Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-02-2009, 12:21 PM   #81
Send a message via AIM to 914max
Watsz good wit this second gen threads there going dead we gotta tlk and give each other ideas feel me our cars are rare and need to b put on the map
__________________
87 maxima-building her up
99 maxima- rip
300zx-coming soon
914max is offline   Reply With Quote
Old 07-03-2009, 09:23 AM   #82
Quote:
AMEN!
__________________
http://WWW.JASSICS.COM ...Defending 70s,80s and early 90s Japanese cars from the junkyard and extinction!!!
DIASISS OF JASSICS.COM is offline   Reply With Quote
Old 07-03-2009, 09:25 AM   #83
the sad part is people keep junking them because theyre too lazy or ignorant to change their timing belts and when they break them they just call the junker...
__________________
Old 07-03-2009, 09:32 AM   #84
but i have GREAT news!!!!!!! me and my friends pulled a 1987 MAXIMA SE out of the junkyard the other day! we put fuel injectors in it,put new wheels and tires on {because it had none},new MAF,and are currently restoring it! and just think only 300 dollars saved this car from CERTAIN destruction! the junkyard was only 2 days away from crushing it...were gonna change the timing belt next!...
__________________
Old 07-03-2009, 10:48 AM   #85
2nd Gen Boostinator
Big_E-Dog's Avatar
oooooooh i just did sometin gangsta to tha max!!!!
__________________
CUSTOM HEADLAMPS/CARBON FIBER/FT&RTSB/OIL COOLER/LED'S/VG30ETT/PATHFINDER INTAKE MANIFIOLD/2.5" EXHAUST/NISMO MUFFLER/HKS TT, BOV, BOOST GUAGE/Q45 BBK/K&N/2x GARRETT T-25/NISTUNE/......
Big_E-Dog is offline   Reply With Quote
Old 07-03-2009, 12:54 PM   #86
uh oh!!! now what??? lol
__________________
Old 07-03-2009, 05:59 PM   #87
2nd Gen Boostinator
Big_E-Dog's Avatar
installed vent shades 17.00 off of ebay NOS!!!
__________________
Old 07-03-2009, 07:15 PM   #88
cool!
__________________
Old 07-06-2009, 08:56 AM   #89
321VQ35MAX's Avatar
I would love to find a cheap 2nd gen. An ex gf of mine had an 87 with leather sunroof and digital dash years ago. I would love to find one similar that is cheap and needs work..
__________________
321VQ35MAX - 03 Black 6spd T.E - Injen CAI-Tein S Tech Springs - Tokico Illuminas - Clear Markers- ES Shifter bushings - ES subframe bushings - ES mount inserts
Best 1/4 -14.501 @ 95.99 mph 2.20 60 ft....
321VQ35MAX is offline   Reply With Quote
Old 07-11-2009, 09:17 PM   #90
i hey a 87 maxima and i was wondering if anyone know how to reset the lock pad on the door
LOS24REYES is offline   Reply With Quote
Old 07-11-2009, 09:26 PM   #91
did you make or buy the headlamps
Old 07-13-2009, 04:29 PM   #92
2nd Gen Boostinator
Big_E-Dog's Avatar
made the headlamps, in the trunk there is a box that says controol lock assy and theres a number on it, enter that number on the pad on the dor itl beep a few times, then enter whatever code you want, and press enter. thatl be your new code
__________________
Old 07-13-2009, 07:34 PM   #93
I love lamp.
maximase86's Avatar
Send a message via MSN to maximase86
Bumpage.
I see E is at it again with his car. Lots of original things...but still can't get a decent paint job! Lookin good.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
04 Sentra SE-R Spec-V - Super Black/Silver-Black Cloth
Northwest Nissan & Infiniti
maximase86 is offline   Reply With Quote
Old 07-18-2009, 10:10 PM   #94
Send a message via AIM to rfmorrow1966
Quote:
Originally Posted by alllw86 View Post
With that many codes I would think you have a wiring harness problem. Loose or dirty connectors? Did you disconnect those circuits while the key was in start position? You’re going to have to use a digital multimeter to check out each circuit back to the ecu.
To erase the codes you disconnect your battery.
So you were able to start your car by removing that air duct hose assembly? Was it running normal when you did that? Read somewhere that car would start also by removing the air flow meter’s connection. So does that mean it’s bad?
When my car had it’s problem there was no error codes. I got tired of troubleshooting and finally just changed the AFM with a spare that I got off of eBay. That was the fix.
There is a chemical spray at the auto parts store for cleaning afm/map sensors that you could try. There is a thin wire configured in a triangle shape that can be cleaned. It may or may not help.
You got so many codes and anyone of those could be the problem.
