Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 01-25-2005, 05:11 AM   #1
new to the maxima world
hi, first off since this is my first post id like to introduce myself my name is Roband im from Washington state, most of my automotive knowledge is in toyota trucks but i just bought an 87 maxima from a friend for $200 bucks. the car is in pretty good shape for being so cheap, a few dings but not bad and a moldy smelly interior. ill post some pics if anyone wants to see them. it does have a problem when cold, it doesnt want to run, the idle will fluctuate up and down and rise slowly as it warms up, but it always fluctuate and has a slight miss, but after it has risen to full temp everything smooths out for the most part, the fluctuation in rpm drops only by a hundred rpm or so instead of a thousand, it could just be in need of a tune-up since its been sitting for a while but if anyone has any ideas of what to check besides the basic plugs, wires cap rotor fuel filter air filter etc. id like to hear them. also the sun roof only goes halfway back then seems to bind up. how hard is it to change a clutch out on one of these things, ive done them on toyota trucks but those sit alot higher and you have alot more room to work. this engine also has 180k on it, how long do these engines (its a v6) last. oh and what are the main things that usually give out on these cars, common problems.well thats it for now, im sure ill have a bunch more questions once i get started working on this thing any help that you guys and gals can give me would be greatly appreciated.
87MaximaGuy is offline   Reply With Quote
Old 01-25-2005, 06:24 AM   #2
Hi Rob. I also have an '87 maxima. Paid $500 for mine. I have 250k+ and runs great. Like 80land said, the fuel injectors for this year car are under recall. I had mine done a month ago. They replaced all the fuel injectors, fuel rail, hoses, filter, etc. at no cost, parts or labor. Call your local dealership. That's where i would start. As for your sunroof, run it forward and check the track for any debris that way be binding the path going back. May just need greased.
Mine's sitting right now, waiting for a solenoid to come in. Dunno, if that will solve my no start situation or not. May be anti theft activated...
Good luck on your car, you made a good choice.
kathy is offline   Reply With Quote
Old 01-25-2005, 06:57 AM   #3
Blown
Send a message via AIM to cardana24
sounds like you may need an Aux. Air Valve....check out the stickies that is a common problem with our cars. It will cause you to have problems on cold starts. Its also know as an Air Bypass Valve.
cardana24 is offline   Reply With Quote
Old 01-25-2005, 07:49 AM   #4
The Man is watching.
Send a message via MSN to maximase86
Also www.partamillion.com has AAV's for around $75 new. Cool part is they have a warehouse up here in Lynnwood, so shipping will be very quick (most likely next day). Spend over $100 there, and I believe shipping is free.
For the sunroof, what'd I check is to see if the mounting bolts for the motor have work thier way loose. That could be causing your binding. Basically where the control switch is, and the reading lights are, if you pop that off, you can get to the motor.
As for the longetivity of these motor......one of the longest lasting V6's you'll find. My car is pushin 211k before I broke my timing belt on start up (when 90k on that belt. DOH!)....but I most likely went unscaved.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 01-25-2005, 05:10 PM   #5
hey thanks for all the info, ill check with nissan tomorrow, and yeah i saw the air valve thing right after i posted. i thought id post a pic of my awseome beast.
http://www.imagestation.com/picture/...b.jpg.orig.jpg
i really like the yellow go fast stripes on the rockers.
Old 01-25-2005, 09:22 PM   #6
Super Moderator
Hmmm Im seeing a red x
__________________
Shift_PRND21
1995 BLK/BLK SE:
Warpspeed superflo y-pipe, Tokico Illumina Suspension Kit,
5th gen Strut bar, ADDCO RSB,
17x7 ADR SZ1 rims, red laquered calibers, Nexen N3000 tires,
Smoked Diamond clear turn signal lens,
AE Headlights/clearance lights/foglights, rewired fogs
max95q is offline   Reply With Quote
Old 01-26-2005, 03:12 AM   #7
well it worked when i posted it, maybe it will come back.
Old 01-26-2005, 06:39 PM   #8
I got 225K miles on mine and going strong... Replaced injectors and rails last summer
max88ima is offline   Reply With Quote
Old 01-26-2005, 09:40 PM   #9
You're gonna have to host your pics else where. Both the link and the image link you posted are bad. Probably because you have to be a member or part of image station to view it. You might try using car domain.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 01-27-2005, 03:27 AM   #10
hmm thats odd i can post pics in other forums.
Old 01-27-2005, 07:22 PM   #11
Ah it's working now.
IS that yellow on the underside? Paint peel down to primer? The car looks familiar.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 01-27-2005, 10:09 PM   #12
yeah whoever had it before my buddy must have painted those on, everyone knows yellow = fast.
Old 01-28-2005, 06:48 AM   #13
Blown
still does not work for me....can you just post it on the thread?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
