TX Houston, 93 VE Auto part out with mods
Hi everyone! The car is done for, too many problems to keep it going, and the rate at which new problems have been showing up is troubling anyway. I don't know what the market for this stuff is, so I will accept all reasonable offers. I take paypal.
Already sold:
- fog lights
- tokico/eibach setup
- warpspeed y-pipe
Removed and ready to go:
- jeff's Z31 rear BBK brackets, rotors, and stainless-steel lines
- suspension-tech sway bars, front and/or rear
I will remove these if there is interest, otherwise I'm not going to bother with the work and they'll go with the car:
- blehmco ground wire kit
- asp underdrive pulley
- nwp eng. phenolic intake spacers
- poly-filled motor mounts (I'd need stock parts to swap)
- rear links with energy suspension poly bushings (I'd need stock parts to swap)
- control arms with energy suspension poly bushings, 4th gen version cut to fit (I'd need stock parts to swap)
These "extras" can be removed easily enough:
- sunroof spoiler
- all 4 splash guards
Also have some brand-new parts that never went in:
- front valve cover gasket (Beck/Arnley 0361633)
- power steering belt (Gates K040388)
- rear brake pads (Wagner PD595)
Some spare parts that aren't on the car:
- all the stock intake resonators
- starter (can't recall if it works, will check)
- driver-side CV axle with torn outer boot
PM me if there is something you'd like that isn't listed. I intend to keep the car functional until I get rid of it, because I need to move it around the garage/driveway without a hassle, so things like engine electronics might be available later, but aren't for sale at the moment.
Thanks,
Mike
Already sold:
- fog lights
- warpspeed y-pipe
- sunroof spoiler
Thanks,
Mike
Matt93SE
04-08-2018 09:23 AM
