1st-3rd Generations Classifieds (1981-1994)No superchargers in here, but you will find other useful parts and accessories.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
I guess you will have get one from the junk yard or make one yourself.
__________________
ebay CAI, DIY ground wires, Otto FTSB, Matt's type II LTB, RSTB, Rear Sway Bar link, Warspeed y-pipe, Full Exhaust W/Hight Flow Cat, ST FSB, Addco RSB, Jeff's Front 13" Z32 BBK, Jeff's Rear Z31 BBK, SS Brake and Clutch Lines, Driver and Passenger Corbeau TRS, E36 head light conversion, Murano 18x7.5 W/225/40/18 Falken 115, Tokico HP shocks and Struts, Eibach spring, Blehmco Parallel links
thats what i had to do for a brake line that runs from the firewall to the rear calipers - you can just buy the straight piping with the threaded fittings already on it and a tube/line bender
Do you have the old part? I know at our local napa or fisher auto they will make hydraulic lines for you. Also any place that makes brake lines would be able to do it too.
* It may be cheaper just to get the stainless one they sell on ebay for $20
I do have the line actually. The reason I need to replace it is because I tried to remove the line from the distribution block to bypass it, but the thing wouldn't come apart. It ended up twisting the line inside the fitting instead, and now it's leaking just enough there to not let me bleed the clutch propertly.
Which line are you referring to on eBay? I already have an s/s line for the slave cylinder. I need a line to connect to that line and run to the master cylinder.
Maximan190 - I was thinking of just building my own line from fittings from Jegs (i.e., a 8" s/s hose and two male fittings on the end), but I've been informed that brake and clutch fittings aren't all a universal size, so I have to try to figure out what size I need, and I'm having trouble finding any information about it
__________________
Desperately looking for a 5 speed axle carrier bracket. Either VG or VE will work. PM me if you have one!
Good working door lock timers $20 shipped. PM me if interested
Anybody? I got the car running today so now I just need this line to get the car driving!
Have you tried www.car-part.com You can look up something like clutch master cylinder and find junkyards that have m/t cars. Then, call them to check on your specific part. Its searchable by state, region, distance, price, etc... I used this strategy to success on my part hunts.
weird, i bought one from Courtesyparts.com last year... hmm. i have one but i was planning on selling it as part of a 5spd swap setup. I'll take another look at what i've got on tuesday to see if I can sell it separately.
__________________ PieceOut.FallToPeacesNew to the forum? CLICK HERE!!!! 1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress! 2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z 1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09 2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
That's who I tried to buy it from. They cancelled my order several days later saying it's no longer available. They've done that to me several times recently
Anyway, do you have an extra? It's not super important as I was able to repurpose/bastardize a honda clutch line to make it work, but it's kind of rigged and not a permanent solution
__________________
