Electrical issues on '81 Max
Old 06-11-2007, 09:47 AM
  #41
joekool's Avatar
No more partys
Well it seems after a couple days of running and starting perfect, the celebration is over. The car is back to doing the same thing, does not start. I know the old relay was, and that replacing it with a new one fixed the problem. But how after 2 days can my relay go bad again. The only other thing I can think that I will try later tonight, is check how tight the 4 prongs are being grabbed, b the end that is attached to all the wires in the car.
joekool is offline
Old 06-22-2007, 07:55 AM
  #42
joekool's Avatar
86 maxima no start
Ok, just to refresh you all. My starter does not turn. When I turn the key I hear a bunch of relays clicking, thats it. Now I have added a ground strap to be sure Im well grounded, plus I have replaced the ignition relay "small blue" under the steering wheel, and am about to replace the starter relay "big blue" under the hood. I dont think this will solve the problem though, and this is why. When I measure the volts going to terminal "S" at the solenoid, I measure about 13 volts, when someone turns the key. I know the battery is good, and I know the starter/solenoid is good. Is it possible that even though Im getting 13 volts, I may not be getting enough amps? Any ideas?
joekool is offline
Old 06-28-2007, 12:30 PM
  #43
Hagii73's Avatar
could be, does it start with a jump? I had a cirrus once (ugh) and the battery indicated that it had enough juice, but it didnt have the cranking power cause it was a few years old. A new battery did the trick.
Hagii73 is offline
MaxLife17
06-27-2019 01:37 PM
MaxLife17
09-08-2015 02:36 PM
Maxima30
09-07-2015 06:13 PM
Hailstatejig
09-02-2015 06:52 AM
Quick Reply: Electrical issues on '81 Max
