experience this?
John
Symptons:
John
I just posted about something similiar a few days ago
I have the same symptons going on in my car. It just started last week at close to 170000 miles. It is only at low RPM and not dependent on wether the car is in gear or not. It's driving me nuts to. I was wondering if it was the begining of a bearing going out, not sure though. I'd like to see if anyone else has had this and figured out what the heck it is. 92GXE Auto
I'm thinking maybe distributor bearing? If I hold my hand on top of distributor cap I can "feel" the vibration. Of'course I can feel the vibration at just about at any other location;-)
Anyone have a distributor bearing fail on a VG motor?
John
John
Is it a low moan sound? Does it get worse when the lights are on? I bet it's the alternator. Other choice would be the PS pump. I just checked mine yesterday. Jacked up the car, took the pass side splash shield and wheel off and used the hose to finally dial it down to the alternator. Have the lights on when you test also
Originally posted by skoobahead
No. Like I mentioned in my original post, The noise is still present with all accy belts removed.
Originally posted by kaleb
Yeah I suppose it could be a tranny bearing, listen in that area closly. TB tensioner won't make noise at that low of an RPM, really.
Have you installed an engine block oil by-pass kit?
-Kaleb
-Kaleb
John
i didnt fix the tranny miself but mine made a funky sound liek that in neutral and park too, it was a year ago so i dont remember exactly, but i also had symptoms of tranny problems. if you dont i wouldnt drop the money on a tranny before getting it diagnosed
Funny, I actually have one too. I get a whrr whrr whrr whrr type nose right around 1600rpm. You NEVER hear it when accelerating b/c the tach flies right past that one point, but if I lock out 4th, or even if i'm in 4th at that 1600 mark I get. If I go a tiny bit faster or slower its not there. Its been that way for atleast a couple years. I'm not even worried about it.
How would I have a transmission bearing making a noise when the car is in park or nuetral when the engine rpm is increased?
John
John
ballerchris510
09-11-2015 05:29 PM
