Help - 1987 Maxima Ignition / digital dash issues
I've been having intermittent issues with the speedometer registering zero. When this happens, the odometer and cruise control do not work.
Recently the ignition switch has failed will not spring back from start. Today when I started the car the entire dash was dark. I restarted the the car and the dash came back to life.
Is the speedometer issue related to the ignition problem? I've ordered a new ignition switch which includes the bracket, switch and cylinder lock.
Does anyone know the steps for removing the old bracket from the steering column? Do I have to drill out the security bolts to remove the old switch?
Any help and/or pictures would be appreciated!
the ignition swtich is the culprit which usually powers up your cars from the dash to window switches as for the key to spring back, sound like bad tumbler, so you would have to to disassemble it and see what the problem could be. I am not sure if there are security bolts on them, if they do, yes they have to be drilled out but I would check the availability of the part before taking on taking apart on your steering column so you know what you are getting into
scutmud
08-16-2018 10:56 AM
King_Ten_Ahead
09-30-2015 04:27 PM
