Help with Power Steering rebuild...
Old 04-04-2014, 03:33 PM
lowpost99's Avatar
Here's my 88' Maxima PS pump removed. Anyone have procedure or instructions rebuilding these? The metal ring goes over the pulley shaft. In another photo apparent grinding can be seen on it and there are bearings exposed with some pieces of metal mixed in. Looks like something ground up pretty nicely.
I don't see any cracks in the housing though, so I hope it can be rebuilt.
https://dl.dropboxusercontent.com/u/...404_170612.jpg
https://dl.dropboxusercontent.com/u/...404_170551.jpg
https://dl.dropboxusercontent.com/u/...404_170426.jpg
lowpost99 is offline
Old 04-04-2014, 03:48 PM
ac max 92's Avatar
Looks like the bearing is no good. Looks like the snap ring over the bearing can be removed and the bearing replaced if you can find one. Im not sure about a rebuild though? Have you tried checking ebay for a replacent?
ac max 92 is offline
Old 04-05-2014, 12:19 PM
lowpost99's Avatar
Got a replacement pump from junkyard...
I got a replacement from a junkyard today, and it's snap ring looks 100% better shape in place and intact...I've got some basic instructions came with the kit, but no photos. Any advice welcomed...
https://dl.dropboxusercontent.com/u/...405_151517.jpg
Old 04-06-2014, 10:12 PM
CMax03's Avatar
Kits are straight forward and easy....There are millions of good cheap units in the junk Yard ready to be crushed!
CMax03 is offline
Old 04-07-2014, 09:56 AM
lowpost99's Avatar
Help needed... which direction do these go back in?
Ok I've got a ps pump from an 85' and I've installed it, re-connected the return line, but I've got the line that comes off with the #24 bolt, and a spring and a pistion like rod came out, and I don't remember which end of that silver piston goes in first, and if the spring goes in before or after it.
https://dl.dropboxusercontent.com/u/...407_075854.jpg
Old 04-07-2014, 04:00 PM
CMax03's Avatar
Spring goes in first....but once i get home I'll help you....I have one apart and I work you thru it if necessary.....
CMax03 is offline
Old 04-07-2014, 11:37 PM
CMax03's Avatar
The spring goes in the bore first, and the valve can only go in one way smaller end first and ring lands last! If you installed the big end first then you won't be able to screw the connector with the pressure valve built in next!
CMax03 is offline
Old 04-09-2014, 07:17 AM
lowpost99's Avatar
Updates...
Yes, I discovered that. As well as that a SE and a GXE use slightly different PS pumps, and the brackets for the banjo hoses are oriented to take that hose slightly but critically differently, and I could not get the angle correct to start the screw, so I ended getting an exact fit from the junkyard. I'm going to go ahead and use it as is for now and if I have problems, then I'll disassemble and rebuild then. I still haven't found anything with good photos on the rebuild yet, and I still a little gun shy. I need a clamp for the hp hose, and then reinstall the belts, and I'll be ready for a test drive!
Old 04-09-2014, 12:52 PM
CMax03's Avatar
Why didyou use your banjo brkts from the original?
CMax03 is offline
Old 04-09-2014, 12:54 PM
CMax03's Avatar
There's a disassembly photos or diagrams in the FSM and the rebuild kit...I used both the 2000-01 FSM since they're all relatively the same....If you need anything I can scan what I have and email it to you...
CMax03 is offline
Old 04-10-2014, 11:43 AM
lowpost99's Avatar
I didn't. I kept the bracket that was on the pump, but apparently it's angled differently than what the line wants for the bolt fitment into the pump. When I got a 88 pump installed, it fit like a charm. I've only got to get the belts tightened up and fill with ATF and test drive. Thanks!
Old 04-10-2014, 12:07 PM
CMax03's Avatar
Great! Cycle the steering back n forth should clear all the air bubble in about 3 minutes or less.
CMax03 is offline
Old 04-10-2014, 12:44 PM
lowpost99's Avatar
Yeah will do. Hey while I not in front of the car, doesent the belt go back on like this: over the p/s pump, over the tensioner, under the crankshaft, over the water pump, and back to the p/s pump. The main belt goes back over the crankshaft and under a tensioner, and over the AC compressor. A third belt runs from the AC compressor to the altenator. I can't find a diagram of this anywhere online, and it's not on the underside of the hood. I think I've got this right, but thought I'd ask since you're online.
Old 04-10-2014, 02:41 PM
CMax03's Avatar
IF your tensioner is smooth then the goes over but if the tensioner is ribbed then the belt goes under it....I think your tensioner is ribbed!
CMax03 is offline
Old 04-10-2014, 03:08 PM
lowpost99's Avatar
ribbed tensioner
The fat belt has a ribbed tensioner between the crankshaft and ac comp. It's the one that adjusts from above near the thermostat. The ac compressor is also ribbed, and only if I go over both, will the.belt meet the ribs of the tensioner. The adjustment screw has come out. Does it need to screw into the tensioner to make it go up/down? I guess I need to go up to tighten...
Well no mechanic here, but I managed. The belt goes over both the tensioner and the AC comp. Test drive went just fine. Thanks again...
Old 07-22-2015, 12:34 PM
jake0978's Avatar
I kited mine and made a mistake the first time. Make sure you put the center O ring on the plug. Don't just lay it in the grove and set the plug in. Put it where it needs to be. The bearing doesn't come with most kits but is available on ebay.
jake0978 is offline
lowpost99
05-16-2021 11:18 AM
Fbana41
08-29-2016 12:18 PM
rbarnes
12-31-2015 06:29 PM
Mochedda
12-15-2015 11:27 AM
fastcarny
10-12-2015 07:06 AM
Quick Reply: Help with Power Steering rebuild...
