87 Maxima crankshaft sensor question,need some help,pease!!
Old 06-03-2013, 01:44 PM
87nissanmaxima's Avatar
87 Maxima crankshaft sensor question,need some help,please!!
Well,I'm stumped....I have a no start situation with my '87 Maxima with VG30e motor. I have no mode III codes on my ECU except 44.I've tested the iginition,coil,MAF,CTS,new cap,rotor,plugs. I'm using the FSM and think I have have narrowed the problem to either the ECU or the Crank sensor. The logic probe (while cranking the engine) test reults yeilded the following results: pin 8(1 degree signal) I got a solid green LED,which,per the probes instructions,indicates,the probe is touching electrical ground or a logic Low signal (below 2v). For the pin 17 (120 degree signal)reading I got solid green and a flashing red LED's,which means the probe is touching a low frequency curcuit. I then did the continuity check between those two wires and the crank sensor harness end and they checked fine......Should the wire to pin 8 have pulsed like the other wire to pin 17?Is this a bad ECU? Do I need to run a jumper from the crank sensor to pin 8 to test the curcuit? I'm not too proficient with electronics and need some help here,as the car has been down two weeks.....Many thanks in advance!...
87nissanmaxima is offline
Old 06-04-2013, 08:19 PM
LastTraintoMEM's Avatar
I have a thread on here that shows my details with this same problem. It's the cam position sensor. Replace it and u will be good to go!!
LastTraintoMEM is offline
Old 06-05-2013, 10:09 AM
Thanks for the reply. I replaced the crank sensor with a new one last September,could it be bad already? Last time it went bad I got the code 11 for it......But I read your post and you had a code 44 with no start and a bad crank sensor,so I guess I'll buy another new one or a used distributor with the sensor intact...I've ordered a replacement ECU and coil off Ebay in case it was either of those.....Curious the no code situation,I guess parts of the ECU age along with the sensors....
Old 06-05-2013, 02:22 PM
Solved!!!You were right,LastTrain,it was the dang crank sensor again...Found my NAPA receipt for the bad one and got a new one replaced under warranty....Apparently,some of the epoxy on the bottom of the sensor was flaking off and screwing things up because I found dust when I pulled the sensor out. The new sensor is sealed completely,so this shouldn't occur again....Took three weeks and alot of testing and cleaning,but at least I know a helluva lot more about my Maxima...Thanks again LastTrain,If you were here,I'd buy you a Guiness....!
Old 06-18-2013, 05:07 PM
Just noticed your reply. I am glad my trials and tribulations helped someone out! I am a Miller Lite man. I am drinking one on you!
Old 11-05-2013, 09:52 AM
Edge's Avatar
Looks like you and I have the same symptoms with crank sensor, though mine is OEM with no codes. I was able to find no crank output on Pin 8 with my frequency counter.
I am looking for a new reliable sensor that won't die out so soon. Do you remember the first and second sensors you got at Napa?
http://www.napaonline.com/Catalog/Ca...701_0257179771
http://www.napaonline.com/Catalog/Ca...418_0336133867
Edge is offline
Old 12-25-2013, 04:28 PM
Well, I am now back in a no start situation. I was hoping it wasn't the crank angle sensor since I just replaced it around a year ago, but this makes me think it is. I think I have a lifetime warranty on it
Old 12-26-2013, 11:04 PM
CMax03's Avatar
If you have no spark or injector signal that's where I would've gone as well!
CMax03 is offline
mrc00l88
01-25-2024 01:14 PM
kjlouis
11-24-2018 06:09 AM
Stagnet04
09-02-2015 07:53 AM
xUNIxPanther
08-05-2015 09:31 AM
yat70458
08-03-2015 01:16 PM
Quick Reply: 87 Maxima crankshaft sensor question,need some help,pease!!
