Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-15-2009, 09:54 AM   #1
Anyone Install Front Stabilizer Links - Length?
I just received an ACDelco p/n 45G113 and the spacer measures 3/8" shorter than the original. The kit looks like it sold under different brands such as Spicer. Otherwise, the kit parts look high quality with thick bushing retainers, urethane bushings, grade 5 bolt and a solid tube spacer (not rolled formed). It is listed as a performance kit. I would have went with the Nissan OEM, but they wanted $15 per side just for the bolt, plus all the bushings. Anyone install the link recently and compare the length or know if this link kit fits? Looks like the stabilizer bar would angle down slightly with this kit due shorter spacer length.
__________________
87 GXE All Original, 2nd Owner - Dad 1st Owner , Low miles
Edge is offline   Reply With Quote
Old 04-15-2009, 12:43 PM   #2
2nd Gen Boostinator
Big_E-Dog's Avatar
i installed mine but my spacers were about twice the size of the old ones got them from energy suspension turning is stiffer than a mofo now and i love it.
__________________
CUSTOM HEADLAMPS/CARBON FIBER/FT&RTSB/OIL COOLER/LED'S/VG30ETT/PATHFINDER INTAKE MANIFIOLD/2.5" EXHAUST/NISMO MUFFLER/HKS TT, BOV, BOOST GUAGE/Q45 BBK/K&N/2x GARRETT T-25/NISTUNE/......
Big_E-Dog is offline   Reply With Quote
Old 04-15-2009, 01:57 PM   #3
Thanks for the pic. Yep, your spacer definitely looks about 2x the length of the original 1 inch spacer. Your stab link looks pretty good and looks like urethane bushings to stiffen up the sway bar. How is the ride comfort, any different?
I did a little more research and it looks like the there are 185 other applications that use this Delco stabilizer link, so they may be consolidating kits and didn't use the exact size spacer. I have an email into Delco. This Delco kit is probably OK as long as there are no clearance problems. Performance should be OK, since the main stiffness comes from the relative twist of the sway bar and the urethane bushings. There will be a slight change in the effective radius of the lever arm of the sway bar with 3/8" height difference. I haven't calculated this yet but, should be a minor change in stiffness.
__________________
Old 04-17-2009, 09:09 PM   #4
I think like Big E, when I got new ones recently the spacer was twice as long...unfortunately the new bolts weren't long enough to use them this way so I just sawed one in half and used the halves. Didn't think about the effect the longer spacer might have on handling, otherwise I'd have gotten longer bolts and used them as they came. Mine weren't from ES (and are just black rubber) but the new stab mount bushings were, and made of that red urethane.
countzero is offline   Reply With Quote
Old 04-17-2009, 10:42 PM   #5
2nd Gen Boostinator
Big_E-Dog's Avatar
stiff al li gotta say complements the stiff suspension setting as well.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
