Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-16-2008, 11:34 PM   #1
Fixed my AC.
Compressor was seized up.
figured if I'm replacing that, might as well convert over to r134a. I DID NOT use a retrofit kit. I used retrofit fittings, and used a measured amount of ester oil, which is compatible with residual r-12. I did not want leak sealers or anything else in there.
Bought a new compressor for $75 on craigslist. Also got a new receiver/drier,new o-rings and belts. Should have replaced the h-valve, but didn't.
Had the old r-12 removed. Then had a holding charge of nitrogen and a trace of 134a put in it around 50psig. Checked everything with a leak detector, picked up some residual around the valves, but no real leakage.
Replaced the compressor, receiver/drier and o-rings Put new Ester in the compressor and drier, and pulled a deep vacuum on it for 2 hours, Let it sit overnight, and it didn't lose any vacuum. Put the vacuum back on it in the morning for 30 minutes anyway, double checked it, then charged her up. Ended up putting in about 28 ounces of refrigerant, which is about 80% of it max capacity of r-12. I will put the gauges back on it as soon as we have a warm day. It was only 60 today.
Ran it for awhile, nice and cold. Let it sit and went over everything with the leak detector again.
So, I went all summer without AC and fixed it just in time for the cold weather. It wasn't my plan, but the clutch hub on the old compressor was almost cashed out, along with the belt.
Fatty Matty is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