Al
Al, finally got around to working on my Maxima. Cleared out all the errors by disconnecting the battery. Ran the Self-Diagnosis again and it came back with 12, 23 & 41. I tested the Throttle valve Switch for continuity and it failed, so I know that I need to replace my throttle valve switch. Moved on to the Air flow meter. It failed its test, so I replaced it with a used one I purchased on ebay from a working Maxima. Before I put it all back together turned over the car and it started right up as smooth as new. Drove it for about 30 minutes with the air conditioner and not a single problem. As far as error 41 is concerned; I will be testing that sensor tomorrow to see what I come up with. If it fails I will add that to my junk yard (I found a yard that has a 1987 that has great parts) shopping list. Thanks for all the advice and recommendations. This place is a real treasure chest of information.
rfmorrow1966 is offline   Reply With Quote
Old 07-19-2009, 01:36 PM   #95
Send a message via MSN to BlackTopVitz
I just bought a 1987 maxima. I am extremely happy with it. It's ugly but it's starting to grow on me.
I got it from a little old lady. Car has 67,000 kms or 40,000 miles. She was the single owner of the car and all receipts from day one including the original bill of sale. Every oil change and always brought to the dealer. Rust proofed every year.
Now I need suspension and rims and she's good!
BlackTopVitz is offline   Reply With Quote
Old 07-19-2009, 02:02 PM   #96
UGLY!!! i beg to differ!!!
http://forums.maxima.org/picture.php...pictureid=2531
http://forums.maxima.org/picture.php...pictureid=4648
http://forums.maxima.org/picture.php...pictureid=1363
__________________
Old 07-20-2009, 02:18 PM   #97
Those don't loom so bad. I like the JDM VIP look!
I really shouldn't have taken up another car project lol.
Old 08-13-2009, 05:21 PM   #98
the 87 is one of the best years of the max and yoo i think i might need another lip might get another 87 tell me what you can do
__________________
99 maxima- rip
300zx-coming soon
Old 08-13-2009, 05:22 PM   #99
any1 dwn with making a 2nd gen car club we got to keep them going
__________________
99 maxima- rip
300zx-coming soon
Old 08-16-2009, 12:30 PM   #100
2nd Gen Boostinator
Big_E-Dog's Avatar
Quote:
Originally Posted by maximase86 View Post
Bumpage.
S
y u allways brealin my balls, DAMN! LOL!
new engine pic..
__________________
Old 08-16-2009, 07:29 PM   #101
I found a 87 Maxima at picknpull 2 days ago, beautiful shape. Just the rear windows are smashed. Digital gauges and everything, the engine looked awesome too
too bad i cant bring her home, i wouldnt mind a 2nd gen to go with my 3rd gen
__________________
1992 GXE l 414,000km on original tranny and original VG30E l Pioneer Premier 12" 3500w subwoofer l 600w amp l JVC H/U l aftermarket fog lights l 2.5" Magnaflow catback exhaust l Motomaster rubber l Sparco Sprint driver/passenger seat w/drivers 6 point harness l Sparco Volanti steering wheel l Castrol Syntec oil/premium Vpower gas
Future mods- Engine swap/5spd tranny swap and after turbo
This winters mods- Z31 hood scoop, digital cluster swap, lowering springs
chrome91 is offline   Reply With Quote
Old 08-16-2009, 10:23 PM   #102
EVEYONE START TAKING THESE CARS OUT THE JUNKYARD PLEASE!!!
__________________
99 maxima- rip
300zx-coming soon
Old 08-17-2009, 04:40 PM   #103
1sik4dsc's Avatar
Send a message via AIM to 1sik4dsc
i havent seen a 2nd gen max in person in a while
__________________
Eibach pro kit, stillen front lip, tinted front/tail lights, roof overlay(getting it redone soon), bullydog tuned
1sik4dsc is offline   Reply With Quote
Old 08-18-2009, 04:05 PM   #104
Fk i'm going back to picknpull tomorrow with a buddy (dude loves looking at RX7, 300zx, etc). Its gonna be a b!sh to pass that poor 2nd gen again
they took 2 rows of domestic cars to the crusher, i think the 2nd gen has not much time left before they crush 2 rows of imports Just a window and i'm sure she would even run if i tried to crank er
I think it only had 250,000km on it, my 3rd gen is bumping 411,000
__________________
Old 08-18-2009, 10:35 PM   #105
I have one I took over from my son after it got Tboned.
All damaged parts have been replaced but not yet painted..has new Enkei 18's and now needs a battery.
82 k original miles.
As soon as I sell 2 of my Zs I will get this looking like Jay Leno's.
__________________
1987 Maxima wip
2007 350z /temp car
2006 350zr
2004 G35C
2003 350z project
2003 350z auto /temp car
2004 Chevy express
1996 Chevy Express conversion wip
raycs7 is offline   Reply With Quote
Old 08-18-2009, 11:41 PM   #106
Man i want that 2nd gen, those digital gauges are sick. Sad thing is theres a few cars at the junkyard that have VG30E engines (the '85 300zx there does) so i could get it up and running
think i'll go sit in it and drool some more tomorrow
__________________
Old 08-27-2009, 09:29 PM   #107
This is gonna kill you. The first 2nd gen i found had a bit of the console taken and the digital gauges, thats it. Some workers decided to take the engine, probably for themselves, then they crushed it.
