Intake setup for 87
Old 12-30-2009, 01:46 AM
CMax03's Avatar
Intake setup for 87
Who out there has a performance intake installed on there 2nd Gen? Got a friend of mine who's got the cleanest 2nd Gen, I've even seen....And we're gonna eliminating the restrictive Oem intake setup with a shortram or shortram CAI but include all necessary bungs and pipes for the AIV and other intake vacuum supported items (4 ea)iirc....also will try to fit my old 3rd gen exhaust manifolds and ypipe just to see if it is possible to eliminate that restrictive exhaust system (crossover setup)! If the 3rd gen exhaust components clear the crossmember and trans the way I'm thinking it will....we should be able to fit some headers on this setup as well!
CMax03 is offline
Old 12-30-2009, 04:54 PM
arsonist63086's Avatar
nice idea about the 3rd gen exhoust on the 1st gen maxima.... keep us updated on your build and post some pix up from you pals 2nd gen maxima...
arsonist63086 is offline
Old 12-30-2009, 11:53 PM
CMax03's Avatar
I'd have to more than likely eliminate the EGR system.....Darn I thought I 'd get more response from you 2nd Gen guys!
CMax03 is offline
Old 01-01-2010, 02:59 AM
2nd Gen Boostinator
Big_E-Dog's Avatar
if you look at it the exaust is the same the 2 banks are evenly fused together with the lower y pipe. as for intake, ill post up a pic of mine i junt installed today pretty much all on your own work.
Big_E-Dog is offline
Old 01-01-2010, 09:35 PM
CMax03's Avatar
3rd gen exhaust manifolds and ypipe fitted on a 2nd gen....not a 1st gen.
CMax03 is offline
Old 01-02-2010, 07:47 PM
Nismo87SE's Avatar
I don't think the 3rd gen exh mani will fit the rear bank. I believe its very little clearance between the oil filter and drive axle to route the exhaust.
Nismo87SE is offline
Old 01-03-2010, 07:08 PM
CMax03's Avatar
I'm sure the oil filters/adapter and driveshafts positions are the same the difference is in the Xmember...But maybe I can swap in a 3rd Gen Xmember n2 a 2nd Gen...VG Sohc is a VG Sohc....head and blockwise the engine are identical! The IM and EM are different and restrictive...and I'm sure if the 3rd Gen EM clear all obstacles a ypipe will be easy to fabricate....see the oil filter w/adapter in the 1st post
CMax03 is offline
Old 01-03-2010, 08:57 PM
Nismo87SE's Avatar
The oil filter isnt like how 3d gens are, it screws directly to block and not at angle like 3rd gens. Also clearance between the rear head and firewall is smaller than 3rd gens too.
Old 01-03-2010, 11:46 PM
CMax03's Avatar
my buddy's 87 has the adapter which angles the filter upward...seems to be very similar!
CMax03 is offline
aw11power
10-10-2021 04:57 AM
04-16-2020 05:15 AM
maxima297
09-30-2015 03:32 PM
09maxshawn11
09-30-2015 10:28 AM
MichMaxFan
09-30-2015 09:18 AM
Quick Reply: Intake setup for 87