Went today, another ones there Light blue with normal gauges, absolutely mint. only 250km on it too, so thats about 110k miles i think
__________________
Old 08-27-2009, 09:58 PM   #108
Indeed so sad.
I've been to the junkyard these couple of days... And there's always a garanteed Maxima there. Some don't even look that half bad... I guess the owners just, you know let it go.
MAX.Graff is offline   Reply With Quote
Old 08-27-2009, 11:23 PM   #109
yeah, some people can give up a car just like that. I'm one of the people who cant, if i get a car i feel like i have to do everything i can to keep it running until it wrecks or absolutely everything fails
__________________
Old 08-28-2009, 07:31 PM   #110
I feel what you saying. It's not right, I'd rather let mine retire honorably.
Old 08-29-2009, 10:14 PM   #111
86 5-speed needs a good home
I've still got my 86 SE. It now has about 225k miles but was running fine until the power steering system sprung a leak. It has been in the drive way for a couple of years now. The leak seems to be at at a fitting at the bottom of the firewall, too hard for me to get to. It starts right up on the second tap of the ignition. In the mean time the radio is gone died. Motor mounts are broken. Body is fine. I'd put up a picture but don't know how here. Would any one like to give this car a nice home? I'm 10 miles south of San Francisco. The weather here is easy on the body.
reknab is offline   Reply With Quote
Old 09-10-2009, 01:10 PM   #112
Still have mine
1986 Talking Lady, Digital dash, every option. 60,524 miles. All original.
Anyone interested in buying?
86MAX is offline   Reply With Quote
Old 09-10-2009, 04:50 PM   #113
1982 1st Gen Maxima for sale in Illinois
But since i don't have 15 replies, I can't post it.
FDSC 240 is offline   Reply With Quote
Old 09-15-2009, 11:02 PM   #114
Word. Anyone got somethin' to contribute?
Our 1st & 2nd Gens are dyin', son!
Old 09-28-2009, 07:21 PM   #115
my friend has 1989 in NJ
maxcima is offline   Reply With Quote
Old 09-30-2009, 10:23 PM   #116
I know there hasn't been that much talk 'bout these cars but...
Currently who still has their 1st & 2nd? Any pictures to show? Any projects happenin'? Anythin' long as we can get this thread movin' again.
I'll post pictures soon as someone teaches me. lol
Old 10-01-2009, 04:08 AM   #117
2nd Gen Boostinator
Big_E-Dog's Avatar
going RWD soon since the cops took the twin turbos LOL!
__________________
Old 10-01-2009, 03:23 PM   #118
Damn lol.
Why don't you tell us the story so we can know what happened?
Old 10-01-2009, 04:22 PM   #119
Quote:
STORY TIME!
Do you mean youre making your 2nd gen RWD (would be epic) or just getting a 240sx or something else RWD
__________________
Old 10-02-2009, 06:46 PM   #120
2nd Gen Boostinator
Big_E-Dog's Avatar
well what happened.....
i was at work and was hella hungry so for lunch i went to the tacobell for lunch. saw the cops on the other part of the partition and they was staring hard, i mean hard!. so i lookes then thought they couldnt be looking at me and did a doubble take and they was still staring. so i got my food watching them in my perephial. they both got into their cars. one pulled out of the parking lot like i didnt see him and waited for me at the side of the road. light turned green fot me and i rolled right past him. then he pulls out i make a right on a green light signal hand was red and no one was trying to cross. so im driving like 5 minunites and hes still tailing me. guessing he aint found nothing on me so looking for a reason. so the lights come on im like there you go you finally found sometin this is what i was waiting for. so i pull to the side he comes up and looks at the car and says:
you have a lot done to this
i laugh and say: kinda yeah why wassup
then hes all: license and reg
im like: sure
hands it to him and he goes back to his car and still finds nothing all my ish is current
so hes all: pop your hood for me
i say: yeah (**** i know he aint got a clue of what i got these moron cops)
so i pop it and its silent for a min or 2 as they inspect it.
he looks and says wheres the intake, i chuckle and point to the 2 turbos LOL!
then hes all: do you have any wastegates
i say: yeah theres 2 right there
looks more and hes all: wheres the FPR i point to it
hes like: so that is what that is....
looks more....
goes to the car gets his camera takes pictures, im like **** my setup is burned, this being a partially racist neighborhood a old white homeless guy comes up and aparently they know this guy he has warrants out for his arrest they know it and they tell him to get lost before they change their mind. im like WTF i better not get a ticket. so im still sitting on the curb 45 minunites later
then they take me to the car and is all like:
the reason why i pulled you over is for the failure to yield to the pedestrians at the right hand turn back there, and for a modified smog device. then hes all: since youve been notified you cant drive this vehicle until its repaired. repaired it 3 days later and back on the street with a letter from the ref saying that my setup is legal. i want his a$$ to pull me over thinking my **** aint fixed i will own his a$$
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
